car fuse problem(new question at end )
andyscooter
PostPosted: 17:28 - 25 Oct 2016    Post subject: car fuse problem(new question at end ) Reply with quote
if mods want to stick it in workshop then fair enough but I need some help
car is a 1999 Peugeot 206 1.1 lx
when I got it all was fine but about july I noticed my 12 volt (lighter) socket had stopped working
thought sod it can live without that
then we went out for a meal and I realised my instrument panel on the dash wasn't lit up so couldn't read speedo all the warning lights work but not the back light
the other day I picked my little in up from brownies and noticed the lights behind the heating controls don't work
and since then noticed my rear number plate lights are out
apparently this all points to a fuse in the inside fuse box
now here is the thing
my manual says its fuse 18 and shows this picture
https://i206.photobucket.com/albums/bb129/andyscooters/DSC_0106_zpsv9bys6fb.jpg
fuse 18 is second row from top on the left (sorry pic is wrong way round)
only problem is fusebox looks like this
https://i206.photobucket.com/albums/bb129/andyscooters/fusebox%20pic_zpslrbrqrm5.jpg
which is completely different
TL-DR WHICH FUSE IS NUMBER 18
techathy
PostPosted: 17:44 - 25 Oct 2016    Post subject: Reply with quote
Second row from the bottom of the fuse box.The red fuse with a white fuse to the left and green fuses above and to the right. My second choice would be the white fuse on the very right of the second from bottom row.
Bikeless
PostPosted: 17:45 - 25 Oct 2016    Post subject: Reply with quote
Shine a torch in there and look for blown ones.
andyscooter
PostPosted: 17:55 - 25 Oct 2016    Post subject: Reply with quote
is that a guess or have you seen this problem
Bikeless
PostPosted: 18:17 - 25 Oct 2016    Post subject: Reply with quote
Fuse number diagram on back of fuse box cover?
andyscooter
PostPosted: 18:19 - 25 Oct 2016    Post subject: Reply with quote
nope just blank black on the back
changed both still nothing
PostPosted: 18:25 - 25 Oct 2016    Post subject: Reply with quote
multi meter on continuity. Don't even have to remove the fuses to check them. Go through the lot.
techathy
PostPosted: 18:39 - 25 Oct 2016    Post subject: Reply with quote
Not on this car but seen fuse box & manual miss-alightnments before. You're generally looking for patterns to give you references. In this case to me it looks like:
https://cdn.bcf.44bytes.net/files/fuses.jpg
Besides fuse 23 now looks like it's two fuses all the slots are in the correct place with extra fuses for newer items.
bugeye_bob
PostPosted: 18:43 - 25 Oct 2016    Post subject: Reply with quote
if the fuses in that fuse box are intact there used to be a fuse box in the engine compartment on a ex's 206,
have you had a look if a feed fuse hasn't popped in there ?
andyscooter
PostPosted: 18:50 - 25 Oct 2016    Post subject: Reply with quote
Looked at that but seems OK also interior light works which wouldn't if that one had gone as its a main fuse for inside compartment
Bikeless
PostPosted: 19:00 - 25 Oct 2016    Post subject: Reply with quote
https://www.peugeotlogic.com/fuses/fuses206/fuses5.htm
From this list it does seem it's f18 as the interior light is f22, feed is from sidelights, are they working?
techathy
PostPosted: 19:06 - 25 Oct 2016    Post subject: Reply with quote
Opps wrong fuse box..
andyscooter
PostPosted: 19:07 - 25 Oct 2016    Post subject: Reply with quote
Sidelights work Confused
andyscooter
PostPosted: 19:15 - 25 Oct 2016    Post subject: Reply with quote
F5 changed still the same
Guessing possible wiring fault rather then a fuse
techathy
PostPosted: 19:18 - 25 Oct 2016    Post subject: Reply with quote
F5 would be the engine bay fuse box.
You have 15A fuse in F7... is it a cabriolet?
Pull F19, the 5A fuse on the left of what we think is F18. Check that the HI rears aren't working.
andyscooter
PostPosted: 19:36 - 25 Oct 2016    Post subject: Reply with quote
Nope to cabriolet
I may ride a scooter but I'm not quite that gay
Will have to leave til morning it's dark and I've ran out of new fuses
bugeye_bob
PostPosted: 19:47 - 25 Oct 2016    Post subject: Reply with quote
Why not just go along with a known/tested good fuse trying each fuse one at a time.
techathy
PostPosted: 19:56 - 25 Oct 2016    Post subject: Reply with quote
andyscooter wrote:
techathy wrote:
You have 15A fuse in F7... is it a cabriolet.
Nope to cabriolet
Just from two sources the F7 fuse is 15A for the "Retractable electric roof (cabriolet)"
Why replacing fuses, check them for continuity. If the old fuse comes out and isn't blown then put it back in. If it is blown but still doesn't work then it's not a fuse issue.
andyscooter
PostPosted: 20:03 - 25 Oct 2016    Post subject: Reply with quote
Very Happy f7 doesn't apper to do anything anyway
Guessing person who owned car had a bright idea
There isn't even any wires connected to it
I had a load of spare fuses from where I worked as I bought tem in bulk Laughing
techathy
PostPosted: 20:06 - 25 Oct 2016    Post subject: Reply with quote
Laughing Laughing
BTTD
PostPosted: 22:03 - 25 Oct 2016    Post subject: Reply with quote
Laughing Laughing
I've done that before when a fuse blew. Put a spare one in a blank spot for next time.
andyscooter
PostPosted: 07:57 - 26 Oct 2016    Post subject: Reply with quote
bingo on 19 but fuse 18 is fine and still no lightyuppy dashboard
which means something else is wrong Crying or Very sad
at least we have sorted that problem out Laughing
time to start looking at newer cars I think
andyscooter
PostPosted: 16:41 - 26 Oct 2016    Post subject: Reply with quote
had a few other fuses blow no2 and 22
changed them
now fuse 18 constantly blows Twisted Evil Twisted Evil
unplugged lighter socket same problem
had also got a blown bulb on number plate light
defiantly wiring problem so looks like its off to the scrappy for it
techathy
PostPosted: 18:04 - 26 Oct 2016    Post subject: Reply with quote
And what's common between F2, F18 & F22?... the instrument panel! Idea
andyscooter
PostPosted: 18:19 - 26 Oct 2016    Post subject: Reply with quote
Yep
Also explains the milage windback about three years ago from 40,000 til 0
Think Imay just scrap it
The last post was made 9 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 123.98 Kb
