Wheelie Tips Needed: 1st to 2nd & Lifting it in 2nd
Az
PostPosted: 16:45 - 01 Sep 2016    Post subject: Wheelie Tips Needed: 1st to 2nd & Lifting it in 2nd Reply with quote
Started to learn how to wheelie a few weeks ago and I can now lift my Blade up in 1st from 5k rpm all the way to red line comfortably and at a decent height...
I can't lift the front wheel in 2nd or shift into 2nd while up. When I try and shift into 2nd the bike drops by the time I slot it into 2nd. Very frustrating that it's so easy to get up in 1st & hold it, but I can't lift it in 2nd.
Any tips please, i'd appreciate it massively... I know the bike's capable, it's just me who can't get it to come up.
https://i789.photobucket.com/albums/yy178/AzAndBikes/EB8DEE26-EE01-43B5-A2E7-398622DE20BE_zpss2dtluuz.png
PostPosted: 16:50 - 01 Sep 2016    Post subject: Re: Wheelie Tips Needed: 1st to 2nd & Lifting it in 2nd Reply with quote
Are you clutchless shifting?
Are you using the clutch to wheelie in second?
.Bishbash.
PostPosted: 16:55 - 01 Sep 2016    Post subject: Reply with quote
Not sure you'll be able to lift the front in 2nd without clutching it up. or the use of a small hill/bump/incline in the road.
But as G says, clutchless change to get to 2nd, should be a quick off throttle/change gear/back on the throttle.
Current bike - GSX-R1000 k8
Az
PostPosted: 17:02 - 01 Sep 2016    Post subject: Reply with quote
I've been clutching it up in 1st and trying to clutch it up in 2nd.
I've not been clutchless shifting as i've always been told to not clutchless shift from 1st-2nd when riding, I assumed this applied when you're wheeling to?
.Bishbash.
PostPosted: 17:05 - 01 Sep 2016    Post subject: Reply with quote
No, you lose too much time using the clutch.
And brave man on clutch up wheelies in 1st when you're learning. Learn in 2nd pal, less risk.
PostPosted: 17:08 - 01 Sep 2016    Post subject: Reply with quote
Also; you should still be able to ride out wheelies in first as first gear is fairly tall for you.
However, it won't be as smooth and slower speed means higher balance point.
Hahadumball
PostPosted: 17:14 - 01 Sep 2016    Post subject: Reply with quote
itll go up in 2nd with no clutch
find where the power kicks in
sit back a bit
get to just before the power, roll on a little just past the power then roll off a little.. then roll on hard and pull the front up.
when youre up you have 2 things to do.
from your pic youve got about 28 miles till youre anywhere near balance point which is hard sat down...
however, sitting back and pulling higher you should be able to sit in 2nd for miles... if you can do this then youre fine to click into 3rd
or..
pull it up in 2nd as it comes up go straight into 3rd and the momentum of going up will keep you up in 3rd.
source: 120mph and landed
https://i.imgur.com/w0zdLIG.jpg
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
Az
PostPosted: 17:15 - 01 Sep 2016    Post subject: Reply with quote
I am currently riding out 1st gear, I keep it up at a good height and then it hit redlines and comes down. Will try get a video, as the only vid' I have is when I just started learning and shows me doing a terrible one lol.
So we're saying clutchles shift into 2nd? Will give it a try this weekend and see what happens.
Also any tips on how to get it to lift in 2nd?
Thanks Thumbs Up
Jayy
Mr. Ponzi
PostPosted: 17:18 - 01 Sep 2016    Post subject: Reply with quote
If you're going to shift from 1st to 2nd it needs to be timed well and seamless. If it doesn't clutchless shift well, needs to be a super fast, tiny pinch and smooth shift or you will keep flying back down to the ground.
Takes a bit of practice to get it right but once you nail it, it's easy Thumbs Up
Keep doing it and you will get it. You also need to have the bike at a fairly high level / even BP when you do it or you will fight it trying to go back down.
Took me a while to work it out at first and now... quickshifters ftw Very Happy
See from your sig it's a 954, some bikes which are heavier can be a little harder to pop up but it will do it, just need to time it and give it a bit of a hoist.
Rare I pop it in 1st gear with clutch, usually pop it in 2nd @ 70mph around 6k and then shift through the box. Pops in 3rd easily and will pop in 4th too but need to be doing about 100mph and give it a hoist.
Depends on the bike / power / etc.
Az
PostPosted: 17:20 - 01 Sep 2016    Post subject: Reply with quote
I can get it higher than the pic', the photo is a week or so old now when I'd just started learning to lift it. I'll try get a vid/photo this weekend.
Also I'd rather clutch it up, I can power it up in 1st but personally I much prefer clutching it, feels nicer and it's also a lot easier imo.
Thanks for the reply, but have you got any tips on how to clutch it up in 2nd?
Also cool pic Cool
Az
PostPosted: 17:22 - 01 Sep 2016    Post subject: Reply with quote
Okaydokie, thanks for responses.
I'll keep trying to pop it up in 2nd on clutch, but first of all i'm going to try and see if I can shift it into 2nd from 1st while up. It's all very new to me, my first wheelie was about 3 weeks ago lol.
