| Bgrover |
 Bgrover L Plate Warrior
 Posted: 19:51 - 18 Sep 2016 Post subject: Do Larger Tyres help? |
Hi all, new poster here.
I used to have a bike when I was in my teens, few years ago now, good old Fizzy and then a little YDS7, only got back into riding a bike last year, 56 now and feeling like I wasted 35 years not having a bike, this was what I was looking for when I tried sportscars for some kicks! As I don't have a bike licence am restricted to a 125.
Have a little YBR125 which is great around town but today on a bend I nearly lost the thing. Wasn't going that fast, around 40 and the back wheel slipped big time, not sure how I stayed on but I did!
Always felt the tyres are really thin on this bike, have Michelin Pilots so decent tyres. Do you think that a bike with thicker tyres would grip the road better round the bends etc? I'm guessing it possibly would but perhaps you still just have the same amount of rubber in contact with the road? Appreciate any advice / thoughts, maybe time to get a different bike? |
| Hahadumball |
 Hahadumball World Chat Champion
 Posted: 20:00 - 18 Sep 2016 Post subject: |
so what youre asking is.. does a larger surface area give more grip....
why so long winded ____________________ Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
| Andy_Pagin |
 Andy_Pagin World Chat Champion
 Posted: 20:01 - 18 Sep 2016 Post subject: |
Short answer's No. I'm sure others will explain the science to you.
Well done on staying on.  ____________________ They're coming to take me away, ho-ho, hee-hee, ha-haaa, hey-hey,
Yamaha Vity -> YBR125 -> FZS600 Fazer -> FZ1-S Fazer |
| Banana_B1 |
 Banana_B1 Banned
 Posted: 20:10 - 18 Sep 2016 Post subject: |
Wider tires will have more contact patch with the road depending on their profile type, some tires the exact same width can have very tall profile = high stability loss like balancing on 1 ice skate, i always fit the widest tires the rims safely permit and i chose tires with a profile no higher than stock. Here's a tire/wheel fitment chart https://ridewrightwheels.com/pages/motorcycle-tire-wheel-fitment-chart
When choosing a set of tires' always make sure thier speed + load ratings match OEM specifications. Bridgestone BT45's have been my favourite grippy wet/dry on road tire for a rather long time  ____________________ The entire Butthurt BCF wrote: Spam Flame Abusive Redundant Off Topic Boring Disagree Confusing |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 20:17 - 18 Sep 2016 Post subject: |
TL; DR: No!
To give you an idea, swap your sneakers for a pair of boots and try to run in them. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Lord Percy |
 Lord Percy World Chat Champion
 Posted: 20:20 - 18 Sep 2016 Post subject: |
Generally it doesn't matter how much rubber is on the road, what matters is the weight of the bike because that's what adds to the downward force for producing grip.
Science here and here. Essentially the main way to increase friction is to increase the normal force - the thing keeping the two surfaces compressed together, which for motorbikes is the downward force due primarily to the weight of the bike.
I suppose larger tyres will be heavier but not by much. The best choice is to aim for getting a bigger engined bike which will almost certainly be a few multiples heavier.
Or eat lots of pies  |
| Banana_B1 |
 Banana_B1 Banned
 Posted: 20:32 - 18 Sep 2016 Post subject: |
Let's whack a set of chisel thin bicycle tires on a nitroglycerin fueled drag bike and watch it loose control spectacularly  ____________________ The entire Butthurt BCF wrote: Spam Flame Abusive Redundant Off Topic Boring Disagree Confusing |
| Hahadumball |
| Banana_B1 |
 Banana_B1 Banned
 Posted: 20:42 - 18 Sep 2016 Post subject: |
BTW' i currently run a set of road legal hybrid knobbies (less rubber contact with the road) on the motard, just touching the rear brake pedal after the front nose dives from applying front brake sends it countersteering in the wet  ____________________ The entire Butthurt BCF wrote: Spam Flame Abusive Redundant Off Topic Boring Disagree Confusing |
| Lord Percy |
| Banana_B1 |
 Banana_B1 Banned
 Posted: 20:58 - 18 Sep 2016 Post subject: |
| Lord Percy |
| Banana_B1 |
 Banana_B1 Banned
 Posted: 21:27 - 18 Sep 2016 Post subject: |
| Lord Percy |
| Banana_B1 |
 Banana_B1 Banned
 Posted: 21:52 - 18 Sep 2016 Post subject: |
Tyres some workmates debating the other month in the office cabin about tire vs Tyre, we always used Tyre until that day...i should have googled it getting Tyre tuned back into the brain may take some time  ____________________ The entire Butthurt BCF wrote: Spam Flame Abusive Redundant Off Topic Boring Disagree Confusing |
| Triton Thrasher |
 Triton Thrasher Could Be A Chat Bot
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 23:15 - 18 Sep 2016 Post subject: Re: Do Larger Tyres help? |
| Bgrover wrote: | Do Larger Tyres help? |
The problem you describe.... No.
