| Artens |
 Artens Borekit Bruiser
| chris-red |
| lihp |
 lihp World Chat Champion
| Wonko The Sane |
 Wonko The Sane World Chat Champion
 Posted: 11:30 - 22 Aug 2016 Post subject: Re: Few engine problems. Unsure where to start. |
| Artens wrote: | Hi. I have wk 125 N . I started hearing ticking noise 100 miles before. Ticking increases when i rev. Seems like valves needs to be cleaned and refitted again . Also, on 3rd gear, when i pull the clutch in, for example if im slowing down, engine makes disgusting sound, or if i stop without clutch ( just release rev ) it looks like grinding noise. ( no noise on other gears). And, i cant exceed 50mph.. I sometimes reach 52-54.. It should do 60-70. So the questions are :
1. When i do the valve clearance, and when i clean them, do i need to change their seal? Or if it not broken can i use it again?
2. What is the problem with that sound?
3. How can i diagnose what causes it to dont exceed 50mph? |
problems could be related to each other, could be separate issues
pick the problem you can identify what the issue is, resolve that, test, next problem.
Sorry I can't offer specific advice beyond that ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 11:36 - 22 Aug 2016 Post subject: |
Help us to help you.
Can you show us a picture of your bike's engine, with any plastics removed. Chances are that it's a copy of either the Suzuki GS125 engine, or the Honda CG125. Whichever it is, you should find yourself a workshop manual for the original bike/engine and follow that for the valve clearances.
If it's the Suzuki copy, it'll have a camchain and it could be a tensioner problem. If it's the Honda then it's pushrods and you'll just have to do the locknuts on the rockers.
The grinding noise sounds like the gear selector is shagged. Again, what you do next is entirely down to what the engine is. You may find that it's cheaper and easier to buy a used engine and sling it in than to pay someone to disassemble yours.
These bike commonly lie about their top speeds. A real 55mph is about what you should expect, 60 tops. However, it's fairly likely the the first owner has dicked around with it in some way. Give it a hard ride then kill the engine, get the spark plug out, and let's see what colour it is. ____________________ Biking is 1/20th as dangerous as horse riding.
| Artens |
| Artens |
 Posted: 11:49 - 22 Aug 2016 Post subject: |
| Artens |
| Artens |
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:14 - 22 Aug 2016 Post subject: |
Huh, that's unusual. It looks like the CG copy-engine, but it's water cooled (the original CG was air cooled). It should still be a pushrod OHV engine, but I'd check for a cam chain tensioner on the back of the barrel just in case they've done something really crazy.
With the air cooled CG, adjusting the valves couldn't be simpler, following this procedure. The top cover has a re-usable rubber seal. I'd follow that guide until and unless you find any differences. ____________________ Biking is 1/20th as dangerous as horse riding.
| Artens |
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:19 - 23 Aug 2016 Post subject: |
Probably. Chattering valves means that they're not opening optimally, which will just mean a loss of performance. If they were too quiet, and not fully closing, you could be burning them out. A little clatter is better than none.
I'd be more concerned with your gearbox issues. If you do have to replace the selector shaft or cam, I'd suggest buying Honda parts (CG125 or XLR125) rather than getting soaked by WK. ____________________ Biking is 1/20th as dangerous as horse riding.
| Artens |
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:24 - 23 Aug 2016 Post subject: |
| Artens wrote: | My lexmoto arrow 125( last bike ) engine got hit through with valve since clearance wasnt done right |
Verified by yourself, or is that what a mechanic told you? If you want it done right, you do have to do it yourself. It's very simple on these copy-engines.
| Artens wrote: | Are you sure that different bike parts will fit my bike? |
I'm sure that it's not a "WK" engine. It'll be a Lifan or Qingqi or one of a dozen Chinese makes, most of which are parts-interchangeable.
I'd just suggest not paying a premium to WK for a generic part, is all. ____________________ Biking is 1/20th as dangerous as horse riding.
| Artens |
 Posted: 13:06 - 23 Aug 2016 Post subject: |
Cheers for help, i will order all the parts next week, and on september, probably 12th-15th i will update this topic to let you know how i am doing with it  |
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:18 - 23 Aug 2016 Post subject: |
What parts? You don't know what's wrong yet. ____________________ Biking is 1/20th as dangerous as horse riding.
| Robby |
 Robby Dirty Old Man
| carpe_diem |
 carpe_diem Trackday Trickster
| jjdugen |
 jjdugen World Chat Champion
| Suntan Sid |
 Posted: 19:26 - 23 Aug 2016 Post subject: |
OP, what bike is it?
It's an easily answered question! ____________________ "Everybody needs money, that's why they call it money!"  |
| Rogerborg |
 Rogerborg nimbA
 Posted: 19:30 - 23 Aug 2016 Post subject: |
It's a WK SS125N. Best of luck.
Here's an HN125-8 engine (157FMI), which I can assure you most certainly is a pushrod CG copy, vs OP's engine, which I'll take a stab at being marked as 156 or 157UMI.
https://i.imgur.com/KgEPN1u.pnghttps://i.imgur.com/e6tstso.png
Let's see what OP finds when he whips the top off, shall we? ____________________ Biking is 1/20th as dangerous as horse riding.
| Falco |
 Falco Traffic Copper
| Artens |
| Rogerborg |
 Rogerborg nimbA
 Posted: 17:24 - 24 Aug 2016 Post subject: |
Whatever you do, don't over-tighten the exhaust bolts just to see if you can get a better seal - they'll come apart faster than a Corbyn train parable. Spray some soapy water around where the exhaust enters the engine first, see if you get bubbles.
Your chain adjustment procedure will be along the lines of this.
Any markings on your swinging arm are likely to vary, and the amount of slack required, and whether to test with the bike on its side stand or not, is bike specific.
The rule of thumb is that you want some slack in the chain when you're sitting on the bike. It shouldn't be drum tight, and it shouldn't be flapping up and down or pulling away from the back of the sprocket. ____________________ Biking is 1/20th as dangerous as horse riding.
| Artens |
The last post was made 9 years, 232 days ago. Instead of replying here, would creating a new thread be more useful? |
