FZS 600 wobble - bearing collapsed.
Bike Chat Forums Index -> The Workshop Goto page 1, 2, 3, 4, 5, 6  Next
herulach
PostPosted: 11:03 - 15 Jun 2016    Post subject: Reply with quote
Sounds like you've fucked something up putting the rear end back together. Rear wheel straight, chain right length etc?
YBR 125>FZS600
Pjay
PostPosted: 11:42 - 15 Jun 2016    Post subject: Reply with quote
Wheel alignment?
Edit*
Just read that it's been asked...
jjdugen
PostPosted: 17:26 - 15 Jun 2016    Post subject: Reply with quote
Front tyre.
Hahadumball
PostPosted: 17:46 - 15 Jun 2016    Post subject: Reply with quote
what sort of wobble?
theres light rear end wobble
massive tank slapper
and everything inbetween.
odd youre having issues with wobbles, mine was so planted and only had 1 wobble and that was when i had tyre slime in the rear tyre.
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
SQL
PostPosted: 20:25 - 15 Jun 2016    Post subject: Reply with quote
that shit was in the front too
Hahadumball
PostPosted: 21:10 - 15 Jun 2016    Post subject: Reply with quote
yeah it was! works wonders though! not so bad in the front but notice it so bad in the rear!
i forgot to mention the rear to bike shop when i got tyre changed and he was mad!
Meatybeaty
PostPosted: 09:08 - 30 Jun 2016    Post subject: Reply with quote
Hi Ash ,not a problem this one , just a matter of getting out the rear wheel and drifting out the old bearings , if you have got the bearings already put them in the freezer ,it will help when you come to install them, its a matter of keeping everything clean when you install them and dont force them in , if you have got some long bolts and sockets you can make a puller. Have a look at Haynes manual Section 7;20 Thumbs Up
Meatybeaty
PostPosted: 09:19 - 30 Jun 2016    Post subject: Reply with quote
PS, are you doing all bearings or just the sprocket carrier Thumbs Up
zark
PostPosted: 09:21 - 30 Jun 2016    Post subject: Reply with quote
Done mine recently, just coz it was apart for other stuff. The wemoto kit for the rear bearings is fab. 2 wheel bearings, seal for offside, carrier bearing and seal, little over 20 ponds... even I got them fitted without mucking it up, using a long screwdriver to twat the old ones out, and a big socket to nudge the new ones in. Don't forget the spacer in the carrier bearing centre.
CBT - Oct 13. Theory - July 14. Mod 1 & 2 - June 15.
Rides a Fazer like an idiot... Edit: Now ride a Fazer Thou...
Meatybeaty
PostPosted: 09:24 - 30 Jun 2016    Post subject: Reply with quote
You wont know that until you get whats left of that chewed bearing out, but expect the worse, but the outer race of the bearing might have saved it Thumbs Up
Meatybeaty
PostPosted: 09:27 - 30 Jun 2016    Post subject: Reply with quote
Buggered Ash, need a new one there
Meatybeaty
PostPosted: 09:36 - 30 Jun 2016    Post subject: Reply with quote
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2055119.m570.l1313.TR0.TRC0.H0.Xyamaha+fzs600+2001+sprocket+carrier.TRS0&_nkw=yamaha+fzs600+2001+sprocket+carrier&_sacat=0
Meatybeaty
PostPosted: 09:41 - 30 Jun 2016    Post subject: Reply with quote
Just one of those things Ash, I think you can see some rust on the wheel bearing , so you have had an egress of water over time and they have just rusted, are your bearings of the sealed type or have you bought dust seals as well Thumbs Up
PostPosted: 09:43 - 30 Jun 2016    Post subject: Reply with quote
The looks like it has been fucked for a while, I'd to all 3 bearings personally.
Meatybeaty
PostPosted: 13:47 - 30 Jun 2016    Post subject: Reply with quote
The oil seal is useless now Ash just prise it out , your gonna need new ones, then its a matter of drifting out the bearing , the block of wood is only to get some leverage when you get your screw driver under the lip of the seal Thumbs Up
sickpup
Old Timer
PostPosted: 14:25 - 30 Jun 2016    Post subject: Reply with quote
When you checked the rear wheel did you try wiggling the sprocket carrier?
Meatybeaty
PostPosted: 14:29 - 30 Jun 2016    Post subject: Reply with quote
Yes Ash , but be careful when you attack the bearing from the other side ,put two lumps of wood under the rims to keep the brake disc of the ground so as not to damage it ,if there were circlips there they would be underneath the oil seal Thumbs Up
The last post was made 9 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 6
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.64 - MySQL Queries: 16 - Page Size: 132.36 Kb
