Smart Thermostat + reducing heatloss
PostPosted: 12:12 - 11 Oct 2016    Post subject: Smart Thermostat + reducing heatloss Reply with quote
I'm looking at getting a smart Thermostat wondering if anyone has any experience with them.
I'm looking at Tado at the moment, I like that it tracks where you are and will turn the heating off when you leave or put it on when you are near home.
Anyone have any tried any others? Hive, nest etc.
Also I am looking to improve how well my house holds the heat. we have an extension which is noticeably colder than the rest of the house so I guess something wasn't insulated well, we have a shabby looking roof window that is my prime suspect. I'm thinking about hiring a thermal Camera for a day to see where I am bleeding heat, any tips or advice about that? Anyone in London/Essex area have one I can borrow to save me a few quid?
Cheers,
Chris
B5234FT
PostPosted: 13:02 - 11 Oct 2016    Post subject: Reply with quote
The problem with all of this technology is that hydrocarbons are still too cheap to make it worthwhile.
The average house ownership is 13 years, but far lower among young people (those who tend to like gadgets like intelligent wireless thermostats) and the average gas bill is £750 quid a year (and again, younger people tend to live in smaller homes), so making a saving by fitting hundreds of pounds worth of insulation after the fact and shiney new thermostats is difficult.
Much easier to justify it from the point of view of comfort. I personally dont care about saving a tenner a month on gas, but its nice coming home to a warm house, not having cold rooms you avoid using etc.
What sort of construction method was used for the extension? air movement loses heat more rapidly than conduction and then once you're looking at conduction, roofs and windows are far worse than even bad walls.
dodsi
Dirty Carny
PostPosted: 13:36 - 11 Oct 2016    Post subject: Reply with quote
We had a whole new heating system installed in July this year - we went from an inefficient electric panel heater/night storage combi things to a proper gas combi boiler installation.
At the time of installation we had a Nest system installed - after much deliberation as to which smart thermostat system to get. I chose the nest because after looking at all the reviews and features it appeared about the best on the market. In addition to having the thermostat you can also integrate other smart home equipment with it - such as a nest 'protect' which is basically a clever smoke/CO alarm.
This allows you to place your thermostat anywhere in your home and have it heat your home to the set temperature in any given location. be aware that other rooms could be +/- this temp due to fluctuations but TRV's would help combat this a little.
The nest system also has an 'away' feature which you set when you are out then 'Auto' away uses your phone(s) location(s) to know when you are in. All you do is change the temperature as and when you need it. The less faffing around with it the better it learns your schedule and then just heats your home as and when it works out it needs to. You can alter these schedules manually.
We turned ours 'on' on friday, it has since ran only for 3.5 hours in total since then to keep the place at 20c - however it has not been /that/ cold but neither is our property particularly energy efficient.
Currently the indoors temperature is 19.5c but the heating is not running as it knows we are not at home.
when it does get cold, all it will do in periods that we are away is let the property drop to 9c and heat it back up to your set temperature in line with your schedule of when you are in the property.
Even 'Turned off' there is a pipe protect system that will turn your heating on to stop anything freezing inside the property if it needs to - this is something like 3c.
all in all, very impressed as its simple to use and has massive gadget appeal.
Would I buy one if I wasn't doing a whole brand new install? I would like to say no as you probably wouldn't reclaim the outlay in energy savings over a reasonable time. However - I am the kind of Tosser who signs up for the apple upgrade program so probably would just for the gadget appeal.
PostPosted: 13:45 - 11 Oct 2016    Post subject: Reply with quote
Tado claim savings up to 31%, based on an Independent study.
A couple of reviews I've seen claim 25-30% and 20%
Assuming the lower one is is the case 20% I should still make my money back easily in 2 winters.
The convenience is the main reason but the savings should be good.
No idea about the extension, it was done in the 90's, however there is no loft for the room in it, i.e. you can see the apex of the roof
PostPosted: 14:14 - 11 Oct 2016    Post subject: Reply with quote
I got a guy from a local eco chairty to come round and do me a thermal survey.
Was very useful but you've got to know what you're looking for and pick when you do it.
Best bet is a reasonably bright morning with a breeze belowing in the prevailing direction when the temperature inside the house is higher than the outside temperature.
You go round the house looking for thermal gradients, spot temperatures and draughts.
Upshot of my one was that my wall and loft insulation was good (he spotted the insulation hadn't been fully poked down in one corner). The doors and windows were also fine but were all draugty and needed new seals and hinges. Few other draughts about the place.
So main thing was refurb the windows and replace my porch and garage doors with outside grade ones. I was expecting to have to redo the cavity walls and get new windows.
