Running out of time
Marc_Buck
PostPosted: 14:19 - 27 Feb 2005    Post subject: Running out of time Reply with quote
Bike MOT monday at midday and the wheel and tyre is sitting in my bedroom, i cant for the life of me get it on.
Its an rxs100 with an innertube, where on sunday can i get this done?
I have till 12pm tomorrow to get it on.
Rolling Eyes
94 fzr600r
Sadie
PostPosted: 14:28 - 27 Feb 2005    Post subject: Reply with quote
Bit difficult to help as I don't know where you are but you must have a tyre shop such as Stapletons near you. Perhaps they could help in the morning.
With experience comes age.
Marc_Buck
PostPosted: 14:29 - 27 Feb 2005    Post subject: Reply with quote
My local tyre shop jet tyres is full of fat twats, know shit and when trying to put it on will probably rip the tube.
Seriously have a guess who does bikes there, a 16 year old kid, they let him loose on an r1 exhaust once too.
94 fzr600r
Scotsman37
PostPosted: 14:31 - 27 Feb 2005    Post subject: Reply with quote
Do you mean you can't get the tyre with the innertube back onto the wheel ?
Have you tried some furniture spray polish because that will allow the tyre to slip over the rim of the wheel - spray on the tyre's rim and the wheel's rim if necessary.
If you still can't get the tyre back on the wheel take it your nearest bike dealer/garage and explain to them that you need it done because it's an emergency !
Marc_Buck
PostPosted: 14:33 - 27 Feb 2005    Post subject: Reply with quote
I cant get the tyre back over the rim, it just doesnt go......
6 months to get the bike ready for mot failed last week on front tyre and now i get new one and cant get int on Laughing
So with the furniture polish shall i just polish up the rim or just spray it on and leave it wet?
94 fzr600r
Scotsman37
PostPosted: 14:35 - 27 Feb 2005    Post subject: Reply with quote
leave it wet to allow it slip on ! Smile
Marc_Buck
PostPosted: 14:43 - 27 Feb 2005    Post subject: Reply with quote
Oh its working, just still cant get about 1/4 of the tyre on.
94 fzr600r
mchaggis
PostPosted: 14:47 - 27 Feb 2005    Post subject: Reply with quote
A mallet might be of use. I presume you are using tyre levers?
Hitting it and jumping up and down are always useful techniques with these things. Embarassed
I must not be a troll...
Mmmm, Guinness
Scotsman37
This is where an extra set of hands and several tyre levers come in handy and so get someone to help. I would invest in a tyre bead breaker from Abba Stands to help you in the future when nobody is around as it will make light work if it taking it off or putting it back on again !
https://www.abbastands.co.uk/products.htm
Marc_Buck
PostPosted: 14:54 - 27 Feb 2005    Post subject: Reply with quote
Asked my dad to help and he ends up making it worse.
Now i have half of one side on, saw hands a snapped tyre lever, with 2 left.
A dad thinking hes helped and about 3 hours tomorow to get it put on.
94 fzr600r
Scotsman37
PostPosted: 15:03 - 27 Feb 2005    Post subject: Reply with quote
You need to get better tyre levers than that because they must be made of cheap alloy metal to have broken and so best to get ones made of steel instead the next time round. Was that broken tyre lever actually designed for a bicycle's tyre or motorcycle tyre because a bicycle one is usually made of cheap alloy metal because it's not put under to much strain.
Have you got nothing else lying around that could do the same job or can you invest in buying some more motorcycle tyre lever
You maybe have to take your tyre & wheel to the nearest biker dealer/garage to have them fit it.
So the next time around do what I suggested in investing in a bead breaker.
Marc_Buck
PostPosted: 15:04 - 27 Feb 2005    Post subject: Reply with quote
Just cheap metal ones, whats a bead breaker?
94 fzr600r
Scotsman37
PostPosted: 15:06 - 27 Feb 2005    Post subject: Reply with quote
https://www.abbastands.co.uk/Images/beadbreakerLg.jpg
Scotsman37
PostPosted: 15:18 - 27 Feb 2005    Post subject: Reply with quote
I know that Halfords sell tyre levers but make sure it's one that you use on car/motorcycle tyres.
The online shop The Fast One sell ones made by Draper made of hardened steel for £18.99 - FastOne Order Code: (530904)
https://www.thefastone.co.uk
M & P also them for £17.99
https://www.mandp.co.uk/productInfo.aspx?catRef=530904
Tooled Up dot Com sells the Draper Tyre Levers for £14.64
https://www.tooled-up.com/Product.asp?PID=15254
Also, they sell another make of a similar type called Elora for £11.47
https://www.tooled-up.com/Product.asp?PID=14768
PostPosted: 15:40 - 27 Feb 2005    Post subject: Reply with quote
You sure you have the right size tyre? An RXS100 tyre should almost push over the rim by hand.
Lay the wheel down on the floor.
Clart damp soap all the way round the rim.
Push one bead over the rim, start at one point and move round gradually with the heels of your hands working the bead down in both directions until you can't get any more on.
Make sure that the bit you started on is pushed as far down into the recess in the middle of the rim as possible.
Now "walk" the rest of the bead over the rim by alternatley pushing your weight onto the bead on either side with your heels.
You might need to 'pop' the last couple of inches over the rim with a tyre lever, remember to keep pushing the bead down into the centre of the rim to give you more space.
Put some talcum/powdered chalk on the tube and install it (stops it sticking to stuff).
Push the second bead over in the same way, ensure you don't catch the tube under it.
If I can fit a 160/80/17 MEZ1 (with tube) to my supermoto using two tyre levers (and admittedly a lot of swearing), you can manage a RXS100
Zoffo
PostPosted: 15:42 - 27 Feb 2005    Post subject: Reply with quote
There's no panic. As long as you are on your way to a booked appointment with a garage you can ride to the appointment even after them MOT expiry date but not use it for anything else. So if you have to get the tyre fitted on Monday and can't get to the MOT untill tuesday you'll be ok as long as the trip to the garage is the only time you use the bike.
jay12329
Dr. Evil
PostPosted: 15:51 - 27 Feb 2005    Post subject: Reply with quote
Just a numpty idea, the inner tube is deflated isnt it? I spent hours trying to get my push bike tyre on then realised the inner tube was about half inflated. i took the air out of it and the tyre slipped in to place realy easily!
HTH
J
crow69
PostPosted: 16:53 - 27 Feb 2005    Post subject: Reply with quote
r u keeping the area of the tyre that u pushed on in the centre of the rim ... not trying to press tyre on with it in the seating area ?
Marc_Buck
PostPosted: 23:03 - 27 Feb 2005    Post subject: Reply with quote
It's the right size, tube deflated im doing it all correctly, just i dont seem to be strong enough, and im not weak either.
I have a mate works at a tyre place, im taking it down at 10am tomorow, ready to fit to bike and ride it to the MOT at 12pm.
I have also discovered a new problem, upon replacing all the split pins, one has rotted and snapped inside the rear wheel spindle, i have no idea how to get it out, nothing is working.
94 fzr600r
mrchips
PostPosted: 00:24 - 28 Feb 2005    Post subject: Reply with quote
Fairy Liquid round the rim and tyre seating and use two screwdrivers.
Northern Irish? www.nibikers.com
The last post was made 21 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 101.58 Kb
