| Az |
 Az World Chat Champion
 Posted: 16:45 - 01 Sep 2016 Post subject: Wheelie Tips Needed: 1st to 2nd & Lifting it in 2nd |
Started to learn how to wheelie a few weeks ago and I can now lift my Blade up in 1st from 5k rpm all the way to red line comfortably and at a decent height...
I can't lift the front wheel in 2nd or shift into 2nd while up. When I try and shift into 2nd the bike drops by the time I slot it into 2nd. Very frustrating that it's so easy to get up in 1st & hold it, but I can't lift it in 2nd.
Any tips please, i'd appreciate it massively... I know the bike's capable, it's just me who can't get it to come up.
https://i789.photobucket.com/albums/yy178/AzAndBikes/EB8DEE26-EE01-43B5-A2E7-398622DE20BE_zpss2dtluuz.png |
| G |
 G The Voice of Reason
| .Bishbash. |
 .Bishbash. World Chat Champion
 Posted: 16:55 - 01 Sep 2016 Post subject: |
Not sure you'll be able to lift the front in 2nd without clutching it up. or the use of a small hill/bump/incline in the road.
But as G says, clutchless change to get to 2nd, should be a quick off throttle/change gear/back on the throttle. ____________________ Current bike - GSX-R1000 k8 |
| Az |
| .Bishbash. |
 Posted: 17:05 - 01 Sep 2016 Post subject: |
No, you lose too much time using the clutch.
And brave man on clutch up wheelies in 1st when you're learning. Learn in 2nd pal, less risk. ____________________ Current bike - GSX-R1000 k8
| G |
| Hahadumball |
 Hahadumball World Chat Champion
 Posted: 17:14 - 01 Sep 2016 Post subject: |
itll go up in 2nd with no clutch
find where the power kicks in
sit back a bit
get to just before the power, roll on a little just past the power then roll off a little.. then roll on hard and pull the front up.
when youre up you have 2 things to do.
from your pic youve got about 28 miles till youre anywhere near balance point which is hard sat down...
however, sitting back and pulling higher you should be able to sit in 2nd for miles... if you can do this then youre fine to click into 3rd
or..
pull it up in 2nd as it comes up go straight into 3rd and the momentum of going up will keep you up in 3rd.
source: 120mph and landed
https://i.imgur.com/w0zdLIG.jpg ____________________ Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
| Az |
| Jayy |
 Jayy Mr. Ponzi
 Posted: 17:18 - 01 Sep 2016 Post subject: |
If you're going to shift from 1st to 2nd it needs to be timed well and seamless. If it doesn't clutchless shift well, needs to be a super fast, tiny pinch and smooth shift or you will keep flying back down to the ground.
Takes a bit of practice to get it right but once you nail it, it's easy
Keep doing it and you will get it. You also need to have the bike at a fairly high level / even BP when you do it or you will fight it trying to go back down.
Took me a while to work it out at first and now... quickshifters ftw
See from your sig it's a 954, some bikes which are heavier can be a little harder to pop up but it will do it, just need to time it and give it a bit of a hoist.
Rare I pop it in 1st gear with clutch, usually pop it in 2nd @ 70mph around 6k and then shift through the box. Pops in 3rd easily and will pop in 4th too but need to be doing about 100mph and give it a hoist.
Depends on the bike / power / etc. |
| Az |
| Az |
 Posted: 17:22 - 01 Sep 2016 Post subject: |
Okaydokie, thanks for responses.
I'll keep trying to pop it up in 2nd on clutch, but first of all i'm going to try and see if I can shift it into 2nd from 1st while up. It's all very new to me, my first wheelie was about 3 weeks ago lol.
I'll get a video up soon and you can show me where i'm going wrong
Thanks all
| Hahadumball |
| Hahadumball |
 Posted: 17:24 - 01 Sep 2016 Post subject: |
| Az wrote: | Okaydokie, thanks for responses.
Thanks all |
careful you dont overdo it going into 2nd, theres a fine line between balance point and tarmac point
ill pm a couple of my video links ____________________ Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015 |
| P.addy |
 P.addy Red Rocket
 Posted: 17:25 - 01 Sep 2016 Post subject: |
Just use 2nd gear rather than 1st.