If someone is pointing a thermal camera at the roof of your house, they are a conman. The guy wasn't too expensive and his experience and advice was very useful.
stevo as b4
PostPosted: 14:28 - 11 Oct 2016    Post subject: Reply with quote
I can understand smart heating and room/zone stats in larger family homes. I'd say it needs to be a 3bed plus home, with adults and kids living there, and preferably people with very different levels of hot/cold bloodedness. Also if the occupants were not much of a family unit and liked being in different parts of the home to each other for long periods. Maybe one works from home in the office room and only needs that room warm in the day etc.
But a small 1-2 bed place with an individual or a couple without kids, it seems totally pointless. Small and efficient homes don't take much heating or time to warm up, so coming home to a cold house might be a 10-15min inconvenience at the most?
And what is this gadget aspect appeal that you speak of? I take it it's the same thinking as the people that like auto headlights, wipers and lane departure warning or evadeance systems in cars, or launch control and anti wheelie systems on their bike?
I'd like my heating system to be simple, powerful and easy to fix and get spares for. I'd also like it to be specced with big reliable components, all brass valves and pumps, and have a simple control system that has replaceable parts.
Will these intelligent heating systems be like that or will they be constantly superceded and made obscelesent quickly with each new version? Where in 15years will you get a new pcb for the controller from?
B5234FT
PostPosted: 14:30 - 11 Oct 2016    Post subject: Reply with quote
The answer is "it depends"
It depends how far your arrivel time at home regularly deviates from normal, what your normal heating pattern is and so on.
That study is comparing a new thermostat which knows when youre getting home, with just leaving the heating on all day. You'd get most of the difference just programming periods, but of course risk a cold house if you arrive home early.
Like I say, a nice to have, but not an easy route to cost savings compared to insulation, or efficient radiators etc.
PostPosted: 14:37 - 11 Oct 2016    Post subject: Reply with quote
I've done insulation in the original house, not touched the extension yet as it would mean pulling ceilings down. All the rads are new, I'm not sure what makes them efficient, I flushed them when I moved in.
PostPosted: 14:52 - 11 Oct 2016    Post subject: Reply with quote
It's not a little place.
I have auto lights on my car, it's great one less thing to worry about, they have been perfect.
When the unit itself is /only/ £200 I'm not really worried about replacement parts, I had to replace the diverter valve and solenoid in my combi the parts were £215. Personally I wouldn't care if something I paid £200 for Broke in 15 years, I've had my moneys worth and I would assume I could pay the same amount for something better.
Your boiler will be superseded every year most likely, doesn't mean you have to buy a new one, the same goes for this.
PostPosted: 14:53 - 11 Oct 2016    Post subject: Reply with quote
Any more details on who you used? That sounds good to me.
ScaredyCat
PostPosted: 15:13 - 11 Oct 2016    Post subject: Reply with quote
I presume you live alone because one person leaving a house shouldn't disable the heating.
I'd stay away from Nest. Not only are google know for dropping products and leaving you with nothing recently nest eol'd some of their stuff breaking something that still worked because they turned off the servers that handled those devices.
I'll also point to the time that the Nest thermostats shut off when they couldn't contact the servers. That's right, shut off rather than staying at the same of any sort of sensible 'average' temperature.
You do not need that fine a control over your heating anyway.
When you buy a product like any of those you listed you're putting yourself in a position where you have lost control. Then again, it could be worse, you could have bought a heatmeiser ...
Set the thermostat to the temperature you want, get a timer for your boiler.
Only for you. For everyone else on the road your lights don't work properly.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
PostPosted: 15:25 - 11 Oct 2016    Post subject: Reply with quote
I live with my missus, she will have the app too, it'll only go off when we are both out.
PostPosted: 15:33 - 11 Oct 2016    Post subject: Reply with quote
https://www.cafs.org.uk/
But I suspect they don't travel as far as you.
I explained I wanted tips for my own information so I could make my house more efficient rather than as a formal report for sale of the house and they did it at a much reduced price.
Basically walked round with the guy and he pointed out draughts and suchlike then sent me a report by email including copys of the images.
PostPosted: 18:49 - 11 Oct 2016    Post subject: Reply with quote
How did he spot the draughts?
cagiva gezzer
PostPosted: 18:54 - 11 Oct 2016    Post subject: Reply with quote
I used a basic IR fluke gun - https://www.amazon.co.uk/Fluke-FLUKE-62-MAX-Infrared-Thermometer/dp/B008EW837S - from work to go around a point at walls / gaps / joints to get an idea of temperature gradients.
It was useful to trace drafts and then pull up laminate flooring to find shabby work / holes to block. It also showed thermal bridging from ceiling joists.
If you want a IR camera we hire equipment from BSRIA - not sure if they would hire to Joe Public through
https://www.bsria.co.uk/instrument/hire/temperature/thermal-imaging-cameras/
dodsi
Dirty Carny
PostPosted: 19:08 - 11 Oct 2016    Post subject: Reply with quote
You just described my Home, Marriage status and car...
