| Wonko The Sane |
 Wonko The Sane World Chat Champion
 Posted: 23:14 - 21 Aug 2016 Post subject: cleaning brake pistons - how? |
So, I've always struggled with cleaning the pistons in the calliper and there are four of the buggers in each of the front ones.
I can get the side with easy access but struggle to get the sides where they're close to the calliper body.
Any tricks anyone would like to share? ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
 Posted: 23:25 - 21 Aug 2016 Post subject: |
Cut a strip of cloth about 1" wide and 12" long. Soak it in wd40, fold in half so it's 1/2" wide, feed it around the piston so the folded edge is closest the caliper body and pull the ends around so you get a full wrap around. Use a see-saw motion to scrub the dirt off the piston.
The stitched edge of an old pillow/bedsheet/tee-shirt case works well for it and you don't need to fold it. ____________________ a.k.a 'Geri'
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 23:38 - 21 Aug 2016 Post subject: |
I wouldn't use wd40 as there is a slight chance it will swell your seals. Use a chain cleaner instead (a brake cleaner, if you have it, would be the best).
Also, you may rotate the pots in the caliper.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
 Posted: 23:43 - 21 Aug 2016 Post subject: |
WD40 works just great. If you're worried use a dribble of brake fluid. ____________________ a.k.a 'Geri'
| andym |
 andym World Chat Champion
| kramdra |
 kramdra World Chat Champion
| mentalboy |
 mentalboy World Chat Champion
| kramdra |
| Rogerborg |
 Rogerborg nimbA
 Posted: 08:14 - 22 Aug 2016 Post subject: |
Cable tie your strip of cloth onto the piston. If you do it tight enough that the piston rotates, well, problem also solved. ____________________ Biking is 1/20th as dangerous as horse riding.
| Howling TerrorOutOfOffice |
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| DRZ4Hunned |
 DRZ4Hunned World Chat Champion
| Itchy |
 Itchy Super Spammer
 Posted: 19:56 - 22 Aug 2016 Post subject: |
Pop them, as in split the calliper and take them out the body.
You can always borrow my pistol removal tool. Heh it's been used by about 17 BCFers  ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| kramdra |
The last post was made 9 years, 323 days ago. Instead of replying here, would creating a new thread be more useful? |
