| Beehive Bedlam |
This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
 Beehive Bedlam World Chat Champion
 Posted: 12:54 - 14 Aug 2016 Post subject: Squeak? ***Fixed*** |
What is this squeak? It's coming from around the rear sprocket when the rear wheel is spun on the centrestand and it can be heard when wheeling the bike around the garage.
Given the last fiasco with the rear wheel it is starting to make me feel apprehensive that the bearings are going to collapse in
spectacular style. Again.
Video.
When I fitted the replacement used low mileage wheel I didn't bother to change the bearings.
There's no play in the wheel does this rule out bearings? Chain is also correctly tensioned.
One final thing the rear wheel is torqued up as per manual.
The only thing I can think of is worn cush drive rubbers?
| andym |
 andym World Chat Champion
| andym |
 Posted: 16:09 - 14 Aug 2016 Post subject: |
Why ask for help then down rate a suggestion?
A worn cushdrive would just create movement on the rear sprocket, which if you pushed your foot under the rear wheel then tried moving the sprocket you would be able to feel, or put the rear wheel back on the ground, Like this video:
https://www.youtube.com/watch?v=D03gRtDqZYs
The way you are able to turn the wheel and from the sound in the video, it sounds like the wheel is either slightly buckled and rubbing against something or isn't lined up properly and rubbing against something.
FFS you had over 50 pages of help to fix a spark plug, follow your haynes manual to the letter.... but down rate a suggestion  |
| Beehive Bedlam |
| andym |
 Posted: 17:39 - 14 Aug 2016 Post subject: |
So you decided you already knew what the problem was with you bike before you made the post?
I have been around here a while and picked up a lot of useful advice, I've learned by my mistakes on more than 1 of my bikes, (emphasis on learned), throughout my biking years I've come across most problems.... including the rear wheel rubbing against the frame, I've also had a bit of movement in the cush drive..... guess which one sounded closest to your video  |
| MCN |
 MCN Super Spammer
 Posted: 18:24 - 14 Aug 2016 Post subject: |
Maybe OP make him too much Fuck Knuckle.
 ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Beehive Bedlam |
This post is not being displayed because it has a low rating (Boring). Unhide this post / all posts.
 Posted: 19:03 - 14 Aug 2016 Post subject: |
I've just checked tyre (standard size) isn't rubbing on the frame/hugger.
Wheel is perfectly aligned.
Next.
To reiterate the rear wheel has developed a squeak like a creaky door hinge out of the blue. I'm completely flummoxed the squeak is coming from around the rear sprocket. |
| recman |
 recman World Chat Champion
| andym |
| Beehive Bedlam |
| recman |
| Beehive Bedlam |
| recman |
 ..... Quote Me Happy
| Beehive Bedlam |
| recman |
| Beehive Bedlam |
| Skudd |
 Skudd Super Spammer
| wr6133 |
 wr6133 World Chat Champion
| wristjob |
 wristjob World Chat Champion
| P.addy |
 P.addy Red Rocket
| recman |
| Wonko The Sane |
 Wonko The Sane World Chat Champion
| Suntan Sid |
| Beehive Bedlam |
The last post was made 10 years, 75 days ago. Instead of replying here, would creating a new thread be more useful? |
