| chris-red |
 Posted: 14:46 - 05 Jul 2016 Post subject: Tropical fish tank - advice tips etc. |
I'm ridiculously impulsive and recently bought a 64l tank and a load of bits and bobs. I think I'm a little bit out of my depth (fnar fnar) I have a few questions.
I've checked my water levels and it all seemed acceptable apart from the hardness which is off the chart. Is this a problem to I need to do anything?
I have these
https://www.amazon.co.uk/Aquarium-Water-Treatment-Conditioner-Stress/dp/B00L2D5R3E/ref=sr_1_7?ie=UTF8&qid=1467728941&sr=8-7&keywords=api+coat
and something to feed my plants.
Do I need to add anything else?
My water looks a bit murky is that OK? I'd like it clearer any ideas how.
What do I need to do to keep it in good shape? I was told to replace 20% of the water once a month. Is this simply a case of putting tap water in and adding the treatments or should I treat it first?
Here it is,
https://img.photobucket.com/albums/v295/chris-red/Mobile%20Uploads/IMG-20160703-WA0002_zpshf0ukbub.jpg
You can see the murk.
What other hardware to I need I have a net, I'm guessing a gravel cleaner is a good idea too, anything else?
What about the tenants? I want bright colourful things, I'd also like weird and wonderful things. I saw Shrimp in the pet shop that I found quite cool to watch so was going to get some of them as for the rest I was going to pick lairy fish.
Any suggestions? Nothing that grows too big or would attack anything or is difficult to keep alive. The lady in the shop told me every litre of water supports 1cm of fish. I would rather quantity over size as. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| CaNsA |
 CaNsA Super Spammer
| chris-red |
| CaNsA |
 CaNsA Super Spammer
 Posted: 15:01 - 05 Jul 2016 Post subject: |
I have my white lights on a timer.
They come on at about 4 or 5pm and stay on for 7 or 8 hours.
I have two diff temps of lights.
1 to promote plant growth and the other to enhance the visual colour of the fish.
Depending on how anal you want to be, and i know that you are an analyst, have a gander at this guide.
https://www.firsttankguide.net/cycle.php
| chris-red |
| CaNsA |
 CaNsA Super Spammer
| chickenstrip |
 chickenstrip Super Spammer
 Posted: 15:05 - 05 Jul 2016 Post subject: |
Jeez, you'd have thought a chap would read up on it a bit before plunging in! CaNsA, just recommend a good starter book for him will ya!
I used to keep a tank myself, nice little hobby. ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
THERE'S MILLIONS OF CHICKENSTRIPS OUT THERE! |
| MCN |
 MCN Super Spammer
 Posted: 15:08 - 05 Jul 2016 Post subject: |
Hardness is not a problem for the fish.
It could be a problem if diatoms become an issue. Micro beasts who pull the chalk out of solution to build their wee houses (sort of coral like).
Harmless things on their own but they coat everything then any algae you have can lock into the wee shell hooses.
You can normally scrape off algae but if theu are stuck to diatoms then it is more difficult to scrape off. Think scraping emulsion paint.
I dealt with this in when using Yorkshire Water (at 9 out of 10 on the water Richter scale) by installing my own RO plant in the hoose. But that takes everything out so you you need to add a little bit back so the fish don't dissolve in the pure water.
I fitted an external filter too which helped with the nitrates too. More filter area for beneficial micro beasts to live on/in.
Water changes about 20-30% every couple of weeks but use a chemical test to determine when. You may need to do it more often
Get clued up on Nitrogen cycle in aquria.
And get an RO plant.
Aquariums are as expensive as feckin' golf is  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| CaNsA |
 CaNsA Super Spammer
| chris-red |
| CaNsA |
 CaNsA Super Spammer
| colink98 |
 colink98 Could Be A Chat Bot
| andyscooter |
 andyscooter World Chat Champion
| Chinaboy |
 Chinaboy World Chat Champion
| CaNsA |
 CaNsA Super Spammer
| Chinaboy |
| andyscooter |
 Posted: 19:52 - 05 Jul 2016 Post subject: |
Not exactly nice looking is it looks like it's taken directly from a fish shop ____________________ gilera runner vxr200 (chavped)
if its spelt wrong its my fat fingers and daft auto correct on my tablet |
| Chinaboy |
| CaNsA |
 CaNsA Super Spammer
| defblade |
 defblade World Chat Champion
 Posted: 06:17 - 06 Jul 2016 Post subject: |
My top tips (running a 155l tank for the last 8 years):
#1 Understock the tank, by the best part of 50%. This way you don't strain the system at all and maintenance required goes waaaay down.
#2 Shrimp and plants (plenty of plants) are good - they are your clean-up crew, both will sort out a lot of the waste products that the fish generate.
#3 Put the lights on a timer and give it an hour or two break in the middle of the day - algae copes with this much less well than proper plants.
#4 Be very aware of the size fish you buy will grow to - especially if you like odd stuff. You probably shouldn't put anything that grows to more than 4cm in that tank, you might get away with 6cm. Lots of small fish makes a better show than a couple of large unhappy ones anyway. Also avoids dominance problems that can occur when you have a small number of male (the pretty ones!) fish - the alpha fish will hound just one or two rivals literally to death. Having lots means the stress is split up. (Plants = hiding places. This is good here too.) Have a look at the various types of rasbora if you don't fancy tetra. A shoal of copper or harlequin rasbora is lovely
That'll do to get you started
I do 50% water changes about every 6 months, BTW, and my water quality stays fine (that should get 'em screaming ) ____________________ Honda Varadero 125cc => Suzuki Bandit 650 33bhp => 77bhp =>
BMW K1200R Sport 163bhp => Aprilia Shiver GT 750 95bhp |
| andyscooter |
| CaNsA |
 CaNsA Super Spammer
| bugeye_bob |
 bugeye_bob World Chat Champion
 Posted: 07:18 - 06 Jul 2016 Post subject: |
Buy a water test kit from the likes of API,
This will tell you when your tank has cycled and is ready for fish,
None of this buy cheap fish to start it off crap after a few days, good money maker for a pet shop,
Once you have the filter working/cycled you can add fish,
I do 25% chanel every 2 or 3 weeks,
I run a few tanks and have had no major problems in 10 years,
I use a beer making bucket for water changes,
Add my tap water to this bucket, then the tapsafe, and leave with a spare water heater until it's about the right temp, so as not to shock the fish,
Start off with simple pretty fish that are easy to manage,
Many fish forums have tank calculators that will give you a guide to what and how many fish your tank can hold,
Hope this helps. |
| andyscooter |
| t121anf |
 t121anf World Chat Champion
The last post was made 9 years, 251 days ago. Instead of replying here, would creating a new thread be more useful? |
