What is a decent lithium-Ion Battery?
bandit1990
PostPosted: 15:54 - 19 Aug 2016    Post subject: What is a decent lithium-Ion Battery? Reply with quote
I'm after one because by current battery is pretty shabby and it's also really heavy for what it is. I'm seeing SkyRich, Shido and SPS as the main contenders.
I know the weight difference won't be massive between them but can anyone recommend one?
PostPosted: 15:56 - 19 Aug 2016    Post subject: Reply with quote
Varta, Yuasa or Motobatt.
rcbikeracer
PostPosted: 16:09 - 19 Aug 2016    Post subject: Reply with quote
I'm thinking of getting this for my Skorpion
https://www.ebay.co.uk/itm/272185478085?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
tom_e
PostPosted: 16:14 - 19 Aug 2016    Post subject: Reply with quote
mpd72 wrote:
Can standard lead acid batteries just be replaced with Li-ion then?
I thought the charging might be different.
I ran a 4ah 14.8V NiMh pack on my total loss ignition race bike, but that needed it's own charger.
Yes, but if you use an external charger you need to make sure it can handle Li ion or you may come back to a rather sad looking burnt out frame.
wots
PostPosted: 16:18 - 19 Aug 2016    Post subject: Reply with quote
All three of my main bikes have one. From a 125 MSX with a high compression overbore (extra cranking needed) to a fireblade. With a selection of 3 and choices based on weather etc. a bike can be sat unused for 2-3 weeks.
Jump on and go, on all of them, no problem. Two of them have data tool alarms.
wots
PostPosted: 18:04 - 19 Aug 2016    Post subject: Reply with quote
Socket wrote:
I wouldn't care (unless track bike) about how heavy the battery was. You're just throwing money away replacing a battery assuming it still works for the sake of it.
None of mine are for weight saving, they tend not to drain and also have better cranking abilities. They don't perform as well in the cold, but that is a known issue with Lithium batteries.
Having said that, the weight difference is significant. I get 10 mph more top end on MSX legit! Rolling Eyes
PostPosted: 19:35 - 19 Aug 2016    Post subject: Reply with quote
Most modern battery chargers have a similar cut offs to a bike's own charging system.
In fact, wouldn't be surprised if they're often more consistent possibly without some higher peaks.
Pigeon
PostPosted: 20:58 - 19 Aug 2016    Post subject: Reply with quote
OK, that is impressive!
kramdra
PostPosted: 00:36 - 20 Aug 2016    Post subject: Reply with quote
Seen quite a few li battery reviews showing the insides. I am *not* convinced any brand has charging done properly/safely, but li-fe cells almost make that redundant.
Seems a bit silly when a 25 quid motobatt will last 5 years
temeluchus
PostPosted: 02:04 - 20 Aug 2016    Post subject: Reply with quote
I have a JMT lithium in the GSXR and it works great.
PostPosted: 07:06 - 20 Aug 2016    Post subject: Reply with quote
I have a Shido in my R1, it's great. Weight saving is huge, cranking amps are good. Happy days. It's been in there for 9 months with no issues.
c-m
PostPosted: 18:26 - 20 Aug 2016    Post subject: Reply with quote
The Shido ones appear to be pretty good. I know of one person using a 4ah one on a KTM 950 adventure. Reports are good so far.
jjdugen
PostPosted: 21:53 - 20 Aug 2016    Post subject: Reply with quote
Lipo is a bit on the dodgy side, especially with the raw nature of a motorcycle charging system. The safer bet is Metal Hydroxide cells. Same kind of charging parameters as lead acid, safe disposal (non toxic), just as powerful and light as Lipo and cheaper. Guess what I use....
PostPosted: 14:05 - 21 Aug 2016    Post subject: Reply with quote
Just been reading up a bit - there is an issue with chargers.
What you have to be careful of is a fancy charger with a de-sulficiation mode that has high voltage spikes not all do, but some do so it's worth checking.
It should be ok if the battery is just kept on the 'trickle' function, but certainly worth being careful.
wots
PostPosted: 21:11 - 21 Aug 2016    Post subject: Reply with quote
If you actually NEED to charge a Lithium battery. You are doing it wrong or your bike has a serious current draw when not running.
PostPosted: 21:17 - 21 Aug 2016    Post subject: Reply with quote
When left for extended periods (over winter say) with alarms, some bikes do.
While you can discharge a lithium battery to around 80% rather than the 50% recommendation for lead acid, typically they'll have a lower amp hour rating as they provide high amps per amphour.
(I've got one that'll do around 500A from 4.2Ah - while you're usually talking about 200A from 12Ah for lead acid I believe.)
If a battery is kept topped up on a trickle charger, it still shouldn't be an issue - but seen at least one report where that's caused issues.
wots
PostPosted: 22:17 - 03 Dec 2016    Post subject: Reply with quote
As a follow-up.
Fireblade has been in the garage for two months, with the alarm armed, went to it this morning and it started first go.
PostPosted: 22:20 - 03 Dec 2016    Post subject: Reply with quote
Went to charge one of my JMT batteries and checked - it's a LifePo4 so less likely to blow up and should last longer than Lipo.
Also has similar maximum charging voltage to a lead acid battery.
wots
PostPosted: 22:22 - 03 Dec 2016    Post subject: Reply with quote
All mine are the JMT models, literally can't fault them. My MSX struggled when it was -4 the other day, high compression and low temperature is hard going. But 3 or 4 short bursts and off it goes.
Hong Kong Phooey
PostPosted: 23:51 - 03 Dec 2016    Post subject: Reply with quote
I sourced a JMT for the cbr, went a touch higher on the capacity. Been great even in this cold weather fires up strong on the button. 2 kg lighter doesn't do any harm.
mentalboy
PostPosted: 04:26 - 04 Dec 2016    Post subject: Reply with quote
Prior to emigrating the bike was spending three months at a time spent sat in the garage. I bought a Motobatt specifically because the usually reliable chappie, at my independent outlet, said it'd hold a charge no problem for that length of time and not need to sit on a maintenance charger.
Being a sceptical sort, I stored the new battery in the house so that it wouldn't have a chilly winter in the garage - and no chance of unexpected electrical gremlins from the bike causing issues - installed it in the beast upon my return and it was flat as a pancake.
So much for no loss, never had that issue with my Makita L-ion batteries and they sat for much longer periods...
...That battery was a complete pain in the arse whenever left stood, probably not helped by my redneck charging system utilising a very low amperage phone charger!!!
Eventually found time to have a bit of a gripe at the shop where I bought it and get a new one, mostly because I didn't fancy getting stuck in London when I had to go there for the required immigrant medical (bloody rip off that medical was but that's another story) ... chappie said 'well, you have had it three years'!!!
TLDR: Think I bought a duffer Motobatt, rigged up my own iffy charging system and still got three years out of the battery!
Make mine a Corona.
The last post was made 9 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.81 - MySQL Queries: 13 - Page Size: 119.65 Kb
