Drain bolt plug stripped
Fin
PostPosted: 11:22 - 22 Oct 2016    Post subject: Drain bolt plug stripped Reply with quote
Crying or Very sad
https://i.imgur.com/FKfMkUr.png
Crying or Very sad
How to fix?
I assume I'll have to drill it out a bit and fit a helicoil (which I've never done before).
This is on my xj600 while putting in the new bolt, why isn't the bolt softer than the thread? Crying or Very sad
Can anyone recommend me a kit to get?
Quote Me Happy
PostPosted: 11:23 - 22 Oct 2016    Post subject: Reply with quote
Is the sump bolted on? If so cheap one of eBay.
Fin
PostPosted: 11:32 - 22 Oct 2016    Post subject: Reply with quote
Ahh, suddenly this isn't so bad Laughing
Thanks
Quote Me Happy
PostPosted: 11:33 - 22 Oct 2016    Post subject: Reply with quote
And remember to order a new gasket at the same time.
Quote Me Happy
PostPosted: 11:34 - 22 Oct 2016    Post subject: Reply with quote
And a torque wrench.
Quote Me Happy
And a Haynes manual.
bikenut
PostPosted: 11:36 - 22 Oct 2016    Post subject: Reply with quote
:D why do i need a torque wrench?
now you know, but...........also check to see if the "bolt" is tooooo long, or the hole is toooooo short.......... :karma:
nuts about bikes
Fin
PostPosted: 11:37 - 22 Oct 2016    Post subject: Reply with quote
I've got a torque wrench and haynes manual, the thread stripped at about 10nm.
bikenut
PostPosted: 11:39 - 22 Oct 2016    Post subject: Reply with quote
10nm is about 8ftlbs ish......from memory......
can i see a crush washer on there?
nuts about bikes
Snod Blatter
PostPosted: 13:25 - 22 Oct 2016    Post subject: Reply with quote
Where you went wrong is using that magnetic sump plug, I bet it has a lot less thread on it than the original bolt had. I have fallen for this, all the thread came out the hole when I undid the plug.. I helicoiled mine because the CB250's engine is split vertically so there's no separate sump piece.
If it does have a lot less thread on it then do not use a torque wrench! Just nip it up a little bit tight and hope it doesn't fall out. If your bike has an oil filter (surely the XJ600 does?) then I'd totally recommend using the old plug again, for peace of mind.
Do you have the old plug/bolt to compare it with? I bet the new one has maybe a third of the thread on it, possibly less..
1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL
PostPosted: 13:48 - 22 Oct 2016    Post subject: Reply with quote
What on earth is the point of a magnetic sump plug.
1. The engine is mainly aluminium alloy.
2. If you have lumps of steel washing around in your oil it's going to take more than a magnet to stop your engine getting destroyed.
Snod Blatter
PostPosted: 14:10 - 22 Oct 2016    Post subject: Reply with quote
Bits of steel get smashed off the dogs in the gearbox, worn off the steel plates in the clutch and little bits come from everywhere else that is sliding and working. To be fair, the plug in my CB250 is always covered in "hairs" of steel, and I see it every 2000 miles. However, the CB250 doesn't have a proper paper filter, only a wire mesh on the feed to the oil pump - this is why I have persisted with the magnetic plug. I wouldn't ever use one in a straight up aluminium thread though, not again.. Seems okay once the thread is helicoiled/timeserted/whatever'd though.
To be honest I don't think they should sell them. There are even horror stories of the magnet part coming away and going for a little sight seeing tour right round everything..!
grr666
PostPosted: 15:47 - 22 Oct 2016    Post subject: Reply with quote
Is that PTFE tape?
PostPosted: 16:26 - 22 Oct 2016    Post subject: Reply with quote
grr666 wrote:
Is that PTFE tape?
I believe it's the sump.
At less than.
This is why I don't generally use torque wrenches.
Fin
PostPosted: 17:17 - 22 Oct 2016    Post subject: Reply with quote
My old drain plug bolt had a lot of metal on it when I removed so they do work a bit.
I'll check the thread on the old bolt but it was magnetic too, I put the new one in as the manual said to replace the washer whenever you undo the drain bolt. The bolt with washer wasn't much more expensive than the washers on there own and I believe magnetic ones are better.
The last post was made 10 years ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 84.42 Kb
