what size zipties do tucano urbano mitts take?
Wonko The Sane
PostPosted: 18:25 - 07 Nov 2016    Post subject: what size zipties do tucano urbano mitts take? Reply with quote
I'm at work and wanting to swipe a couple of zip ties before going home but not sure what thickness zip ties the tucano urbano mitts take
anyone know?
DrDonnyBrago
PostPosted: 18:30 - 07 Nov 2016    Post subject: Reply with quote
The neoprene must be a different design? The big furry muffs can take whatever you are packing.
PostPosted: 19:09 - 07 Nov 2016    Post subject: Reply with quote
The neoprene muff must be a bit tighter. You could use the palm of your hand to bash the muff on. I've had varying degrees of success using my fist.
Wonko The Sane
PostPosted: 21:28 - 07 Nov 2016    Post subject: Reply with quote
The ones I have use a little lock-ring held together by zip tie to hold them on at the switch side of the grip - still got the rubber bung to stretch over the bar end at the outer edge
Andy_Pagin
PostPosted: 22:43 - 07 Nov 2016    Post subject: Reply with quote
Same as mine, they take a very thin cable tie, the only one's I've found that fit are way too short so I have to chain three together.
-Matt-
PostPosted: 18:27 - 08 Nov 2016    Post subject: Reply with quote
I never fitted or used them properly, but the cable ties that came with my pair are 250mm x 3mm.
kawakid
PostPosted: 01:51 - 12 Nov 2016    Post subject: Reply with quote
I have had the same problem this week.
The ones the come with the muffs fit, but normal ones don't.
Go to pound world, they do a set of small cable ties that consists of tiny ones in different colours and in the same pack in the middle they have long thin black ones.
These fit.
If I remember tomorrow I'll try to update this post with a pic.
I've a twin and a 4.
The last post was made 9 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 52.71 Kb
