recommend me some indicators
Hong Kong Phooey
PostPosted: 12:41 - 17 Sep 2016    Post subject: recommend me some indicators Reply with quote
CBR600F4 1999. I've already swapped out the huge oem units for small arrow type but there's a problem with one of them so I'm changing.
I'm thinking led, but not tiny. Must be bright and waterproof.
Not bothered if I have to add inline resistors or swap out the flasher relay.
Must also suit the bike.
I'll be doing all 4 with blanking spacers too.
Over to you BCF.
Hong Kong Phooey
PostPosted: 15:05 - 17 Sep 2016    Post subject: Reply with quote
Socket wrote:
Refit the OEM ones and leave it alone.
I suppose you've retained the standard incandescent OEM lights so you can take your own advice?
The standard ones are huge tatty blobs.
PostPosted: 15:38 - 17 Sep 2016    Post subject: Reply with quote
Kellermann if you can stomach the cost.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:41 - 17 Sep 2016    Post subject: Reply with quote
Cheapest bulb mini idicators in your local shop/iternet.
Triumph Sprint ST 1050
Hong Kong Phooey
PostPosted: 22:34 - 17 Sep 2016    Post subject: Reply with quote
Ok so faffery of led doesn't seem worth it, plus not sure how bright 'super bright' and the other equally useful descriptions are. Wheras the standard wattage of incandescent bulb indicators are a known quantity.
The micro ones are near impossible to repair as I've found out so I'm going for a larger aftermarket pair.
colink98
PostPosted: 10:46 - 19 Sep 2016    Post subject: Reply with quote
get a left one......
and
a right one.......
Ride it like you stole it.
Hong Kong Phooey
PostPosted: 11:11 - 19 Sep 2016    Post subject: Reply with quote
and
a right one.......
How will I know which one is which?
groovylee
PostPosted: 11:43 - 19 Sep 2016    Post subject: Reply with quote
i have these https://www.ebay.co.uk/itm/181767214694
they are properly small, but very very bright, as i was told repeatedly after the last BCF rideout Laughing
just dont overtighten them.
they are cheap enough to buy 2 sets so you have spares in the event of failure, and they are small enough to carry a spare or two under the seat just in case Thumbs Up
make sure you get the orange lensed ones though, as the clear lens ones i ordered looked almost bright white to me!
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
Shinigami
PostPosted: 12:05 - 19 Sep 2016    Post subject: Reply with quote
i bought a set of 4 cheapy mini led ones for the gpz...ive just discovered theyre so small (and with the mounting points on the gpz) that they will be entirely blocked by the reg plate Laughing
colink98
PostPosted: 13:05 - 19 Sep 2016    Post subject: Reply with quote
Hong Kong Phooey wrote:
and
a right one.......
indicate left and see which ones flashes.
Fit that to the left of the bike.
Simples.
Adam80UK
PostPosted: 13:25 - 19 Sep 2016    Post subject: Reply with quote
Oxford Eyeshot Nano or any from that range. Not cheap, but fantastic quality, all metal shell and very bright. All I will ever use.
Current: '07 Suzuki SV1000 & '07 Honda SH300i (again).
Previously owned: '08 Yamaha R1, '10 Kawasaki Z1000, '07 Honda SH300i, '04 Suzuki SV1000S, '11 Honda CB1000R, '09 Kawasaki ZX-10R, '08 Aprilia Tuono 1000R, '07 Triumph Daytona 675, '95 Honda CBR600F.
groovylee
PostPosted: 21:18 - 19 Sep 2016    Post subject: Reply with quote
so basically the ones i linked to, but £40 more expensive... Wink
plus, with them being made by oxford, you can guarantee they will leak and/or get nicked Laughing
Hong Kong Phooey
PostPosted: 22:28 - 19 Sep 2016    Post subject: Reply with quote
Have they proven to be waterproof? Did you fit inline resistors or a suitable flasher unit?
bamt
PostPosted: 23:48 - 19 Sep 2016    Post subject: Reply with quote
One problem with LEDs is that being bright and having a wide viewing angle are usually mutually exclusive features. So your indicators may appear dazzlingly bright to someone directly behind, but almost invisible to someone close to you but offset (like a driver in another lane).
Multi-LED indicators can be a way around that.
groovylee
PostPosted: 08:03 - 20 Sep 2016    Post subject: Reply with quote
so far yes. I fitted a flasher unit, but also, due to the way the system is wired on the R6, i put zener diodes in the idiot light circuit to prevent current bleed between the two sides. major PITA, but looks much better than the stock indys. i could have just fitted resistors, but the diodes were cheaper (if not harder) to fit.
as for viewing angle, on those type, the lens is designed in such a way that they can be seen from quite a wide angle Thumbs Up rather than a plain lens with an led behind it.
adriansk
PostPosted: 08:49 - 20 Sep 2016    Post subject: Re: recommend me some indicators Reply with quote
Over to you BCF.
Same bike, I'll be looking at replacing these huge indicators too. I also need to add a USB charges.
CBR600F4
Hong Kong Phooey
PostPosted: 19:52 - 20 Sep 2016    Post subject: Re: recommend me some indicators Reply with quote
Over to you BCF.
Well I can confirm this USB works fine:
https://www.ebay.co.uk/itm/262535132445
I left it under the seat, but it wedges into the tray nicely so doesn't move about. I didn't use the mounting bracket, seems to be water resistant and the inline fuse is a good feature.
adriansk
PostPosted: 20:49 - 20 Sep 2016    Post subject: Re: recommend me some indicators Reply with quote
Nice one cheers. Will buy it. Will have to install it somewhere next to handlebars as I use my phone as Sat Nav.
Let me know how you get on with indicators.
CBR600F4
Hong Kong Phooey
PostPosted: 22:45 - 20 Sep 2016    Post subject: Re: recommend me some indicators Reply with quote
There are probably better alternatives if mounting on the handlebars. There's not much space with clip ons, do some research.
Also you may want to wire via the ignition so people can't steal usb power when you're not with the bike. Not an issue for me as it's locked away.
Derivative
PostPosted: 09:22 - 21 Sep 2016    Post subject: Reply with quote
Personally, I don't think the bulb choice is as important as the circuitry.
Make sure that you connect the wires correctly so that the switch operates randomly. You must keep other road users on their toes. If they come to believe that your left indicator actually means a potential left turn, one day you may not turn left, and that will be that.
The last post was made 10 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 117.84 Kb
