Whats One Of Dese
WildGoose
White Van Man
PostPosted: 19:48 - 26 Feb 2005    Post subject: Whats One Of Dese Reply with quote
basically, im in the process of taking apart my CBR, the frame mounting bolts have these annoying castilated nuts, haynes manual says you either need to make a tool yourself, or talk to honda, so i went to llyod cooper the local honda place, and got blank looks again Rolling Eyes
attached is the drawing of what i would call a peg-socket, but went around all the tool shops in town today and recieved blank looks
i know they exist, cos the seaking tool box has one in, not as big as 22mm though
https://www.bikechatforums.com/files/crudeness.jpg
excuse the crapness, but that should indicate the jist of it
its like a socket, but has 4 prongs extending from the top of it, kinda like a castle battlements or something
if anyone has one, or has seen where to get them, would be appreciated Thumbs Up
Stew
If it's good enough for top race teams...
PostPosted: 19:51 - 26 Feb 2005    Post subject: Reply with quote
Its a tool for a castle nut. Not sure exactly what its called but I have one.
If it's the same tool that is used for NC30 clutches then give me a shout and you can borrow mine. (PS its double sided, one side for the clutch the other for the swingarm pivot, I think).
"Unlike public school you don't need to have your arse up and your head down to go a long way...."
WildGoose
White Van Man
PostPosted: 19:53 - 26 Feb 2005    Post subject: Reply with quote
any chance you could take a quick snap of it stew
where did you get it from?
Stew
PostPosted: 19:55 - 26 Feb 2005    Post subject: Reply with quote
Think I got it from dave slivers when I ordered a new clutch.
I will go and grab it and take a snap. Smile
WildGoose
White Van Man
PostPosted: 19:57 - 26 Feb 2005    Post subject: Reply with quote
cheers matey Thumbs Up
mr.z
PostPosted: 19:59 - 26 Feb 2005    Post subject: Reply with quote
Its the same tool you can buy from honda or make yourself, only ever seen it being used to looseten the clutch (cg125/cx500/xl600) probably just a standard honda part...
If you get some pipe the right diameter and a dremel or even a hack-saw and just make one... you can use a hammer and a flatblade screwdriver on any notch carefully, but only if your really desperate imo hammers, screwdrivers and delicate engine innards should never meet!
I'm supprised a honda dealership didn't know what you meant! afaik its use for most if not all older hondas for the clutch... Question
Stew
PostPosted: 20:04 - 26 Feb 2005    Post subject: Reply with quote
Here are the pics.
WildGoose
White Van Man
PostPosted: 20:18 - 26 Feb 2005    Post subject: Reply with quote
nice one stew, that looks like the boy
zero, yeh i was surprised too, but they are mostly monkeys in my experience
at least now i have a photo of the exact thing Smile Thumbs Up
Claud 14.7 to 1
PostPosted: 21:02 - 26 Feb 2005    Post subject: Reply with quote
What's going on with the CBR mate?
Yer you can make one of those up: socket + angle grind/Dremel.
I made up something like that for the plugs. Course it would be much easier to borrow the proper tool for your frame. Wink
PostPosted: 21:12 - 26 Feb 2005    Post subject: Reply with quote
Hideously expensive, but available from Demon Tweeks. £35~£40 though!
PostPosted: 21:14 - 26 Feb 2005    Post subject: Reply with quote
I believe it is called a 'castellated socket'.
In the TT600 workshop manual it simply calls it a "Engine mount adjuster socket". Hookay! Laughing
WildGoose
White Van Man
PostPosted: 23:38 - 26 Feb 2005    Post subject: Reply with quote
yeh, any number of stupid names
claud, its coming apart, cos its dirty, and cos im curious, and cos i can
i will decide at a later date if i can be bothered putting it back together Razz
thanks for that link keith, never found it before
PostPosted: 00:53 - 27 Feb 2005    Post subject: Reply with quote
Or Honda part number: 07716-0020100
You can tell the honda dealers next time you are in. Try getting a price on a proper Honda one, bound to be good for a laugh!
Stew
PostPosted: 01:03 - 27 Feb 2005    Post subject: Reply with quote
Or, as I say, borrow it from me. Smile
wildcat
PostPosted: 09:58 - 27 Feb 2005    Post subject: Reply with quote
Confused I don't know if this would work but have you tried a flat head screw driver? As long as it's as wide or wider than the diameter of the castellated nut it should catch and turn it for you.
Worth a try, if you don't want to spend a lot of money on the tool.
https://www.bebo.com/Z1000-Wildkat
WildGoose
White Van Man
PostPosted: 13:30 - 27 Feb 2005    Post subject: Reply with quote
wouldnt work, as the centre of the nut is raised if you see what i mean, hence why you need the special tool
The last post was made 21 years, 229 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 3.64 - MySQL Queries: 15 - Page Size: 88.91 Kb