What are your tyre pressures? what are the units? PSI.. pounds per square inch. The area of contact, then comes from squashing the tyre until there's enough square inches of rubber pressed against the road to support the weight on it.
Bigger tyre, will just mean that there's more rubber NOT being pressed against the road.... unless you let the pressure down.. which isn't usually all that good for either handling or ecconomy.
Bigger bikes generally use bigger tyres, to support more weight...
Skinny 1cm wide push-bike tyres supporting the weight of an 80Kg is rider and maybe a couple of Kg of push-bike, will get pumped up to maybe 100PSI or more...
Imagine how high a pressure you would have to pump up such a skinny tyre to support 1/4 ton of 750cc motorcycle, a couple of 80Kg people on the seat and some luggage!
So they make the tyre bigger, spread the load and reduce the pressure...
Then the rule is, as wide as you have to, as skinny as you can.
Narrower tyres, will usually deform less when they rotate and the flat bit at the bottom moves around the wheel; that means less internal friction, which means less 'rolling resistance' or 'drag' holding the bike back; so you can go faster for the same power or you can go as fast for better MPG.
Meanwhile, when you have a wet road; rubber don't grip water, tyre has to 'cut' through that surface water to find grip on the tarmac beneath; now the narrower tyre is sharper, and better able to cut through water; and water that has to be shoved out of the way doesn't have to be shoved so far, or so fast, which means you will generally get more rubber gripping tarmac and less water lubricating it..... Ie better grip.
YBR, as standard, is a little notoriouse for being supplied with pretty dire OEM tyres... but of you have Mitch Pilots, of the right size, then they should be giving about as much grip as you can get on that bike.....
If they are pumped up to the right pressure; if they aren't squared off, if they aren't lubed by excess chain oil or anything...
BUT grip is always finite...
AND.... it's that time of year; we have had a long summer; and dry-ish roads, and now we are getting a bit of rain again, lifting however many months worth of accumulated road slime....
BUT... little bike, and chap on a learner licence... with little and certainly not recent, experience......looking for thrills not found with sports cars?
Its NOT exactly a prescription for a smooth predictive rider, riding for maximum traction, and aware of hazards and surface conditions, really... might go as far as to suggest its an accident looking for some-where to happen, and you almost found it!!!
Suggesting further, 'the Problem' isn't tyres, or tyre pressures, or contact patch, or grip.... but simple experience vs exuberance vs prudence.... and the 'solution' isn't to change the bike or bits of bike... but change the rider... or how they are riding!!!! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Ariel Badger |
 Ariel Badger Super Spammer
| Banana_B1 |
 Banana_B1 Banned
 Posted: 00:35 - 19 Sep 2016 Post subject: |
| Banana_B1 |
 Banana_B1 Banned
 Posted: 00:45 - 19 Sep 2016 Post subject: Re: Do Larger Tyres help? |
| Major Doss |
 Major Doss Traffic Copper
 Posted: 03:40 - 19 Sep 2016 Post subject: |
An awful lot of cock rubbing cobblers has been spouted here.
Let me add to it.e
A bigger tyre will need more heat too. You'll struggle to get the necessary friction with a 125. A 'thin' tyre will generate the heat easier. Maybe you just have a cakky OE tyre?*
A 'bigger' tyre will also ruin any notion of handling without a furrowed brow and a yardstick.
Even if you disregard the maths that gets it going and stopping, it'll still handle like a jockstrap on a hippo.
*edit. Michelin rp's on a 125. Either no heat in the tyre or you slid on a drizzle of diesel.
Get a grin on, pass test, then move on.
*****Go with the walloftext Teff post, now I've read the ruddy thing. |
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:31 - 19 Sep 2016 Post subject: |
tl;dr version - your problem is that you're wasting time on a tiddler.
Tests -> license -> buy whatever Fatty Boom Batty shod steed you want. ____________________ Biking is 1/20th as dangerous as horse riding.
| Alpineandy |
 Alpineandy World Chat Champion
| owl10 |
 owl10 Could Be A Chat Bot
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
The last post was made 10 years, 22 days ago. Instead of replying here, would creating a new thread be more useful? |
