how does a CG125 go ?
themadatter
PostPosted: 23:07 - 20 Feb 2005    Post subject: how does a CG125 go ? Reply with quote
Hi there,
my CG125 will do about 50mph on the speedo top.
and you have to rag it in every gear to get it to go anywhere,,,i heard these things CRUISE at 55 and do 60-65 ?
well at 50 mine is making alot of racket and theres nothing left in it.
besides the tappets needing set i cant find anything wrong with it
is this normal ?
how do CG's usually perform ?
its a 1991 model
Jamie
nick.h
PostPosted: 23:09 - 20 Feb 2005    Post subject: Reply with quote
CG's aren't built for speed, but reliablity. They can't be 'tuned' as they run on a 4T engine.
[Italjet MM5A] ll [Rieju RS1 Evolution] ll [Suzuki GS500e] ll [Suzuki GSX600F] ll [Honda CG125] ll [Pug Elyseo 125] ll [Yamaha YZF750R] ll [Yamaha Thunderace] ll [Yamaha R6] ll [Triumph 955i] ll [Hayabusa RZK3] ll [Suzuki RGV250] ll
White Noise
Mr Dudwee
PostPosted: 23:11 - 20 Feb 2005    Post subject: Reply with quote
by means of an internal combustion engine Laughing
From my limited knowledge of them i found that the one i was riding could get upto 55-60 at a push but this was a newish riding schools bike.
WN
themadatter
PostPosted: 23:12 - 20 Feb 2005    Post subject: thanks Reply with quote
Well any engine can be tuned, but i don't want to tune my cg.
I just want a rough guide on how they perform so that I can tell weather mine maybe needs to be looked at.
thanks
Jp
nick.h
PostPosted: 23:15 - 20 Feb 2005    Post subject: Reply with quote
Are you a fat/tall git, you could be losing top-end that way Laughing
mchaggis
They're relatively indestructable, they tend to get thrashed a lot because they never go very quickly. If you keep feeding it fresh oil every 1000-1500 miles and make sure it's not running too rich, and that it's carburettor isn't gummed up then there's not a lot else that can go wrong. The Haynes recommended valve tappet clearances are pretty loose and it'd be unsurprising were they done up to zero clearance. 0.03 mm or something is perhaps best.
Watch out for a rumbling and heavy vibration in the footpegs. If you get that, it's likely that your main bearings are giving way. At the end of the day, it's a four stroke 125, it's not meant to go quickly, the 93 (I think) model my Mum has in the garage did about 55 tops (before it knackered a bearing and killed it's spark plug).
I must not be a troll...
Mmmm, Guinness
PostPosted: 23:16 - 20 Feb 2005    Post subject: Reply with quote
Depends how heavy you are, if there is a headwind and if you are going up a hill.
Given someone of average weight on a level straight with no headwind then 65mph should not be an unreasonable expectation.
I would get myself a workshop manual and do all the stuff listed under a major service/tune up then see how you go.
dibbster
PostPosted: 23:18 - 20 Feb 2005    Post subject: Reply with quote
WN
I found the newer ones to be slightly slower than the older 1990ish model after leaving my instructor behind in a NSL during training. Laughing
Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's Thumbs Up
www.bikepics.com/members/dibbster
Silky
PostPosted: 00:05 - 21 Feb 2005    Post subject: Reply with quote
I dont think theres anything to worry about mate. Ive got a 97 model, and that doesnt seem to want to go any higher than 50 at all.
unless we have a similar problem Confused
But i doubt it very much. Bullet proof engines! Wink
Just think, would you rather be going at 50 all day on a CG? or 80 now and then on a wanked up RS? Mr. Green
tony532
PostPosted: 00:08 - 21 Feb 2005    Post subject: Reply with quote
didnt you have an rs125 and crash and break your wrists 2 years ago
if your the same person from apriliaforum.com
themadatter
PostPosted: 01:47 - 21 Feb 2005    Post subject: small world Reply with quote
Hi there
Yea I have an Rs too, and had an accident 2 years ago, broke alot of bones.
How did you know it was 2 years ago ! ? thats scary....
Good bike, and i find it to be ultra reliable as long as its looked after.
Always wanted a CG125 and im happy enough with it,
[glad to hear about the 1997 model that only doees 50 !, sets my mind at ease]
Jp
binge
Emo Kiddy
PostPosted: 03:17 - 21 Feb 2005    Post subject: Reply with quote
Well Compaired to 260mph on you RS125, Im sure that 55mph does feel very slow Laughing
dodsi
Dirty Carny
PostPosted: 04:17 - 21 Feb 2005    Post subject: Reply with quote
how does a CG 125 go?
Brum brum normally.
mchaggis
PostPosted: 09:43 - 21 Feb 2005    Post subject: Reply with quote
dodsi wrote:
Brum brum normally.
Someone just had to say it!
Mmmm, Guinness
tony532
PostPosted: 17:19 - 21 Feb 2005    Post subject: Reply with quote
hi madatter
i have a very good memory
which is suprising considering the amount of stella i drink
Silky
PostPosted: 18:06 - 21 Feb 2005    Post subject: Reply with quote
Brum brum normally
Well actually IMO its more of a really fast 'Brup Brup Brup' Laughing
Unless your ragging it to get every last drop out of it, then its a 'Brruuuuuuuuuuuhhhh!!!!' Laughing
JodieWodie
Reflective Banana
PostPosted: 18:58 - 21 Feb 2005    Post subject: Re: how does a CG125 go ? Reply with quote
Jamie
Well...fuk knows what's wrong with it.
Mine isn't old, and I am not a mechanic ..so.... Shocked
My CG is an 04 model..and it does 60 cruising nicely...and 75 top end.
I am not tiny, nor large..sort of normal frame woman...and it is true...in bad winds it does slow the bike down and some noise and shaking may occur, ..if it was STRONG wind, and up-hill, about 65 max..yes.
Courage doesn't always roar. Sometimes courage is the quiet voice at the end of the day saying, "I will try again tomorrow"
pipnet11
PostPosted: 20:08 - 21 Feb 2005    Post subject: Reply with quote
Should do 60 quite easily, but you do need to rag the tits off them to get it there. Top speed seems to be about 65 for the older ones and 70 ish for the newer engine.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
PostPosted: 20:19 - 21 Feb 2005    Post subject: Reply with quote
You may find that oiling the speedo cable will give you an extra 5-10mph. It used to on my old 125 Wink
What I'm trying to say is the speedo on those bikes was designed in the 1970s. Back then speedos were little more than a guide at best, wildly innacurate at worst. You are all probably doing exactly the same speed on your CG125s. It is a fair bet to say that when you hear the valves bounce, it will be doing somehwere between 65 and 70mph
themadatter
PostPosted: 21:23 - 21 Feb 2005    Post subject: Speedo cable Reply with quote
Hi there,
This crossed my mind, as I was going through a 30 zone at an indicated 30mph but was sure i was going faster.
I just put this down to the feel of a different bike.
Anyway; thanks for the replies,
I'm not really concerned with speed its just to gauage how well mine is set up.
Thanks
Jp
Silky
PostPosted: 00:58 - 22 Feb 2005    Post subject: Reply with quote
ok... take back what i said about my top speed being 50.
Just got 60 out of it. Laughing
All you need is a nice long straight, good clutch control and a lack of wind.
Oh, and make sure you really use ALL the gears have to give, especially 3rd.
Good luck Very Happy
The last post was made 21 years, 118 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.28 Sec - Server Load: 1.65 - MySQL Queries: 13 - Page Size: 113.62 Kb
