cleaning brake pistons - how?
Wonko The Sane
PostPosted: 23:14 - 21 Aug 2016    Post subject: cleaning brake pistons - how? Reply with quote
So, I've always struggled with cleaning the pistons in the calliper and there are four of the buggers in each of the front ones.
I can get the side with easy access but struggle to get the sides where they're close to the calliper body.
Any tricks anyone would like to share?
PostPosted: 23:25 - 21 Aug 2016    Post subject: Reply with quote
Cut a strip of cloth about 1" wide and 12" long. Soak it in wd40, fold in half so it's 1/2" wide, feed it around the piston so the folded edge is closest the caliper body and pull the ends around so you get a full wrap around. Use a see-saw motion to scrub the dirt off the piston.
The stitched edge of an old pillow/bedsheet/tee-shirt case works well for it and you don't need to fold it.
RhynoCZ
PostPosted: 23:38 - 21 Aug 2016    Post subject: Reply with quote
I wouldn't use wd40 as there is a slight chance it will swell your seals. Use a chain cleaner instead (a brake cleaner, if you have it, would be the best).
Also, you may rotate the pots in the caliper. Thumbs Up
PostPosted: 23:43 - 21 Aug 2016    Post subject: Reply with quote
WD40 works just great. If you're worried use a dribble of brake fluid.
andym
PostPosted: 00:00 - 22 Aug 2016    Post subject: Reply with quote
Probably have loads disagree with my method, but it's worked for me.
Get some white spirit and a toothbrush and scrub what you can, give the lever a couple of presses (since they are off the bike anyway), and repeat, then get a can of brake cleaner and go nuts with the whole can.
If there's a bit of rust then some fine sand paper and pumping them out to almost maximum, then try cleaning the rust off. If you've let your pistons get to that stage of corrosion then it would probably be better to remove them and clean them all with some 1500 wet and dry
kramdra
PostPosted: 01:31 - 22 Aug 2016    Post subject: Reply with quote
The proper way is always split the calliper and remove the pistons. Extra effort to drain and refill but its only 10 mins or so. And it lets you get the crap out of seal groves.
But today I was lazy, cleaned them in place. I use kitchen roll. cut/rip a 10mm strip either half or whole sheet long. Spray it in brake cleaner and floss the piston with it. Dont let the strip get too dirty or dry, keep replacing it. When you cant see any dirt, you are now half way.. as this has pushed lose dirt upto the dust seal - pushing the pistons back now would be bad.
So you pull brake lever, using fingers to let pistons out evenly another 2mm. There will be a visible line of solid dirt, clean this off and your done. Give pistons quick polish with more brake cleaner/tissue before pushing back in and refit pads.
This is a far easier, nicer, quicker job if you have anodised alu pistons, the brake dust doesn't stick too much and there's no rust.
mentalboy
PostPosted: 01:45 - 22 Aug 2016    Post subject: Reply with quote
If you have alloy pistons (which, I seem to remember, Zed's do) then any problems with sticky pistons is going to be because the seal groove is full of crud and makes cleaning a well meant but probably futile exercise, possibly even driving dirt under the dust seal if you are not careful.
Make mine a Corona.
kramdra
PostPosted: 07:58 - 22 Aug 2016    Post subject: Reply with quote
Not so, there was no corrosion last time. The annodised finish on the pistons and calliper is excellent.
PostPosted: 08:14 - 22 Aug 2016    Post subject: Reply with quote
Cable tie your strip of cloth onto the piston. If you do it tight enough that the piston rotates, well, problem also solved.
PostPosted: 18:11 - 22 Aug 2016    Post subject: Reply with quote
My method.
Clean exterior of caliper.
Remove caliper.
https://i104.photobucket.com/albums/m174/howlingterror_2006/DSCF1814_zpsb25d2289.jpg
Carefully pump out each piston, sometimes use a wooden wedge to hold the others in place( see it in the background.
https://i104.photobucket.com/albums/m174/howlingterror_2006/DSCF1807_zps1c9b0a87.jpg
Floss piston,
https://i104.photobucket.com/albums/m174/howlingterror_2006/DSCF1811_zpsc2c9b8a8.jpg
Light smear of red rubber grease and push in.
https://i104.photobucket.com/albums/m174/howlingterror_2006/DSCF1810_zps89bc5ce7.jpg
Sometimes they need a little persuasion with some pipe holders.
https://i104.photobucket.com/albums/m174/howlingterror_2006/DSCF1808_zpse6d9f016.jpg
A short length of gardener's wire or a bungee cord from the caliper to somewhere on the bike takes the strain off the brake line if I need to let go of the caliper during cleaning.
DRZ4Hunned
PostPosted: 19:48 - 22 Aug 2016    Post subject: Reply with quote
I've literally just done this, I used a toothbrush and some warm soapy water.
I was going to use WD40 but then remembered that it doesn't go with rubber, so used that instead.
Not seen that cloth idea before, I'll try that next time.
DRZ400-SM
FZS600
Itchy
PostPosted: 19:56 - 22 Aug 2016    Post subject: Reply with quote
Pop them, as in split the calliper and take them out the body.
You can always borrow my pistol removal tool. Heh it's been used by about 17 BCFers Very Happy
PostPosted: 20:02 - 22 Aug 2016    Post subject: Reply with quote
While WD40 might cause the seals to swell, so can brake cleaner. I know this from experience (absent mindedly left the old seals soaking in a cap of brake cleaner)
Katy
kramdra
PostPosted: 23:09 - 22 Aug 2016    Post subject: Reply with quote
Socket wrote:
I'd consider removing the calipers from the bike and giving them a full strip down at least once a year particularly coming towards the end of summer. Do it now with the light nights and a nice cold beer.
A seized piston in the middle of winter when it's cold dark and shit is a nightmare.
I dont want to waste a summer evening stripping brakes when I could be out. Much rather do it indoors on a miserable wet winter night. Only takes couple minutes to refit and bleed in the morning, last time I did it just before going to work.
Howling Terror wrote:
My method...
If you only push out once, the cleaning will push lose dirt back against the dust seal. Push out again to remove all, then they can be pushed back and should only need thumb pressure.
The last post was made 9 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 2.86 - MySQL Queries: 13 - Page Size: 91.91 Kb
