NSR 125 fork seals still leaking
Farmingstock
PostPosted: 23:08 - 08 Jul 2016    Post subject: NSR 125 fork seals still leaking Reply with quote
Hello,
I have changed the fork seals twice and they are still leaking. One more than the other.
Would anything other than the seals cause the forks to leak?
They are fine when I test them off the bike, but as soon as I get them on the bike and down the road they spit oil out of the top. It's instantly grey as well for some reason???
Itchy
PostPosted: 23:13 - 08 Jul 2016    Post subject: Reply with quote
Did you also change the bushes?
Islander
PostPosted: 23:24 - 08 Jul 2016    Post subject: Reply with quote
What Itchy said. Worn bushes cause the sliders to run off true on the stanchions and that can cause seal failure.
Other causes are cheap pattern seals, pitting on the stanchion and not protecting the seal lip when fitting.
Nobby the Bastard
Harley Gaydar
PostPosted: 23:31 - 08 Jul 2016    Post subject: Reply with quote
What condition are the stanchions in? How much rust? How pitted are they where they run across the seals?
Triumph Sprint ST 1050
Islander
PostPosted: 23:34 - 08 Jul 2016    Post subject: Reply with quote
And above that. If you're pushing a seal down over a rough stanchion it's not going to do it any favours. Wink
Farmingstock
PostPosted: 23:42 - 08 Jul 2016    Post subject: Reply with quote
Hi all
Wow
Thank you for the quick responces, the stantions are mint, no pitting at all, no rust.
The bushes have seen better days, but they are discontinued now.
I have just been looking at some videos and manual diagrams and things aren't adding up.
Which way round should the seals go? And where should the washer go before or after the seal?
It looks like I have put them in the wrong way round, this time but I did the reverse last time as I have found two different versions!
I need this clarifying once and for all!!!
My bike is a Honda NSR 125 1991 Alcast
Islander
PostPosted: 23:52 - 08 Jul 2016    Post subject: Reply with quote
Washer goes between seal and bush - i.e. under the seal. Retaining clip goes above the seal. If it's a seal with a flat side and an open side then the flat side goes uppermost.
Nobby the Bastard
Harley Gaydar
PostPosted: 23:54 - 08 Jul 2016    Post subject: Reply with quote
Buy a Haynes manual
Look at the pictures.
Farmingstock
PostPosted: 00:07 - 09 Jul 2016    Post subject: Reply with quote
Looks like I have put the washers in the wrong way round this time then.
The seal has a bit of a concave, an open bit on one end and a concave bit on the other. Should the open bit face up?
The image is of the concave bit
Islander
PostPosted: 00:09 - 09 Jul 2016    Post subject: Reply with quote
That looks like the top of the seal.
Farmingstock
Buy a Haynes manual
Downloaded the Honda manual, that shows it one way, yet the online parts diagrams show it differently, Haynes don't sell the NSR manual, otherwise I would have bought one.
Farmingstock
PostPosted: 00:10 - 09 Jul 2016    Post subject: Reply with quote
So that should face the top of the fork?
Islander
PostPosted: 00:11 - 09 Jul 2016    Post subject: Reply with quote
Yep.
Farmingstock
PostPosted: 00:18 - 09 Jul 2016    Post subject: Reply with quote
Islander wrote:
Yep.
Right well I've got it the wrong way round now, but had it the correct way first time round and it still leaked.
Meatybeaty
PostPosted: 08:26 - 09 Jul 2016    Post subject: Reply with quote
This any good to you Thumbs Up
skatefreak
PostPosted: 09:26 - 09 Jul 2016    Post subject: Reply with quote
slightly different design to my CBR600 but the two bushes (7/8 in the diagram) were worn and sliding over each other and the Teflon coating was being scraped off and contaminating the fork oil.
This lead to me curing 3 separate oil seals and partially losing my sanity until someone suggested it. Replaced them and not had a problem since.
Get them out, measure them up, am sure they will match another one from somewhere, or give david silver spares a call Smile
Farmingstock
PostPosted: 10:51 - 09 Jul 2016    Post subject: Reply with quote
Could probably do with a hand yeah 👍
Farmingstock
PostPosted: 10:52 - 09 Jul 2016    Post subject: Reply with quote
Going to phone them now thanks
Meatybeaty
PostPosted: 12:17 - 09 Jul 2016    Post subject: Reply with quote
Hi have you got a manual with this page in it Thumbs Up
Farmingstock
PostPosted: 16:13 - 09 Jul 2016    Post subject: Reply with quote
Does that come under the title of complete gimp? No your no where to be found in the manual! Thanks for the helpful input tho 👌🏼
Meatybeaty
PostPosted: 16:18 - 09 Jul 2016    Post subject: Reply with quote
I guess what I'm asking you is do you need a manual Wink
Farmingstock
PostPosted: 16:33 - 09 Jul 2016    Post subject: Reply with quote
Thing is Haynes don't make the NSR 125 88-91 manual and any other manual available I have downloaded!! So basically yes I do need a manual but They don't exist!!
Meatybeaty
PostPosted: 16:37 - 09 Jul 2016    Post subject: Reply with quote
Right ,you've probably got the one i've got 222pages
Farmingstock
PostPosted: 16:51 - 09 Jul 2016    Post subject: Reply with quote
Yeah think so, it's a pdf on my PC, it's in black and white, but blurry!!
Meatybeaty
PostPosted: 17:03 - 09 Jul 2016    Post subject: Reply with quote
Yeh could have the same one, but i also have the parts booklets, have a look if their any good to you
https://www.dropbox.com/sh/sf3uiqzvnkbtwkd/AACxDth07YAod1niitEad6Cda?dl=0
The last post was made 10 years, 115 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 119.49 Kb
