| mudcow007 |
 mudcow007 World Chat Champion
| tom_e |
 tom_e Brolly Dolly
| chris-red |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 13:16 - 03 Nov 2016 Post subject: |
Blip the throttle to prevent this from happening.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
 Posted: 13:18 - 03 Nov 2016 Post subject: |
A few things going on there, all of which reduce available grip.
1) You're under braking so the weight is transferring off the back wheel onto the front one.
2) You're cornering so there is a lateral force on your tyre.
3) You are under engine braking so the tyre is decelerating, applying longitudinal force through the tyre. Effectively because the energy stored in the wheel was, as you say, pushing the engine around rather than the engine pushing the wheel around.
There is a finite amount of grip available which is a function of the road surface (type, temperature, surface conditions), your tyre compound and the amount of downforce (weight) on the wheel.
If the sum of the three factors I mentioned exceeds the grip, the tyre will stop grippiung and begin to slide. That's what happened. The road is cold and wet, you applied a greater than normal deceleration force through the tyre and started to lose grip. The next step is a slide.
Another factor, you still on a lightweight 100cc 2-smoke? Could've been the frame/swingarm/forks flexing under power on a corner. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MarJay |
 MarJay But it's British!
| RhynoCZ |
 Posted: 13:35 - 03 Nov 2016 Post subject: |
What the man above says.
When at high speed, the moment you disengage the clutch the revs drop, yet the wheel is still spinning quite fast. The moment you engage the cluch again, the engine has to match the speed of the wheel. It will eventually, but it also will lock up your wheel for a moment. It's quite like the other way around. Being stationary, rev the engine up and then just release the clutch lever.
Now, blip the throttle or release the clutch more sensibly. Especially when on a wet surface. Race drivers/riders used to blip the throttle when there was no such a thing as antihopping clutch. Bliping the throttle is way quicker than slipping the clutch. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| G |
 G The Voice of Reason
| mudcow007 |
| notbike |
 notbike World Chat Champion
| RhynoCZ |
 Posted: 14:43 - 03 Nov 2016 Post subject: |
One more thing, the gear downshift happens during the throtle blip. Practice holding the throttle grip and operating the brake lever with your middle, index or both fingers. I use the middle finger on the brake lever and the rest of the hand firmly holds the throttle.
The moment you get all this right, with a smooth downshift, you're gonna feel like your life is finaly complete.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| chris-red |
| mudcow007 |
| M.C |
 M.C Super Spammer
| thx1138 |
 thx1138 World Chat Champion
 Posted: 20:33 - 03 Nov 2016 Post subject: |
I made a mistake on my Honda the other day, been riding my 2stroke for the last fortnight and forgot that the engine braking on my Honda is relatively heavy in comparison, didn't exactly lock up, it just sort of 'complained to me' about it.  |
| G |
| Old Git Racing |
 Old Git Racing World Chat Champion
| Dave70 |
 Dave70 World Chat Champion
 Posted: 22:59 - 04 Nov 2016 Post subject: |
I accidentally did the same as OP once, I didn't like the result at all. I have no intention of trying to purposely carry out such a thing again. In fact, one of my life missions, is to make sure it never happens again.
Does this mean that I have to hand in my man card now.  ____________________ There ain't no devil, there's just god when he's drunk.
2012: R125 killed by white van. 2016 R125 killed by 30,000 miles of redline. Current: 2016 Kawasaki ER6f. |
| RhynoCZ |
 Posted: 23:22 - 04 Nov 2016 Post subject: |
| Dave70 wrote: | I accidentally did the same as OP once, I didn't like the result at all. I have no intention of trying to purposely carry out such a thing again. In fact, one of my life missions, is to make sure it never happens again.
Does this mean that I have to hand in my man card now.  |
*Warning, possible adult talk*
Not at all, some lads just like it rough, others prefer it smooth. I always try to be as smooth as possible, on a motorcycle being smooth gives you extra stability, in car it's just more comfort. Side effect of being smooth is being gentle to your engine, gearbox and final drive, as well as the rear tyre/s and suspension components.
Bouncing rear wheel of a motorcycle in front of a corner might be fun for some, but not for me. I blip the throttle all the time (when it's reasonable), it's a good habit for when the tar is slippery or wet.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| trevor saxe-coburg-gotha |
 Posted: 12:08 - 05 Nov 2016 Post subject: |
| RhynoCZ wrote: | | Dave70 wrote: | I accidentally did the same as OP once, I didn't like the result at all. I have no intention of trying to purposely carry out such a thing again. In fact, one of my life missions, is to make sure it never happens again.
Bouncing rear wheel of a motorcycle in front of a corner might be fun for some, but not for me. I blip the throttle all the time (when it's reasonable), it's a good habit for when the tar is slippery or wet.  |
I'm definitely getting old - I'm a recent convert to smooth is king. This in car and on bike. Before, "smooth" was a bit down the list of qualities to try and perfect. But for whatever reason (yes, age possibly being primary), it's become something I pretty much strive for.
Braking sooner - coming onto the brakes softer and earlier, and off again with more care. Sending the bike or car clear "hints" about what's going to happen - changes of direction, speed, both, etc. - before giving more emphatic inputs. Imo getting smoother entails better obs - more anticipation, looking further ahead, etc. But it's more directly physical than that, i.e. how your feet and hands go to work on the controls - making more graduated, considered - but still positive - movements.
Sounds boring as fuck? It kind of is. But otoh, it becomes strangely addictive - and you start to feel like this is the secret to being better in every sense. Safer, comfier (for passengers/pillions), and - yeah - faster.
At some level everyone knows how important smoothness is - but for me at least, it still wasn't something I consistently and diligently prioritised. E.g. fast was more important. Or (in the case of driving) just getting to the god damned destination (and thus being out of Ye Cage). But I'm now firmly of the view that - for me at least although probably most people too - being a decent, safe, fast rider or driver, is entirely dependent on being silky smooth. Exsqueeze the alliteration a sec, but concentration and commitment are crucial. Anyway yes it's taken me a bloody long time to grasp this smoothness thing, and embrace it. Pretty embarrassing in some ways - i.e. it's so obvious. Far from easy though - if only because you can always be smoother.
Also, it's a quite cerebral notion and somewhat at odds with the visceral thrills of "controlling" a vehicle. And it seems to require a degree of discipline that threatens to dilute the excitement and immediate gratification that you get from just fucking well caning the living shite out of it. But if you can find some way to think passed those tensions, smoothness - as an objective - soon prevails. Soz for unleashing the zeal of the convert here, and getting a bit spergy about it all, but this past few months have been a bit sort of damascene on the smoothness front.
https://i.imgur.com/bEqQYsk.gif ____________________ "Life is a sexually transmitted disease and the mortality rate is one hundred percent."
Mobylette Type 50 ---> Raleigh Grifter ---> Neval Minsk 125 |
| Fin |
 Fin World Chat Champion
| MCN |
 MCN Super Spammer
 Posted: 16:22 - 06 Nov 2016 Post subject: |
| stinkwheel wrote: | A few things going on there, all of which reduce available grip.
Another factor, you still on a lightweight 100cc 2-smoke? Could've been the frame/swingarm/forks flexing under power on a corner. |
Just to chuck the other important factor in to the equation.
When the tyre loses adhesion/grip with the road surface it also loses any braking force.
So the problem is ex-arse-abated. Until road speed slows to the the same speed as the tyre or the 'braking' force is removed/released.
The same principle applies to ABS and is why it is (can be ) advantageous for 'skidding' conditions. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
The last post was made 9 years, 340 days ago. Instead of replying here, would creating a new thread be more useful? |
