Do Larger Tyres help?
Bgrover
PostPosted: 19:51 - 18 Sep 2016    Post subject: Do Larger Tyres help? Reply with quote
Hi all, new poster here.
I used to have a bike when I was in my teens, few years ago now, good old Fizzy and then a little YDS7, only got back into riding a bike last year, 56 now and feeling like I wasted 35 years not having a bike, this was what I was looking for when I tried sportscars for some kicks! As I don't have a bike licence am restricted to a 125.
Have a little YBR125 which is great around town but today on a bend I nearly lost the thing. Wasn't going that fast, around 40 and the back wheel slipped big time, not sure how I stayed on but I did!
Always felt the tyres are really thin on this bike, have Michelin Pilots so decent tyres. Do you think that a bike with thicker tyres would grip the road better round the bends etc? I'm guessing it possibly would but perhaps you still just have the same amount of rubber in contact with the road? Appreciate any advice / thoughts, maybe time to get a different bike?
Hahadumball
PostPosted: 20:00 - 18 Sep 2016    Post subject: Reply with quote
so what youre asking is.. does a larger surface area give more grip....
Rolling Eyes Rolling Eyes
why so long winded
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
Andy_Pagin
PostPosted: 20:01 - 18 Sep 2016    Post subject: Reply with quote
Short answer's No. I'm sure others will explain the science to you.
Well done on staying on. Thumbs Up
Banana_B1 This post is not being displayed because the poster is banned. Unhide this post / all posts.
RhynoCZ
PostPosted: 20:17 - 18 Sep 2016    Post subject: Reply with quote
TL; DR: No! Thumbs Up
To give you an idea, swap your sneakers for a pair of boots and try to run in them.
Lord Percy
PostPosted: 20:20 - 18 Sep 2016    Post subject: Reply with quote
Generally it doesn't matter how much rubber is on the road, what matters is the weight of the bike because that's what adds to the downward force for producing grip.
Science here and here. Essentially the main way to increase friction is to increase the normal force - the thing keeping the two surfaces compressed together, which for motorbikes is the downward force due primarily to the weight of the bike.
I suppose larger tyres will be heavier but not by much. The best choice is to aim for getting a bigger engined bike which will almost certainly be a few multiples heavier.
Or eat lots of pies Very Happy
Hahadumball
PostPosted: 20:41 - 18 Sep 2016    Post subject: Reply with quote
Banana_B1 wrote:
Let's whack a set of chisel thin bicycle tires on a nitroglycerin fueled drag bike and watch it loose control spectacularly Pass the popcorn
best
film
ever!
Lord Percy
PostPosted: 20:49 - 18 Sep 2016    Post subject: Reply with quote
Banana_B1 wrote:
in the wet
Well things may be a little different on wet surfaces because with less ground contact it doesn't take as much fluid to induce full aquaplaning.
But then you can counter that by saying less ground contact means the tyre is more sensitive to an uneven road surface which makes it less susceptible to slipping.
There are a fair few funny variables that'll change things but as far as plain science goes, the only thing that can change the gripping power of a surface under uniform conditions is the force driving the surface together, i.e. the mass of the bike.
Lord Percy
PostPosted: 21:21 - 18 Sep 2016    Post subject: Reply with quote
Banana_B1 wrote:
??? ever noticed how engine rpm's raise over potholes/manholes and small humps with knobbies? Laughing
Ever notice how nobody uses wide, smooth road-racing tyres on dirt tracks?
Lord Percy
PostPosted: 21:40 - 18 Sep 2016    Post subject: Reply with quote
Banana_B1 wrote:
Because there's no knobbie tread pattern for digging into the dirt...something knobbies can't do on tarmac Thumbs Up ever wondered why trials tires offer less grip than enduro and mx tires in quagmire? Wink
vifferguy?
Triton Thrasher
PostPosted: 22:24 - 18 Sep 2016    Post subject: Reply with quote
There's no shortage of fluid.
If you want to aquaplane, get wide tyres.
Rrrrrrrrrrrrrrrrrr
Teflon-Mike
tl;dr
PostPosted: 23:15 - 18 Sep 2016    Post subject: Re: Do Larger Tyres help? Reply with quote
The problem you describe.... No.
What are your tyre pressures? what are the units? PSI.. pounds per square inch. The area of contact, then comes from squashing the tyre until there's enough square inches of rubber pressed against the road to support the weight on it.
