Damn alloy fur - any advice
map
Mr Calendar
PostPosted: 15:59 - 24 Feb 2005    Post subject: Damn alloy fur - any advice Reply with quote
Just thought I'd pick a few brains.
Here's the situation:
Bike in garage (not mine).
Car parked in garage, parked when wet.
Water runs under bike so garage damp.
Bike engine now covered in alloy fur Sad
So thinking need to clean this off with a bit of elbow grease.
Are there any other effective solutions or recommended products?
Was thinking of taking the Dremel with polishing bits and working away at it (air-cooled so lots of fins on engine). However, I believe this just makes it easier for it to come back as any laquer is removed.
So, as I said, looking for ideas/products to use.
Thanks in anticipation Thumbs Up
map
Mr Calendar
PostPosted: 16:56 - 24 Feb 2005    Post subject: Reply with quote
Just been looking around and found some guys on another site rate this ACF-50 stuff - see here.
Anyone used this stuff?
Does it do what it says on the tin and will it help stop my alloy corrosion?
speedfight
PostPosted: 17:04 - 24 Feb 2005    Post subject: Reply with quote
All I have to say on this is be careful on what products you do use. For example some alloy-cleaning product do cause damage to certain alloys depending on brand, make, type of alloy and time left on before washing off. Mad Make sure any surplus spray does not get on plastic faring or plastic bike parts it sometime melts or flakes certain plastics.
Having said this I have found that Autoglym (Yes I am a big fan of Autoglym) Smile if you have read other post. Is the best when I have used it seems to remove alloy dirt and fur well with any other lasting damage. Check on a small part first spray on and brush using a tooth brush, then was off IMMEDIATLY **** Do Not leave on to soak *****
I hope this information is what you are looking for and helps Cool
Peugeot Speedfight 100cc (year 2000)
Polini Clutch, Malossi Multivar 2000 Variator
Malossi Kevlarf Belt, Doppler Exhaust
PostPosted: 17:55 - 24 Feb 2005    Post subject: Reply with quote
Those plastic 'scotchbrite' style scouring pads for non-stick pans do a fairly good job of shifting the fur without marking the alloy too much.
speedfight
PostPosted: 18:01 - 24 Feb 2005    Post subject: Reply with quote
ACF-50 Looks interesting not cheap tho.....
Have a look https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=10458&item=7956849770&rd=1&ssPageName=WDVW
map
Mr Calendar
PostPosted: 18:12 - 24 Feb 2005    Post subject: Reply with quote
speedfight wrote:
ACF-50...Interesting not cheap tho.....https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=10458&item=7956849770&rd=1&ssPageName=WDVW
Thanks for the link. That's about the same price I was quote for a can from the shop (DRS from ACF-50 site, I remember £12 something) - minus the postage of course. If I can arrange a detour past the shop I'll pick some up to try.
The last post was made 21 years, 251 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 52.46 Kb
