| Bearing Puller or Punch tools |
| Pulling tool |
28% |
[ 2 ] |
| Punch tool |
71% |
[ 5 ] |
| Total Votes : 7 |
| Commuter_Tim |
 Commuter_Tim World Chat Champion
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| G |
 G The Voice of Reason
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| Nobby the Bastard |
| Islander |
 Islander World Chat Champion
 Posted: 20:24 - 08 Jul 2016 Post subject: |
You can buy long drifts quite easily.  |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 22:48 - 08 Jul 2016 Post subject: |
I use sockets from the socket set and hammer. To knock the bearings out or to seat them in. Just pick the right diameter socket, use the extender if needed and knock the bastard bearings out.
EDIT: When trying to seat a bearing in, use gentle taps, don't smash the bearing.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Nobby the Bastard |
| RhynoCZ |
 Posted: 22:55 - 08 Jul 2016 Post subject: |
Yes, I do.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| Evil Hans |
 Evil Hans World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 05:12 - 09 Jul 2016 Post subject: |
Good internal pullers work just fine. Sockets make good drifts for fitting things but they nearly always have a chamfered edge so using them for removing races that are all but flush with the seat can be very frustrating, and the same goes for fitting bearings it's easy to smash in the the shield. A drift set is a tenner on eBay:
https://r.ebay.com/Z2aGJt ____________________ a.k.a 'Geri'
| Commuter_Tim |
 Posted: 21:59 - 09 Jul 2016 Post subject: |
Cheers fellas.
Alas I'm in a house time warped to the 1950s and don't have a shower.
Think I will opt for longer punches and a drift set.
Who doesn't like whacking shit with a hammer anyway?
Blowtorches and hammers are 2 of the main reasons I enjoy working on bikes.
A brass drift has me intrigued though, surely the metal would be soft as shit compared to bearing races?  ____________________ The above post is most likely nonsensical.
I ride a Bandit 600... badly. |
| Pete. |
 Pete. Super Spammer
 Posted: 05:36 - 10 Jul 2016 Post subject: |
Brass, aluminium, copper, bronze, steel, hardened steel drifts all have their places and uses. Brass is quite soft and non-marring. Harder than copper and aluminium but softer than bronze and steel. For knocking out bearing racer I prefer a round mild steel drift with square-cut edges to catch that little bit of lip.
Quite often I'll see where people before have used a cold chisel or old screwdriver and invariably there will be damage to the seat. ____________________ a.k.a 'Geri'
| Commuter_Tim |
 Posted: 19:33 - 15 Jul 2016 Post subject: |
So bought these cheap bitches: https://www.amazon.co.uk/gp/product/B003TO2JYY/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Knocked them out with ease.
Question on fitting the new ones...
I did them in the order Haynes suggested for the rear, but the spacer couldnt be moved at all.
I very carefully drifted it back out a bit and now the spacer can be pushed sideways with a finger, but if I turn the inner race one side, the other moves too.
Is this normal or do I need to drift it back out until the other side stops moving in synch? (I can twist them independantly if I use both hands).
Haynes suggests nothing about spacer movement.
EDIT: found the answer in Bodyguards thread, you sure do get about Pete.
Unless I read your post incorrectly as long as the spacer moves sideways a bit then a bit of friction shouldn't matter? ____________________ The above post is most likely nonsensical.
| Pete. |
 Pete. Super Spammer
 Posted: 19:37 - 15 Jul 2016 Post subject: |
If both races turn together but you can slightly slide the spacer on the face of the bearing then you're ok - just put it together. If the spacer was jammed tight or loose to rattle you would want to adjust the bearing fit. ____________________ a.k.a 'Geri'
| Commuter_Tim |
 Posted: 19:40 - 15 Jul 2016 Post subject: |
Cheers again man.  ____________________ The above post is most likely nonsensical.
The last post was made 9 years, 204 days ago. Instead of replying here, would creating a new thread be more useful? |
