TightVNC?
mudcow007
PostPosted: 11:04 - 18 Aug 2016    Post subject: TightVNC? Reply with quote
Anyone use TightVNC on here?
Just rolled it out across all clients (about 100 or so) Win7 clients are fine - after I created a rule for the F/W within ePO.
Win10 refuses to allow connection.
been onto a client an the VNCServer all looks happy an is set to allow connections
grr
Ive tried both normal viewer an java flavour too.
PostPosted: 11:25 - 18 Aug 2016    Post subject: Reply with quote
nmap and see if its actually listening.
Pjay
PostPosted: 11:27 - 18 Aug 2016    Post subject: Reply with quote
Port 5900 open?
PostPosted: 11:38 - 18 Aug 2016    Post subject: Reply with quote
Indeed, unsure if it affects win10, but VNC should always have a password...
TCP 5900 should be open, you can download Zenmap to find out and run nmap -T4 -Pn IPADDRESS where IPADDRESS is the IP you want to connect to. This will list all ports that are open on the device.
UnknownStuntm...
PostPosted: 11:48 - 18 Aug 2016    Post subject: Reply with quote
Careful running nmap though, don't let it go on a whole subnet, you'll have your switches in a broadcast storm before you can say "I never actually read the manual". Ask me how I know.
PostPosted: 11:53 - 18 Aug 2016    Post subject: Reply with quote
I regularly run it for large networks, probably /20 sized. Only requesting 1 single port though and haven't had any issues. Thumbs Up
CaNsA
PostPosted: 12:10 - 18 Aug 2016    Post subject: Reply with quote
Have a gander.
https://flummox-engineering.blogspot.com/2015/08/making-vnc-work-in-windows-10.html
mudcow007
PostPosted: 12:14 - 18 Aug 2016    Post subject: Reply with quote
cheers Paddy
it seems the port isnt open.
very odd.
the plot deepens
Pjay
PostPosted: 12:15 - 18 Aug 2016    Post subject: Reply with quote
mudcow007 wrote:
cheers Paddy
very odd.
the plot deepens
You're welcome.
mudcow007
PostPosted: 12:50 - 18 Aug 2016    Post subject: Reply with quote
Pjay wrote:
mudcow007 wrote:
cheers Paddy
very odd.
the plot deepens
You're welcome.
Ha sorry, thanks also Cool
Loui5D
PostPosted: 13:02 - 18 Aug 2016    Post subject: Reply with quote
Used to have problems with interactive desktop services as well if i remember correctly.
mudcow007
PostPosted: 13:30 - 18 Aug 2016    Post subject: Reply with quote
plot deepens further.
Windows firewall is off
Mcafee ePO firewall is on - i added the rule to open the port this morning, but its still closed.
Contacted Mcafee who have confirmed all looks good (firewall config) but i still cant access the port
As far as im aware there is no way of finding out if the clients have downloaded the new policies from the ePO.
grr
PostPosted: 13:47 - 18 Aug 2016    Post subject: Reply with quote
Go to client, check its installed.
If not, that is why 5900 is closed.
Can you even use zenmap to check a single IP and see if ANY ports are showing.
Loui5D
PostPosted: 13:55 - 18 Aug 2016    Post subject: Reply with quote
telnet on that port?
mudcow007
PostPosted: 14:07 - 18 Aug 2016    Post subject: Reply with quote
Yap, scanned 4 times now, always the same result
using cmd "namp -p 1-65535 -T4 -A -v IP"
135
139
8081
thats it
Also Telnet fails..
Application (TightVNC) is installed on client - I used PDQ deploy an have manually confirmed its been rolled out successfully.
back to Mcafee I go
PostPosted: 14:12 - 18 Aug 2016    Post subject: Reply with quote
135
139
8081
thats it
Also Telnet fails..
back to Mcafee I go
That is gonna be long... just use nmap -T4 -Pn ipaddress
It may be firewall...
Pjay wrote:
mudcow007 wrote:
cheers Paddy
You're welcome.
https://secret-identity.net/images/2008/images/Vic_Bob_Handbags.jpg
You snoozed, you loozed.
On the Win10 machines, ALT+R Arrow resmon Arrow Network Arrow sort by port. Is 5900 even listening?
mudcow007
PostPosted: 14:36 - 18 Aug 2016    Post subject: Reply with quote
Resmon confirms its listening on 5800 + 5900 with a firewall status of allowed an unrestricted
PostPosted: 14:42 - 18 Aug 2016    Post subject: Reply with quote
So its FW is off and allowing, last port is local installed software FW, likely your McAfee pile of dong. Disable it all and see if it works.
PostPosted: 14:46 - 18 Aug 2016    Post subject: Reply with quote
Shenanigans on that. Wireshark time.
mudcow007
PostPosted: 14:48 - 18 Aug 2016    Post subject: Reply with quote
Just lodged another support call to Mc-a-shaft
will update with results
mudcow007
PostPosted: 14:53 - 18 Aug 2016    Post subject: Reply with quote
Its definitely Mcafee
Disabled all services and I'm in like Flynn
now its figuring out what blocked me
Pjay
PostPosted: 15:33 - 18 Aug 2016    Post subject: Reply with quote
I had the very same problem, McAfee sees VNC as a threat. It was a while back so I forgot the exact fix, but it was down to telling McAfee to stop being a dick and leave VNC alone and then uninstalling vnc and reinstalling it.
PostPosted: 15:45 - 18 Aug 2016    Post subject: Reply with quote
Now that I think about it, tightvnc.com briefly got flagged by the ZScaler netcops as a malware site. Rolling Eyes
The last post was made 10 years, 27 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 120.18 Kb
