Fibre speed test, which what one I ort to be believing govna
M.C
PostPosted: 14:19 - 15 Jul 2016    Post subject: Fibre speed test, which what one I ort to be believing govna Reply with quote
Recently upgraded to fibre broadband, and I've run a few different speed tests (on a wired connection) to see what I'm getting:
Internet Frog: 10.22Mb/1.37Mb (up/down)
Speedtest.net: 51.51Mb/9.43Mb
BT's own tester: 47.05Mb/9.38Mb
What one should I believe? Thinking I'm inclined to believe Internet frog as when I've had broadband issues in the past (barely able to load videos etc.) it has always reflected this in test results.
Also downloaded a couple of games this morning and whilst it was quick, it didn't seem to be the sort of jump you'd expect going from 3-4Mb to allegedly 50ish. Also Speedtest/BT's checker seem to vary a lot more.
Matt B
PostPosted: 14:31 - 15 Jul 2016    Post subject: Reply with quote
No idea, but ours at home is 5Mb. Every test I've just run says the same, except that frog one, which says 3Mb. Seems inaccurate.
PostPosted: 14:33 - 15 Jul 2016    Post subject: Re: Broadband speed test, what one to believe? Reply with quote
*Which
PostPosted: 16:17 - 15 Jul 2016    Post subject: Reply with quote
*ought
M.C
PostPosted: 16:45 - 15 Jul 2016    Post subject: Reply with quote
The Shaggy D.A. wrote:
*ought
Character limit Wink
herulach
PostPosted: 16:54 - 15 Jul 2016    Post subject: Reply with quote
Bts own (or maybe speedtest) is the only one testing whqat you're paying for. i.e. a connection to BT's servers. Anything else going outside their datacentre isn't covered by your contract IIRC.
YBR 125>FZS600
ScaredyCat
PostPosted: 17:46 - 15 Jul 2016    Post subject: Reply with quote
Test to your ISP that's the only one that makes sense.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
PostPosted: 18:41 - 15 Jul 2016    Post subject: Reply with quote
Where were you downloading games from?
The only places I can max out my connection are Windows Updates and Steam.
M.C
PostPosted: 22:18 - 15 Jul 2016    Post subject: Reply with quote
Xbox. I've got some stuff to DL'd off steam tomorrow so I'll see if it's any better.
PostPosted: 22:49 - 15 Jul 2016    Post subject: Reply with quote
As speedtest.net and BT's own speed tester sound right I don't think you've got much to worry about.
Internet Frog gives me a result that's about 1/4 of what speedtest.net and BT's own one says.
Quite willing to bet that Internet Frogs server is somewhere far away and or they've got a slow connection.
Your connection works fine, stop speed testing and get on with downloading the internet. You'll find that you can't get full speed from the vast majority of sites or services but that's inevitable when you've got super faster internets. Thumbs Up
orac
PostPosted: 21:15 - 17 Jul 2016    Post subject: Reply with quote
FYI consoles are notorious for being shockingly slow at downloading stuff. There are quite a few pages out there walking through speeding up the network connection.
also make sure your using LAN and not wifi, its surprising how much wifi can sometime slow stuff down
Jayy
Mr. Ponzi
PostPosted: 00:57 - 18 Jul 2016    Post subject: Reply with quote
Are you on WiFi or LAN?
Are you on the master socket or an extension?
Also, try: https://www.fast.com Thumbs Up
Jayy
Mr. Ponzi
PostPosted: 01:00 - 18 Jul 2016    Post subject: Reply with quote
That's the only place you max out?
Loui5D
PostPosted: 10:51 - 18 Jul 2016    Post subject: Reply with quote
I find Origin is uses the most out of my connection.
Steam will usually sit around 900Kbs whereas Origin is usually 1.2Mbs
R1stu
Shrek!
PostPosted: 11:13 - 18 Jul 2016    Post subject: Reply with quote
If you want to raise a fault, you need to run bts own speed tester.
This is the only one they will accept speeds from.
You also need to complete all tests, and enter your number. Complete them at least 10 minutes apart.
Once all 3 tests are complete they will appear against your number on the BT system so they will see the results when you raise a ticket.
if you dont enter your number it wont link to your acccount, and they will ask you to complete them again.
You mail also have to change the Un/PW in the router too for their account for speed testing to complete the TAP3 testing.
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
Jayy
Mr. Ponzi
PostPosted: 12:29 - 18 Jul 2016    Post subject: Reply with quote
Thing is as well, different apps will have different ways of measuring bandwidth. Steam might not be showing you the true speed and Origin inflating because of the way it measures BW.
Speed tests should give you the truest reflection as they're optimised better for the test than something like Steam / Origin, etc.
Paris2
PostPosted: 16:16 - 18 Jul 2016    Post subject: Reply with quote
Believe BT's own tester. And if you want an accurate result make sure you follow their guidelines which will be along the lines off disconnecting everything else and turning on the wifi (no point testing whilst someone else is streaming netflix).
Also check your ping result for each of these tests, which will give you an idea how far away the testing servers are. From memory Internet Frog tests to servers in the US, so don't rely on it for anything.
The chances are, if it doesn't appear to be any faster then the bottle neck wasn't your internet connection.
Current Ride: Daytona 600
The last post was made 10 years, 51 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 92.44 Kb