You should easily be able to 3rd gear on a litre.
https://youtu.be/umb4GcIIH68?t=25s
This random guy with a similar name uses 3rd at nearly a ton. You can probably do similar on yours. You can even see the revs which might help. You'll want to give it more powaaaaah though. You should be able to ride out 3rd gear, I don't have proof because I don't wheelie. |
| Az |
| Az |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 17:35 - 01 Sep 2016 Post subject: |
Popping the clutch in 1st, on a blade
This man is brave.
Stick it in second and learn to clutch it up from there. It's a simple case of a bigger blip, if you get it right it should be more controlled than a 1st gear clutch up.
2nd and 3rd gear wheelies are the way forward. FZ6 will clutch up in second up to about 60mph. Won't come up in 3rd. Woudn't even want to try it in 1st. Clutchless changing from 1st to second, with the front up takes some serious practice.
When I learned to wheelie, every straight bit of road I was down into second gear clutching it, just getting a feel. The wheelies weren't big to begin with but it was getting the consistent lift on the front. Literally every opportunity.
I'd recommend if you're used to the front coming up now, doing a similar thing as above. Every bit of road, give the throttle a blip and clutch in. Make sure you're relaxed and your weight is back. Use the clocks on the horizon as a good indicator that you're about right with height. If you're looking round the clocks to see where you're going its a good wheelie.
As the speed increases it becomes easier. Think I've manged to get into 4th on the back wheel now but no balance point as of yet (although I think my longest wheelie is over 1 mile) ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| P.addy |
 P.addy Red Rocket
| Ste |
 Ste Not Work Safe
 Posted: 17:45 - 01 Sep 2016 Post subject: |
Can you clutchless shift when both wheels are on the ground?
It'll be easier to control clutching it up in second rather than using first.  |
| Groove |
 Groove World Chat Champion
 Posted: 19:20 - 01 Sep 2016 Post subject: |
As below, clutch it up in at least 2nd. The gsxr comes up as easy in 3rd as it does 2nd. I don't even have to piss about with the throttle in 1st to power it up, just open it up and at about 6 k up it comes.
I learnt back on my cbr 600 with powering it up in 1st then clutching it. Since the 636 I always use 2nd for clutching and power for first...seems more control able to me.
I did however think I was in 2nd on the r1 once and clutched it up as one would normally, damn thing basically smacked me in the face as I was actually in first  ____________________ || Past: 1991 Kawasaki ZXR 250 ~ 2003 Honda CBR 600 F Sport ~ 2004 Kawasaki ZX6R B1H 636 ~ 1999 Yamaha R1 ~ 1999 Kawasaki ZX6R J ~ 2004 Kawasaki ZX6R B1H 636 ~ 1998 Honda VTR1000F Firestorm ~ K1 GSXR 600 Track bike ~ K6 GSXR 1000 ~ 2006 Speed Triple 1050 || Current: 2005 R1 https://www.adrucore.co.uk |
| Fin |
 Fin World Chat Champion
| G |
| Bozzy |
 Bozzy Traffic Copper
| Jayy |
 Jayy Mr. Ponzi
| 0l0dom0l0 |
 Posted: 12:47 - 02 Sep 2016 Post subject: |
| Jayy wrote: | | Bozzy wrote: | How easy are wheelies to balance side to side? I ask as I have visions of falling sideways as I'm not able to correct the bars by turning them. |
You can steer wheelies easily by shifting your body weight to the side your want to go to ever so slightly. |
Can you ?
Easier method to steer wheelies is to, wait for it, turn the handlebars. Really you want your weight central and inline with the bike and on a smooth clutch up, the front should stay straight anyway.
I had all sorts of issues when I first started to wheelie my FZ6 where I'd move one handlbar to the side on the clutch up and it would then mean the bike was always trying to go off straight (either left or right depending on which way the handlebars were pointing). All sorted by keeping the handlebars straight on the clutch up and and turning them to change your direction once the front wheel is up.
So to summarise, you turn the bike with the front wheel off the ground in exactly the same way as you would turn the bike with rhe front wheel off the ground. Turning the handlebars to the right means the bike will turn to the left, turning the handlebars to the left means the bike will go right.
That's one of the reasons clutching up in second and starting the wheelie at a higher speed makes the bike more balanced with the front wheel of the ground, the gyroscopic effect from the spinning front wheel wants the bike to go in a straight line. It's also why you can't steer when the front wheel stops spinning, and that's the end of wheelie for most. Unless you're at the balance point, very good and controlled in which case you can carry on. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
The last post was made 10 years, 41 days ago. Instead of replying here, would creating a new thread be more useful? |