Bigger tyre, will just mean that there's more rubber NOT being pressed against the road.... unless you let the pressure down.. which isn't usually all that good for either handling or ecconomy.
Bigger bikes generally use bigger tyres, to support more weight...
Skinny 1cm wide push-bike tyres supporting the weight of an 80Kg is rider and maybe a couple of Kg of push-bike, will get pumped up to maybe 100PSI or more...
Imagine how high a pressure you would have to pump up such a skinny tyre to support 1/4 ton of 750cc motorcycle, a couple of 80Kg people on the seat and some luggage!
So they make the tyre bigger, spread the load and reduce the pressure...
Then the rule is, as wide as you have to, as skinny as you can.
Narrower tyres, will usually deform less when they rotate and the flat bit at the bottom moves around the wheel; that means less internal friction, which means less 'rolling resistance' or 'drag' holding the bike back; so you can go faster for the same power or you can go as fast for better MPG.
Meanwhile, when you have a wet road; rubber don't grip water, tyre has to 'cut' through that surface water to find grip on the tarmac beneath; now the narrower tyre is sharper, and better able to cut through water; and water that has to be shoved out of the way doesn't have to be shoved so far, or so fast, which means you will generally get more rubber gripping tarmac and less water lubricating it..... Ie better grip.
YBR, as standard, is a little notoriouse for being supplied with pretty dire OEM tyres... but of you have Mitch Pilots, of the right size, then they should be giving about as much grip as you can get on that bike.....
If they are pumped up to the right pressure; if they aren't squared off, if they aren't lubed by excess chain oil or anything...
BUT grip is always finite...
AND.... it's that time of year; we have had a long summer; and dry-ish roads, and now we are getting a bit of rain again, lifting however many months worth of accumulated road slime....
BUT... little bike, and chap on a learner licence... with little and certainly not recent, experience......looking for thrills not found with sports cars?
Its NOT exactly a prescription for a smooth predictive rider, riding for maximum traction, and aware of hazards and surface conditions, really... might go as far as to suggest its an accident looking for some-where to happen, and you almost found it!!!
Suggesting further, 'the Problem' isn't tyres, or tyre pressures, or contact patch, or grip.... but simple experience vs exuberance vs prudence.... and the 'solution' isn't to change the bike or bits of bike... but change the rider... or how they are riding!!!!
Ariel Badger
PostPosted: 00:10 - 19 Sep 2016    Post subject: Reply with quote
You mean nitromethane.
Major Doss
PostPosted: 03:40 - 19 Sep 2016    Post subject: Reply with quote
Brick Wall Doh! Rolling Eyes An awful lot of cock rubbing cobblers has been spouted here.
Let me add to it.e
A bigger tyre will need more heat too. You'll struggle to get the necessary friction with a 125. A 'thin' tyre will generate the heat easier. Maybe you just have a cakky OE tyre?*
A 'bigger' tyre will also ruin any notion of handling without a furrowed brow and a yardstick.
Even if you disregard the maths that gets it going and stopping, it'll still handle like a jockstrap on a hippo.
*edit. Michelin rp's on a 125. Either no heat in the tyre or you slid on a drizzle of diesel.
Get a grin on, pass test, then move on. Wink
*****Go with the walloftext Teff post, now I've read the ruddy thing.
PostPosted: 10:31 - 19 Sep 2016    Post subject: Reply with quote
tl;dr version - your problem is that you're wasting time on a tiddler.
Tests -> license -> buy whatever Fatty Boom Batty shod steed you want.
Alpineandy
PostPosted: 17:15 - 19 Sep 2016    Post subject: Re: Do Larger Tyres help? Reply with quote
Bgrover wrote:
56 now ..... As I don't have a bike licence am restricted to a 125.
Get a full licence then!
You'll be so pleased you did Cool
The above comment isn't necessarily the truth and anyone that says it is, is only correct if it's the truth or they're bigger than me.
owl10
PostPosted: 21:30 - 19 Sep 2016    Post subject: Reply with quote
There is a lot more to tyre performance than just contact patch, especially when you start adding in acceleration, braking, turning forces etc into the mix.
Michelin tyres generally are great as a very simplistic generalisation. That said, you personally may get on with something else.
Lots of stuff to try
DanceLikeAMonkey says: "An infinte amount of web pages available
Yet I still end up reading crap like that"
Kawasaki Jimbo
PostPosted: 21:48 - 19 Sep 2016    Post subject: Re: Do Larger Tyres help? Reply with quote
The last post was made 10 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 146.37 Kb
