Can any electricians check out my shed wiring?
DRZ4Hunned
PostPosted: 13:02 - 21 Aug 2016    Post subject: Can any electricians check out my shed wiring? Reply with quote
Following on from this thread: https://www.bikechatforums.com/viewtopic.php?t=313954&highlight=
I've attempted to wire up my shed with four double sockets in a radial circuit, but it doesn't seem to work...
The power is fed from a 13A plug from the house which runs through flex cable into the consumer unit and I've wired the consumer unit as such:
https://i.imgur.com/dWLgcsw.jpg
I've used my multimeter to do a continuity test from the plug to the MCBs to check that it's all kosher, everything seems fine apart from the live.
How does the live get from the RCD on the right to the fuses on the left? Is it through the buzz bar at the bottom?
Anything stupid that I've missed here? Embarassed
(The incoming blue flex is only like that for test purposes, route it properly when it works)
DRZ400-SM
FZS600
WD Forte
PostPosted: 14:15 - 21 Aug 2016    Post subject: Reply with quote
They're not fuses they're breakers/MCBs
forget them for a minute
I would disconnect the blue cable from the mains
and get the meter out set to continuity or low resistance
then with the main switch in the on (UP) position do a continuity test between
top left and bottom left and top right bottom right clamp screws
ie 1 to 2 and N to N
there should be continuity across them
No?
bad main switch, get another
yes?
check bus bar connections are good sound and tight
and they have continity between 2 ( bottom left) on the main switch
and the corresponding screws (bottom) of the mcbs
NO? refit and check again
OK?
Now with the mcbs in the ON ( up) position do a continuity test across them
flip them few times for hell of it if you like
No? bad MCBs
OK?
It should all work now
Also check you're clamping the conductor wires not the insulation
when fitting cables to the RCD MCB terminals
A bit of green/yellow sleeving on the earth wires wouldn't hurt
and be good practise
Take your time and work safe
check it's all tickety boo before powering up the mains
HTH
bikers smell of wee
DRZ4Hunned
PostPosted: 14:32 - 21 Aug 2016    Post subject: Reply with quote
Thanks for the info, I've done continuity tests between clamps of the MCBs (top to bottom) and it appears the only one that's not getting continuity is the one second from the right (with the yellow test button).
So I guess that's my problem! I'll get a new one ordered (even though this is a new one... Mad )
I've checked that the sockets work by bypassing the consumer unit and wiring the first socket in the circuit straight into the 13A lead and they all work, so it's definitely a fault with the MCBs.
DRZ400-SM
FZS600
wristjob
PostPosted: 17:14 - 21 Aug 2016    Post subject: Reply with quote
the 2 brown wires appear to be connected to seperate breakers and nothing else
blue goes through breaker on right
brown is connected on the top but nothing on the lower terminal
DRZ4Hunned
PostPosted: 17:19 - 21 Aug 2016    Post subject: Reply with quote
I think the two breakers are connect via the buzz bar at the bottom? (you can only just see it at the bottom of the two MCBs in the picture). Unless that isn't for the live?
DRZ400-SM
FZS600
wristjob
PostPosted: 17:26 - 21 Aug 2016    Post subject: Reply with quote
op has lower bar connected as earth
diagram on breaker shows it connects top terminals to lower terminals
neutral is ok on right hand breaker
live is connected to nothing
DRZ4Hunned
PostPosted: 17:40 - 21 Aug 2016    Post subject: Reply with quote
I have a similar setup to this:
https://www.needselectricalonline.com/%5Cimages%5Cproduct%5Cextralarge%5C20110615131959Europa%20GRG32E%20open.jpg
With the brown buzz bar at the bottom that connects all the breakers, which you can't really see on my picture. So surely that connects the lives?
DRZ400-SM
FZS600
wristjob
PostPosted: 18:00 - 21 Aug 2016    Post subject: Reply with quote
with that picture it makes more sense.
is the blue flex the incoming feed?
DRZ4Hunned
PostPosted: 18:04 - 21 Aug 2016    Post subject: Reply with quote
Yeah the blue's the feed (13A plug on the other end)
DRZ400-SM
FZS600
bugeye_bob
PostPosted: 18:10 - 21 Aug 2016    Post subject: Reply with quote
have you checked the fuse in your lead ?
when plugged in doe the RCD test button cause the rcd to trip,
if not you have no supply coming in . . .
