| Immoans |
 Immoans Derestricted Danger
| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
| Immoans |
| UnknownStuntm... |
 Posted: 11:06 - 27 Oct 2016 Post subject: Re: plugs |
Well, IMHO, if you change something and it DOESN'T work, change it back. Do not change anything else.
Having a bike that worked for 400 miles, changing the plugs, noticing a problem, then changing a carb, would seem to be 'a bit dippy'.
Check the plug is the right one for the engine. If the book doesn't say Iridum, don't put one in, no matter what the spotty fella at Halfords tells you.
Check to see if problem goes away. If not, put the original carb back on. |
| Immoans |
| UnknownStuntm... |
| Immoans |
| tom_e |
 tom_e Brolly Dolly
| Immoans |
| Wull |
 Wull Crazy Courier
| Immoans |
| wots |
 wots World Chat Champion
 Posted: 20:54 - 27 Oct 2016 Post subject: |
I've said this, from personal experience with a carb'd fireblade, carbs and iridium plugs do not mix. My fireblade lasted about 20 miles before going back to the WELL USED plugs and running much better.
A well respected friend disagrees with the above, but I'm going on my experience.
They work great in modern FI bikes, don't seem to like carb'd bikes. Get some standard plugs in there ASAP and go from there. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
| Immoans |
| Rogerborg |
 Rogerborg nimbA
 Posted: 21:33 - 27 Oct 2016 Post subject: |
I have no idea what you're saying about front and rear "heads".
Don't even think of touching the carb yet.
Is it running on both cylinders? Run it as hard as it'll go, then check (carefully) if both exhaust are hot.
Get the plugs out, see what colour the tips are, and if either is wet with unburnt fuel.
The HT caps melt when they get hot, take a look at them when you get the plugs out, and check for continuity (£5 multimeter, don't just guess).
It's probably not relevant, but that oil you put in it is way too techno, and it may cause clutch slip (i.e. it revs but doesn't accelerate). The cheapest 10W40 from Tesco will be fine in that engine.
Aside, the 2006 one that I worked on ("been standing for a bit, just needs a good run") was a complete dog and a money pit. While you're looking at yours, check that the swinging arm isn't rotting out in the centre. ____________________ Biking is 1/20th as dangerous as horse riding.
| Immoans |
| Rogerborg |
 Rogerborg nimbA
 Posted: 21:51 - 27 Oct 2016 Post subject: |
On the bright side, it's possible that you just have a loose plug cap after changing the plugs. But it's not something that can be diagnosed from those symptoms, you will have to get in there and test the continuity and spark on each plug. ____________________ Biking is 1/20th as dangerous as horse riding.
| tom_e |
 tom_e Brolly Dolly
| Rogerborg |
 Rogerborg nimbA
| tom_e |
 tom_e Brolly Dolly
| andyscooter |
 andyscooter World Chat Champion
| kgm |
 kgm World Chat Champion
| Nobby the Bastard |
| tom_e |
 tom_e Brolly Dolly
| Nobby the Bastard |
| pepperami |
 pepperami Super Spammer
The last post was made 10 years, 4 days ago. Instead of replying here, would creating a new thread be more useful? |
