car question
kawashima
PostPosted: 01:34 - 03 Sep 2016    Post subject: car question Reply with quote
My 2005 toyota brevis (59000miles) is going to MOT(shaken) 2 weeks later. Toyota dealer suggested me
-timing belt change
-water pump change
plus
-cylinder head cover gasket change(oil is seen on the cover)
I am going to ask belt and pump change,
but I am wondering if I should ask gasket change too or not.
I read somewhere that changing gasket sometimes worsen oil leak.
Would you ask gasket change too? Engine looks like this now.
https://i21.photobucket.com/albums/b295/kawashima_/P1060098_zps1o4xrw0t.jpg
https://i21.photobucket.com/albums/b295/kawashima_/P1060092_zpsecff6azq.jpg
own:2020 Serow 250
iooi
PostPosted: 05:59 - 03 Sep 2016    Post subject: Re: car question Reply with quote
Clearly it leaking past the gasket. So how would not changing it make it better?
Maybe cleaning the surfaces and reseating may help. But for the cost of a new gasket, is it worth the risk of it having to go back to be replaced again if it still leaks afterwards.
c_dug
PostPosted: 06:46 - 03 Sep 2016    Post subject: Reply with quote
I've heard the Japanese MOT is one of the most strict in the world, but what exactly would it fail on?
kawashima
PostPosted: 07:35 - 03 Sep 2016    Post subject: Re: car question Reply with quote
Thanks iooi, I will ask gasket change too. I couldn't tell how not good this was.
I'm thinking of driving this car till 125k miles, so added cost is negligible Thumbs Up
Maybe what I read was the case done by dodgy method, I think genuine Toyota dealer will do it properly.
Total MOT fee estimation will be from £1500 to £1700.
If the oil is dripping under the car, it won't pass. If not dripping, it will pass by cleaning the engine surface.
own:2020 Serow 250
Pjay
PostPosted: 07:43 - 03 Sep 2016    Post subject: Reply with quote
I'm not sure that it's strict, it's just very expensive, which is why Japs export used cars so vigorously.
kawashima
PostPosted: 07:55 - 03 Sep 2016    Post subject: Reply with quote
I think UK MOT seems to be stricter than ours. And ours is expensive Sick £450 (out of £1700) is tax and liability insurance(=fixed cost for 2500cc/1.6ton car). £550 is parts cost, £700 is labour and inspection fee.
own:2020 Serow 250
PostPosted: 10:23 - 03 Sep 2016    Post subject: Reply with quote
I personally wouldn't bother changing the gasket at all. It's a very slight misting of oil when all is said and done. If it got more severe I might think about it. There is WAY more oil on and around the engine block of my work van and I don't give it a second thought.
There again, I don't much care about cars anyway.
Alpineandy
PostPosted: 12:44 - 03 Sep 2016    Post subject: Reply with quote
Why are you taking it to a dealer rather than an independent garage?
Over here the dealer rates are usually over double the price on independent garages.
The above comment isn't necessarily the truth and anyone that says it is, is only correct if it's the truth or they're bigger than me.
kawashima
PostPosted: 13:48 - 03 Sep 2016    Post subject: Reply with quote
Thanks stinkwheel, this time I decided to ask gasket too, went to the dealer and asked them to change gasket which I canceled on the phone without watching the engine yesterday.
At first I thought I may postpone gasket change till around 85k miles, but decided to do it earlier this time, cause I'm aiming to drive this car till around 125k miles which is double of present 59k miles.
I once asked independent garage doing MOT but they couldn't fix spongy brake pedal after fluid change even after 2 time retries. So I had to bring my car to Toyota dealer just after that to fix spongy brake. I had to pay nearly double.
Later I found why they couldn't fix it. Toyota Brevis has EBD(Electronic Brake Force Distribution) and need scan tool to cancel solenoid valve and change brake fluid properly. I think they didn't have scan tool. I decided not to bring my car to independent garage anymore after that. And they are not so cheap(maybe 80% of dealer here). Maybe the garage I brought my car was the worst one, there may be better independent garage somewhere, but I lost confidence in them.
own:2020 Serow 250
The last post was made 9 years, 304 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 2.23 - MySQL Queries: 13 - Page Size: 66.76 Kb