DRZ4Hunned
PostPosted: 18:45 - 21 Aug 2016    Post subject: Reply with quote
Yeah the lead's fine, I've currently got it plugged into the sockets and they're working, so it's the RCD which seems to be faulty from my continuity checks.
DRZ400-SM
FZS600
331X2
PostPosted: 22:28 - 21 Aug 2016    Post subject: Reply with quote
Have you fitted the bus bar?
Edit: I see you have now I've read the posts! You need it in the live outgoing of the RCD and the bottom of the breakers, make sure you've got hold of it properly with the terminals as it's easy to have the finger of the bar fall behind the terminal as it closes up.
One test lead on earth, meter on VAC and follow it from top of RCD where it comes in, bottom of RCD, bottom of mcb, top of mcb. Post up where you stop getting voltage and it'll be easier to diagnose.
Edit 2: double the single core cable over where it's terminated by screw and sleeve the CPC you rough bastard Mr. Green [/list]
drzsta
PostPosted: 22:39 - 21 Aug 2016    Post subject: Reply with quote
Why have you even bothered with a CU connected from a plug anyway? Even if you house has a 15th/16th edition board it will have RCD protected socket ccts. You have no discrimination and its a waste of money IMO.
DRZ4Hunned
PostPosted: 23:37 - 21 Aug 2016    Post subject: Reply with quote
To be honest I initially had no idea what I was doing, the most sparky thing I've done before is wire a plug, so this is all new to me.
At least with this setup I can install SWA and have it connected to the house CU in the future.
DRZ400-SM
FZS600
DRZ4Hunned
PostPosted: 23:41 - 21 Aug 2016    Post subject: Reply with quote
Knew I'd get shamed by a sparky... Embarassed It'll all be tidied up when I get it working. Smile
I've already done those tests to check the MCBs/RCD and the RCD doesn't appear to be working, contacted the seller and he's sending me another out.
DRZ400-SM
FZS600
WD Forte
PostPosted: 01:04 - 22 Aug 2016    Post subject: Reply with quote
The point is, if the garage/shed circuit develops a fault
the RCD in the small CU shuts off the power locally
This means 'er indoors can watch Corrie without interruptions
if the OP decides to chew through the cable.
Fitting these boxes is standard practise in sheds, garages and caravans
bikers smell of wee
drzsta
PostPosted: 07:58 - 22 Aug 2016    Post subject: Reply with quote
Laughing good idea, but when you have a 30ma RCD in the shed and in the house It's anyone's guess which will trip first. Defeats the point.
syl
PostPosted: 19:32 - 23 Aug 2016    Post subject: Reply with quote
You should really get someone in to do it if you're not sure. Just google wiring up a CU. This diagram (with one MCB missing so you can see the bar - it shouldn't stick out like that [the ?]) gives you a bit of an idea. If you've got the bar in yours, you look pretty good (but messy as above).
https://i62.tinypic.com/k4jwwn.jpg
Current bike: Kawasaki Z750S
DRZ4Hunned
PostPosted: 20:00 - 23 Aug 2016    Post subject: Reply with quote
Yeah I used that picture to wire mine, but it didn't work...
I'm getting sent a new RCD next week as mine appears to be faulty so I'll let you know if it fixes it or not Smile
I really hate paying for work to be done when I can do it myself, what's the worse that can happen, a fuse in a plug blow?
DRZ400-SM
FZS600
lihp
PostPosted: 20:07 - 23 Aug 2016    Post subject: Reply with quote
Your wiring by the way is disgusting and borderline dangerous.
No earth covering Also, you need to switch those MCB's around, the highest rated should be closest to the the main incoming RCD.
By the standard of that wiring, I'd recommend you get a spark in.
DRZ4Hunned
PostPosted: 20:51 - 23 Aug 2016    Post subject: Reply with quote
You obviously haven't read my previous posts Laughing
But thank you for your advice about the position of the MCBs, I'll swap them over. Thumbs Up
DRZ400-SM
FZS600
RichardCraniu...
PostPosted: 21:26 - 23 Aug 2016    Post subject: Reply with quote
I've seen much worse wiring by sparkies, don't worry
ZX6R 636
The last post was made 9 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.91 - MySQL Queries: 13 - Page Size: 115.6 Kb
