Squeak? ***Fixed***
Beehive Bedlam This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
andym
PostPosted: 13:30 - 14 Aug 2016    Post subject: Reply with quote
Sounds like the tyre is fouling somewhere
andym
PostPosted: 16:09 - 14 Aug 2016    Post subject: Reply with quote
Why ask for help then down rate a suggestion?
A worn cushdrive would just create movement on the rear sprocket, which if you pushed your foot under the rear wheel then tried moving the sprocket you would be able to feel, or put the rear wheel back on the ground, Like this video:
https://www.youtube.com/watch?v=D03gRtDqZYs
The way you are able to turn the wheel and from the sound in the video, it sounds like the wheel is either slightly buckled and rubbing against something or isn't lined up properly and rubbing against something.
FFS you had over 50 pages of help to fix a spark plug, follow your haynes manual to the letter.... but down rate a suggestion Confused
andym
PostPosted: 17:39 - 14 Aug 2016    Post subject: Reply with quote
So you decided you already knew what the problem was with you bike before you made the post?
I have been around here a while and picked up a lot of useful advice, I've learned by my mistakes on more than 1 of my bikes, (emphasis on learned), throughout my biking years I've come across most problems.... including the rear wheel rubbing against the frame, I've also had a bit of movement in the cush drive..... guess which one sounded closest to your video Rolling Eyes
MCN
PostPosted: 18:24 - 14 Aug 2016    Post subject: Reply with quote
Maybe OP make him too much Fuck Knuckle.
Karma
Beehive Bedlam This post is not being displayed because it has a low rating (Boring). Unhide this post / all posts.
recman
PostPosted: 19:10 - 14 Aug 2016    Post subject: Reply with quote
Got anything stuck or wedged in around the caliper?
andym
PostPosted: 19:14 - 14 Aug 2016    Post subject: Reply with quote
OK I will say this as politely as possible, but know it will still be down rated anyway..... but:
Have you tried spraying a little WD40 on the dust seal (where it touches the axle) on that side?
recman
PostPosted: 19:26 - 14 Aug 2016    Post subject: Reply with quote
Socket wrote:
That would be obvious. Rolling Eyes
Lol what a twit that is going to make me giggle myself to sleep tonight.
I'll try that when I next go out to the garage.
You really are a total wanker. Buy a proper reliable bike you prick. Middle Finger
recman
PostPosted: 19:34 - 14 Aug 2016    Post subject: Reply with quote
I bet that was the look on the last owner's face when you rode off.
Quote Me Happy
PostPosted: 19:38 - 14 Aug 2016    Post subject: Reply with quote
Can everyone just stop trying to help this pleb? All he gives out in return is insults and abuse.
recman
PostPosted: 19:48 - 14 Aug 2016    Post subject: Reply with quote
Socket wrote:
If you want to go down that road... Rolling Eyes
I rode off on the bike let me thing must be around 30000 miles ago now.
It's called wear and tear you twit though you probably wouldn't know being a weekend warrior.
That shit heap has been fucked from the start.
So what is it that's worn and torn this time? Rolling Eyes
And do change the record.
Skudd
PostPosted: 20:18 - 14 Aug 2016    Post subject: Reply with quote
It does sound like something rubbing.
I would take the wheel off, lube everything, then put back together again.
wr6133
PostPosted: 20:20 - 14 Aug 2016    Post subject: Re: Squeak? Reply with quote
Socket wrote:
What is this squeak?
Hopefully it's the fault that tosses you down the road, headfirst in to a tree at 120mph.
wristjob
PostPosted: 20:29 - 14 Aug 2016    Post subject: Reply with quote
untill op learns that video is supposed to be in landscape not portrait i will continue to hold him in the contempt he has earned.
PostPosted: 20:45 - 14 Aug 2016    Post subject: Reply with quote
Unbolt the rear calliper and move it out the way. Give it another spin.
recman
PostPosted: 21:12 - 14 Aug 2016    Post subject: Reply with quote
And I'd trust you to take the wheel off, lube everything then put it back together again.
This may be on a par with the spark plug.
Wonko The Sane
PostPosted: 22:02 - 14 Aug 2016    Post subject: Reply with quote
I was going to suggest similar,
You might have looked and checked it's not rubbing, but might as well eliminate it from the equation.
Suntan Sid
PostPosted: 22:17 - 14 Aug 2016    Post subject: Reply with quote
Socket wrote:
Why do people get all butthurt when one uses the karma system as intended?
If the karma system had been used properly you'd have been banned a long time ago! Rolling Eyes
The last post was made 10 years, 79 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 130.48 Kb
