| DRZ4Hunned |
 DRZ4Hunned World Chat Champion
 Posted: 13:02 - 21 Aug 2016 Post subject: Can any electricians check out my shed wiring? |
Following on from this thread: https://www.bikechatforums.com/viewtopic.php?t=313954&highlight=
I've attempted to wire up my shed with four double sockets in a radial circuit, but it doesn't seem to work...
The power is fed from a 13A plug from the house which runs through flex cable into the consumer unit and I've wired the consumer unit as such:
https://i.imgur.com/dWLgcsw.jpg
I've used my multimeter to do a continuity test from the plug to the MCBs to check that it's all kosher, everything seems fine apart from the live.
How does the live get from the RCD on the right to the fuses on the left? Is it through the buzz bar at the bottom?
Anything stupid that I've missed here?
(The incoming blue flex is only like that for test purposes, route it properly when it works) ____________________ DRZ400-SM
FZS600 |
| WD Forte |
 WD Forte World Chat Champion
| DRZ4Hunned |
 Posted: 14:32 - 21 Aug 2016 Post subject: |
Thanks for the info, I've done continuity tests between clamps of the MCBs (top to bottom) and it appears the only one that's not getting continuity is the one second from the right (with the yellow test button).
So I guess that's my problem! I'll get a new one ordered (even though this is a new one... )
I've checked that the sockets work by bypassing the consumer unit and wiring the first socket in the circuit straight into the 13A lead and they all work, so it's definitely a fault with the MCBs. ____________________ DRZ400-SM
FZS600 |
| wristjob |
 wristjob World Chat Champion
| DRZ4Hunned |
| wristjob |
| DRZ4Hunned |
| wristjob |
| DRZ4Hunned |
| bugeye_bob |
| DRZ4Hunned |
| 331X2 |
 331X2 Crazy Courier
 Posted: 22:28 - 21 Aug 2016 Post subject: |
Have you fitted the bus bar?
Edit: I see you have now I've read the posts! You need it in the live outgoing of the RCD and the bottom of the breakers, make sure you've got hold of it properly with the terminals as it's easy to have the finger of the bar fall behind the terminal as it closes up.
One test lead on earth, meter on VAC and follow it from top of RCD where it comes in, bottom of RCD, bottom of mcb, top of mcb. Post up where you stop getting voltage and it'll be easier to diagnose.
Edit 2: double the single core cable over where it's terminated by screw and sleeve the CPC you rough bastard [/list] |
| drzsta |
 drzsta World Chat Champion
| DRZ4Hunned |
| DRZ4Hunned |
| WD Forte |
| drzsta |
| syl |
 syl World Chat Champion
 Posted: 19:32 - 23 Aug 2016 Post subject: |
You should really get someone in to do it if you're not sure. Just google wiring up a CU. This diagram (with one MCB missing so you can see the bar - it shouldn't stick out like that [the ?]) gives you a bit of an idea. If you've got the bar in yours, you look pretty good (but messy as above).
https://i62.tinypic.com/k4jwwn.jpg ____________________ Current bike: Kawasaki Z750S |
| DRZ4Hunned |
| lihp |
 lihp World Chat Champion
| DRZ4Hunned |
| RichardCraniu... |
 RichardCraniu... Nova Slayer
The last post was made 9 years, 326 days ago. Instead of replying here, would creating a new thread be more useful? |
