Battery care
Ariel Badger
PostPosted: 19:01 - 21 Jun 2016    Post subject: Battery care Reply with quote
I need a set of starting rollers to fire up my bike and use a car battery to power them. what is the best way to keep this in decent condition? Optimiser, run down with a bulb and recharge or just put on the charger once a week?
herulach
PostPosted: 19:13 - 21 Jun 2016    Post subject: Reply with quote
No danger of using a deep cycle instead? You can get ones intended for solar trickle charging that would probably suit nicely.
YBR 125>FZS600
PostPosted: 19:13 - 21 Jun 2016    Post subject: Re: Battery care Reply with quote
Is it just a normal car battery? Or a deep cycle leisure battery?
Normal car batteries do not like being run down low, hence flattening it with a bulb would probably dramatically shorten its life
Katy
Oldie
PostPosted: 19:24 - 21 Jun 2016    Post subject: Reply with quote
I would definitely just put it on the charger once a week. Any old charger should do the trick. I've gradually given up on trickle charging as I reckon that theses so called smart chargers probably kill at least one in five motorcycle batteries, and new, or newish, ones at that.
That's my rough estimate using my last 30(ish) bikes as evidence, and four different "name" chargers.
Ariel Badger
PostPosted: 20:10 - 21 Jun 2016    Post subject: Re: Battery care Reply with quote
Katy
Normal car battery Katy, in fact I had to use the one off my car on Sunday as the dedicated battery had died on me. I will not flatten in but just draw a bit of juice off before recharging.
herulach
PostPosted: 20:56 - 21 Jun 2016    Post subject: Re: Battery care Reply with quote
Katy
How many amps do you need? Could you just wire it to jump leads instead or will it need running away from the car/van
YBR 125>FZS600
Ariel Badger
PostPosted: 21:05 - 21 Jun 2016    Post subject: Reply with quote
Tried it using jump leads but not enough umph to start the bike, so I had to pull the battery out of the car and hook it up to the starters. Not sure how many amps it pulls but the starter motor is huge from a truck.
Ariel Badger
PostPosted: 21:10 - 21 Jun 2016    Post subject: Reply with quote
herulach
PostPosted: 21:14 - 21 Jun 2016    Post subject: Reply with quote
Sure its not rated for 24V then? Might explain why its struggling at 12.
YBR 125>FZS600
Ariel Badger
PostPosted: 22:01 - 21 Jun 2016    Post subject: Reply with quote
No it is 12v and does not struggle with a good connection rather than jump leads. I made them in 2011 and have had no trouble at all.
MCN
PostPosted: 17:04 - 23 Jun 2016    Post subject: Reply with quote
£40+ for a Ctek. Bullet proof fit and forget. Smile
Mibby more than £40+ Embarassed
^^^ Miles oot.
About £70 Smile
I would advise a maintenance charger as you will forget to charge or forget it's charging and have no week-end fun or burn the house down. Smile
The last post was made 10 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 73.85 Kb