However, i simply don't agree - when installing a heating system from scratch it made absolute sense in my 2 bed 60s built flat to install a smart system.
I can control my system from anywhere in the world and as I have the 'protect' system I can get notified if there is anything going on at home in terms of fire/CO. Plus when you burn the toast/open the oven etc you can mute the alarm from your phone. All possible through integration via the smart system it's very useful. The smoke alarm also doesn't treat steam like smoke - very good system.
With regards to what is stated about the nest - if anything I chose google due to them being a big tech company who appear not to be going anywhere.
If the servers go down this does not disable my thermostat - I just can't see anything or control it from the web/from my phone. The protect works from Bluetooth so still works via the phone.
In terms of installation it's very quick and easy and very simple to replace should you need to. Again, of course there are overrides available should this be needed.
Interesting that the people with the opinions about these systems don't appear to have used them/have any experience of them.
There are many benefits to them - and definite gadget appeal if you like gadgets.
Diggs
PostPosted: 20:55 - 11 Oct 2016    Post subject: Reply with quote
Things to look for:
Draughts - obvious one. Remember though that your house needs to breath otherwise condensation will build up and it will slowly rot from the inside out.
Heating/Hot Water System - lots of debate about this one, but generally accepted that a current condensing combi-boiler is about as efficient as you can get when used with TRVs (thermostatic radiator valves) and a control system with its thermostat carefully placed to optimise room temperature and frequency of boiler firing up. The hall is often seen as the best place for this.
Wall insulation - depends upon the age and construction of the original house. If it has a cavity for example it is generally considered acceptable to fill walls that aren't exposed to prevailing winds/rain. If it doesn't or you live on top of a mountain then internal insulation is an option if you don't mind loosing a bit of floor area.
Floor insulation - depends upon the build, but if you have suspended timber floors you can fill between the joists. Usually only practical if you have a void beneath the house and are happy to get very dirty... Makes a massive difference though!
Windows and doors - do you have modern (i.e. post 2002) double glazing? If you don't it is worth putting these on your 'to do' list. Easiest way to tell is to look at the rubber seal. General rule of thumb is that if the big bit of the seal is external and pronounced then your windows will be pre 2002.
Roof insulation - a 'warm roof' (i.e. with insulation between the rafters rather than the joists) is generally considered a better option than your standard loft insulation. Loads of good reasons.
If your extension was designed in the 1990s then it almost certainly was constructed to Building Regs of the time. The U Value of the walls should be low enough to keep heat in, as should that of the roof given that you don't have a ceiling. Could be that you need to change your rooflight, line with thermal-backed plasterboard and insulate between the floor joists. Do all this and it will most likely be the warmest room in the house!
Caveat - this is 'off the cuff' advice and I am not liable etcetcetc....
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
PostPosted: 00:13 - 12 Oct 2016    Post subject: Reply with quote
Because we'd timed it for a 10 degree temperature gradient between inside and outside, any incoming air showed up well on the thermal imaging.
PostPosted: 08:28 - 12 Oct 2016    Post subject: Reply with quote
Oh, right, I didn't realise it would show up that well on IR. Back in the day, folk used to use smoke puffers. Butter was a reasonable price then too, and policemen were polite.
PostPosted: 09:43 - 12 Oct 2016    Post subject: Reply with quote
I was surprised too.
Here's my living room window:
https://i48.photobucket.com/albums/f216/stinkwheel/DC_4096.jpg
Here's the thermal image showing a reasonable leak round the window seal, especially in the corner and a major one round the outside of the window casing.
https://i48.photobucket.com/albums/f216/stinkwheel/IR_4095.jpg
Two new hinges (£2.50 each), new rubber seal (£10 for 25m), a wedgethingy to make the window shut square (£1.99) and a bead of frame sealant and the living room is noticeably warmer for longer.
PostPosted: 10:30 - 12 Oct 2016    Post subject: Reply with quote
Lawks, even the rental price on thermal imaging cameras is £100+ a day. Those sensors don't come cheap.
ScaredyCat
PostPosted: 11:47 - 12 Oct 2016    Post subject: Reply with quote
Blimey, Flir one is £200 (plugs into your phone). Considering the age of my house and the fact it's winter inside 365 days of the year, I might take a look at this.
PostPosted: 11:50 - 12 Oct 2016    Post subject: Reply with quote
Counterpoint: £200 buys you a lot of insulation.
PostPosted: 12:23 - 12 Oct 2016    Post subject: Reply with quote
Looking at the FLIR One myself. Please don't bid on the one on eBay Laughing
PostPosted: 12:25 - 12 Oct 2016    Post subject: Reply with quote
"Oh look a OBD reader is only £200"
"Pft £200 buys a lot of sensors."
The last post was made 9 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.31 Sec - Server Load: 3.15 - MySQL Queries: 13 - Page Size: 150.13 Kb