I'll get a video up soon and you can show me where i'm going wrong Thumbs Up
Thanks all
Hahadumball
PostPosted: 17:23 - 01 Sep 2016    Post subject: Reply with quote
Also cool pic Cool
i cant give tips on clutching in 2nd or first as i just dont do it, to me it feels dangerous as hell, unless you do it a million times and know the exact engine note/rpm youre gonna come off the back.
problem i find with clutching up wheelies is the rpm will always change so you could end up damn high damn fast or barely come up and look like a dick, under power once it starts lifting keep the throttle open and itll keep going up till you say stop
Hahadumball
PostPosted: 17:24 - 01 Sep 2016    Post subject: Reply with quote
Thanks all
careful you dont overdo it going into 2nd, theres a fine line between balance point and tarmac point
ill pm a couple of my video links
PostPosted: 17:25 - 01 Sep 2016    Post subject: Reply with quote
Just use 2nd gear rather than 1st.
You should easily be able to 3rd gear on a litre.
https://youtu.be/umb4GcIIH68?t=25s
This random guy with a similar name uses 3rd at nearly a ton. You can probably do similar on yours. You can even see the revs which might help. You'll want to give it more powaaaaah though. You should be able to ride out 3rd gear, I don't have proof because I don't wheelie.
Az
PostPosted: 17:26 - 01 Sep 2016    Post subject: Reply with quote
See I disagree there, when I clutch it I know exactly how far it's going to come up based on how much throttle I give it. It feels completely controlled to & smooth.
Az
PostPosted: 17:28 - 01 Sep 2016    Post subject: Reply with quote
I've seen that video on FB somewhere too, also has a very similar name Laughing
I know the bike can, I just don't know how to make it come up in 2nd+
0l0dom0l0
PostPosted: 17:35 - 01 Sep 2016    Post subject: Reply with quote
Popping the clutch in 1st, on a blade Shocked Shocked
This man is brave.
Stick it in second and learn to clutch it up from there. It's a simple case of a bigger blip, if you get it right it should be more controlled than a 1st gear clutch up.
2nd and 3rd gear wheelies are the way forward. FZ6 will clutch up in second up to about 60mph. Won't come up in 3rd. Woudn't even want to try it in 1st. Clutchless changing from 1st to second, with the front up takes some serious practice.
When I learned to wheelie, every straight bit of road I was down into second gear clutching it, just getting a feel. The wheelies weren't big to begin with but it was getting the consistent lift on the front. Literally every opportunity.
I'd recommend if you're used to the front coming up now, doing a similar thing as above. Every bit of road, give the throttle a blip and clutch in. Make sure you're relaxed and your weight is back. Use the clocks on the horizon as a good indicator that you're about right with height. If you're looking round the clocks to see where you're going its a good wheelie.
As the speed increases it becomes easier. Think I've manged to get into 4th on the back wheel now but no balance point as of yet (although I think my longest wheelie is over 1 mile)
The same, just in 2nd.
Slow it down to 0.25 and watch the revs and left hand.
PostPosted: 17:45 - 01 Sep 2016    Post subject: Reply with quote
Can you clutchless shift when both wheels are on the ground?
It'll be easier to control clutching it up in second rather than using first. Thumbs Up
Groove
PostPosted: 19:20 - 01 Sep 2016    Post subject: Reply with quote
As below, clutch it up in at least 2nd. The gsxr comes up as easy in 3rd as it does 2nd. I don't even have to piss about with the throttle in 1st to power it up, just open it up and at about 6 k up it comes.
I learnt back on my cbr 600 with powering it up in 1st then clutching it. Since the 636 I always use 2nd for clutching and power for first...seems more control able to me.
I did however think I was in 2nd on the r1 once and clutched it up as one would normally, damn thing basically smacked me in the face as I was actually in first Laughing
Fin
PostPosted: 19:45 - 01 Sep 2016    Post subject: Reply with quote
You should try a 2 stroke with a powervalve Razz
PostPosted: 20:17 - 01 Sep 2016    Post subject: Reply with quote
A good bit easier than a revvy one with out a powervalve. Wink
(Not sure if my trials bike has a powervalve, but it's far from revvy with a way flatter delivery than most 4 strokes.)
Bozzy
PostPosted: 20:46 - 01 Sep 2016    Post subject: Reply with quote
How easy are wheelies to balance side to side? I ask as I have visions of falling sideways as I'm not able to correct the bars by turning them.
Jayy
Mr. Ponzi
PostPosted: 12:37 - 02 Sep 2016    Post subject: Reply with quote
You can steer wheelies easily by shifting your body weight to the side your want to go to ever so slightly.
0l0dom0l0
PostPosted: 12:47 - 02 Sep 2016    Post subject: Reply with quote
Can you Shocked?
Easier method to steer wheelies is to, wait for it, turn the handlebars. Really you want your weight central and inline with the bike and on a smooth clutch up, the front should stay straight anyway.
I had all sorts of issues when I first started to wheelie my FZ6 where I'd move one handlbar to the side on the clutch up and it would then mean the bike was always trying to go off straight (either left or right depending on which way the handlebars were pointing). All sorted by keeping the handlebars straight on the clutch up and and turning them to change your direction once the front wheel is up.
So to summarise, you turn the bike with the front wheel off the ground in exactly the same way as you would turn the bike with rhe front wheel off the ground. Turning the handlebars to the right means the bike will turn to the left, turning the handlebars to the left means the bike will go right.
That's one of the reasons clutching up in second and starting the wheelie at a higher speed makes the bike more balanced with the front wheel of the ground, the gyroscopic effect from the spinning front wheel wants the bike to go in a straight line. It's also why you can't steer when the front wheel stops spinning, and that's the end of wheelie for most. Unless you're at the balance point, very good and controlled in which case you can carry on.
The last post was made 10 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 134.74 Kb
