Cooling system sealants...
RhynoCZ
PostPosted: 14:56 - 15 Nov 2016    Post subject: Cooling system sealants... Reply with quote
Has anyone ever successfully used one of those ''pour into the cooling system'' sealants?
I have a small leak in my car's cooling system and it's too cold for me to work on it at the moment. The radiator has a wet spot on it, so I think a small stone or previous owner damaged the radiator and as it gets colded outside, the leak got present/noticeable. I already cleaned the whole engine to deremin, where the leak is comming from and I'm 99.9% sure it's the radiator.
Q: I have here a Sonax cooling system sealant, that you pour into the coolant (into the expansion tank, in my case), so...
1) Will this feck up the engine?
2) Will it just do nothing?
3) Will it work?
PostPosted: 15:22 - 15 Nov 2016    Post subject: Re: Cooling system sealants... Reply with quote
Yes. I poured in whatever my local petrol station was selling, and it sealed a leak in my Citroen radiator without causing any problems until I scrapped it a few years later for being a Citroen.
RhynoCZ
PostPosted: 19:15 - 15 Nov 2016    Post subject: Reply with quote
Well, poured it in. I had to take the hose from the head to the radiator off and pour it there, as they say it's supposed to go directly into the radiator. Had a hour drive in the car, now we'll wait. For obivous reason, when the engine is hot, there's no leak. It's the cooling down, that opens the little cracks. Thumbs Up
Thanks Roger,
PostPosted: 21:14 - 15 Nov 2016    Post subject: Reply with quote
Even cracking a raw egg into the radiator works. Seen it done.
PostPosted: 21:22 - 15 Nov 2016    Post subject: Reply with quote
^^^Just the egg white...can get smelly if you add the yolk.
PostPosted: 21:36 - 15 Nov 2016    Post subject: Reply with quote
I used radweld on a Mk1 Goldwing many years ago Thumbs Up
No problems.
RhynoCZ
PostPosted: 21:42 - 15 Nov 2016    Post subject: Reply with quote
I thought the egg into the radiator was just a urban myth. Thinking
RhynoCZ
PostPosted: 00:26 - 16 Nov 2016    Post subject: Reply with quote
Read above, already done.
Also, the manual said specifically to turn the heater on, as it seals the heater core as well. Let's hope I did not feck up the engine. Thumbs Up
stevo as b4
PostPosted: 00:48 - 16 Nov 2016    Post subject: Reply with quote
Tbh if a manufacturer of expensive performance engines is using a plastic water pump impeller and pump body housing too, they are simply not worth buying their products, as you'd have to think what other engine and ancillary parts are they scrimping on?
I used K-seal as a very short term temporary part fix on a Rover K-series engine once. But it has very mixed reputation and results, and is probably better suited as a gasket and leak sealant on a simpler dimensionally stable engine that has fewer potential ways of failure.
RhynoCZ
PostPosted: 13:30 - 17 Nov 2016    Post subject: Reply with quote
And so far, it still leaks. Thumbs Down
A new radiator it is, then.
DrSnoosnoo
PostPosted: 13:50 - 17 Nov 2016    Post subject: Reply with quote
If you're resorting to a new rad, try the egg trick. It's scrap anyway, to you so run the experiment. Pleeeasseeee.
RhynoCZ
PostPosted: 14:49 - 17 Nov 2016    Post subject: Reply with quote
Yes Doctor, but wouldn't the egg mess up the whole cooling system as well as the radiator? All the hoses, lines, the head, cylinders, coolant pump...? Smile
stevo as b4
PostPosted: 15:43 - 17 Nov 2016    Post subject: Reply with quote
A new cheap rad from your local factors, maybe two hoses if they look perished, and an hours work on the drive will have the job done.
You love old Merc's so it would be silly to kill one seeing as they generally go on forever with the occasional service. Sadly they still can't cool the engine without water, I'm not sure any manufacturer has perfected this feat either.
Good job you ain't got a K-series in your benz, lose a pint:lose an engine is a fair and accurate motto for these.
DrSnoosnoo
PostPosted: 15:51 - 17 Nov 2016    Post subject: Reply with quote
Nah the hot water in the rad will instacook the egg and it won't be anything that you couldn't flush out of the system anyway.
tom_e
PostPosted: 16:29 - 17 Nov 2016    Post subject: Reply with quote
You mean apart from all those air cooled engines right? Laughing
stevo as b4
PostPosted: 17:21 - 17 Nov 2016    Post subject: Reply with quote
I thought it was obvious we were talking about modern car engines though? I didn't explicitly specify though so the twat hat is on me if that makes you feel a little bit better inside? Wink
tom_e
PostPosted: 17:22 - 17 Nov 2016    Post subject: Reply with quote
It does thank you Thumbs Up Smile
The last post was made 9 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 100.08 Kb
