Propane torch on a map cylinder?
cb1rocket
PostPosted: 09:22 - 27 Oct 2016    Post subject: Propane torch on a map cylinder? Reply with quote
Got myself a map cylinder as heard they heat up hotter than propane.
However I'm not sure i can use with my propane torch?
Any advice appricated.
Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852
smallfrowne
PostPosted: 10:27 - 27 Oct 2016    Post subject: Reply with quote
Aye there are different types. There are propane torches that normally you fit on a butane/propane mix cylinder, a camping gas type affair. And then there is a more pro type that you can get map cylinders for, or just propane. Different attachment type on each. What torch have ya got? I'm guessing you'll need a rothenberger superfire 2 torch or the likes.
I got one off ebay but they can be a little ££ if you only need it to do a single job. However, it is excellent for cooking pizzas too, so don't forget that.
'90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90
LongJohn22
PostPosted: 18:49 - 27 Oct 2016    Post subject: Reply with quote
Even better for lighting barbecues.
MCN
PostPosted: 19:28 - 27 Oct 2016    Post subject: Reply with quote
Gas torches are designed to burn specific fuels.
I am not certain of the sciency stuff but differing fuel need different quantities of oxygen to burn efficiently.
Acetylene and propane gas cutting torches are totally different animals too
cb1rocket
PostPosted: 14:01 - 28 Oct 2016    Post subject: Reply with quote
Ok thanks guy, seem like I'm getting a new torch as well then!
kramdra
PostPosted: 14:39 - 29 Oct 2016    Post subject: Reply with quote
Noone makes proper MAPP gas since 2008 so it will be a lpg/propane substitute anyway. Nice bit of accepted false advertising Laughing
You can use existing torch, mine was a shit bernzomatic brand torch, you may need to shorten the end as mapp/subsitue burn in a slightly more compact flame than propane.
cb1rocket
PostPosted: 19:11 - 29 Oct 2016    Post subject: Reply with quote
Ok thanks, good to know
The last post was made 9 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 50.79 Kb
