Moving Handlebars Backwards
james1988
PostPosted: 20:23 - 21 Nov 2016    Post subject: Moving Handlebars Backwards Reply with quote
Evening All,
I ride a Honda Varadero and find the reach to the handlebars a little bit of a stretch, I could do with moving the bars back by about 30mm (stumpy arms!). I've found that SW Mototech do risers that move the bars backwards but the bars are the perfect height as they are so I don't want to raise them if I can help it.
Is there anything out there that would allow me to move the bars backwards without raising them too?
Any help would be appreciated!
James
Honda XL1000VA '07
Pjay
PostPosted: 20:26 - 21 Nov 2016    Post subject: Reply with quote
Those risers rise because when you roll the bars back towards you, they drop in height.
Buy the risers.
james1988
PostPosted: 21:00 - 21 Nov 2016    Post subject: Reply with quote
I never realised that. I've not had any experience with risers in the past so this is new to me.
Thanks for the advice! Smile
James
Honda XL1000VA '07
PostPosted: 23:15 - 21 Nov 2016    Post subject: Reply with quote
Just loosen the handlebar clamps and move the bars back until you are happy.
If you can't get it comfy, you need the risers.
james1988
PostPosted: 00:03 - 22 Nov 2016    Post subject: Reply with quote
I was unaware they moved backwards. I had always assumed that they were meant to be in that position. Embarassed
James
Honda XL1000VA '07
Raffles
PostPosted: 00:09 - 22 Nov 2016    Post subject: Reply with quote
Do bear in mind, James, that raising and or moving the bars back may create problems with throttle and clutch cables as well as L/H and R/H switch wiring etc.
james1988
PostPosted: 00:15 - 22 Nov 2016    Post subject: Reply with quote
Raffles wrote:
Do bear in mind, James, that raising and or moving the bars back may create problems with throttle and clutch cables as well as L/H and R/H switch wiring.
I'd thought of that and had put off buying them for sometime as I'm concerned I'd have to shell out on brake lines and other various bits if they're too far back.
James
Honda XL1000VA '07
Dave_80
PostPosted: 01:51 - 22 Nov 2016    Post subject: Reply with quote
I rode a bike fitted with risers fitted and the steering felt a lot sharper/twitchier compared to the standard bike,don't know if it would affect you or your bike but something to bear in mind.
Honda CB750 F2X
Pjay
PostPosted: 09:59 - 22 Nov 2016    Post subject: Reply with quote
Yeah good point, but it is only 30mm he wants to travel, so chances are good that it will have that amount of play.
James, try it and see, with full turns to make sure nothing catches on each lock. Brake lines are a lot easier to change over than clutch cables and the electrical wiring is harder still, but don't let that bother you too much. If the current position is bothering you, then slowly buy the bits you need until you have everything and then get it done in a single hit. Don't try and bodge it piece by piece, as this could give you handling problems.
Chances are though it should be fine just moving them 30mm, but I'd make sure the cables don't then rub on the tank, as that soon starts leaving a mark.
PostPosted: 10:28 - 22 Nov 2016    Post subject: Reply with quote
Looking at this picture, I very much doubt there will be any issues just moving the bars back 30 degrees.
https://www.huntercreate.com/Images/photo-gallery/1%20John%20Cusick%20Honda%20Varadero%20XL125%20V6.jpg
james1988
PostPosted: 12:08 - 22 Nov 2016    Post subject: Reply with quote
I'll upload a photo of the bike when I get home from work. I'd imagine there'll be room for manoeuvre. I'm ok when it comes to spannering not totally amateur but wouldn't call myself advanced (I carry out my own servicing etc).
The reason I want to move them back is because there is a little bit of a stretch to the bars which is causing my neck and shoulder to ache around half way through ride outs- we normally do 4-5 hours riding at a time to put it into perspective.
Honda XL1000VA '07
Baffler186
PostPosted: 12:23 - 22 Nov 2016    Post subject: Reply with quote
Adjust bars to suit, remember that you'll have to slacken off and re-position switchgear and levers. Then with engine running turn the bars lock to lock (carefully) and check nothing is fowling or pulling i.e. cables. I think they'll be fine though if the (now lower) bar ends don't hit anything at full lock.
I'd also make sure the brake fluid reservoir is pointing straight up as before
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
james1988
PostPosted: 12:31 - 22 Nov 2016    Post subject: Reply with quote
Here is a photo I found on my phone of the bars as they currently are:
https://c4.staticflickr.com/6/5562/31173912915_fab2ed8e4e_h.jpg
2016-11-22_11-22-37
James
Honda XL1000VA '07
PostPosted: 13:50 - 22 Nov 2016    Post subject: Reply with quote
That is the Varadero 1000 then.
I'm presuming those 4 round discs pop out to reveal allen bolts. Found it.
https://www.bike-parts-honda.com/thumbs/h/motog/13MBT3S1/IMGE/720_280/F__0600.png
james1988
PostPosted: 20:16 - 22 Nov 2016    Post subject: Reply with quote
I've just been out to the garage and have managed to get the bars into a comfortable position without them fouling anything.
Thanks for the help all, that's quite a bit of cash saved!
James
Honda XL1000VA '07
recman
PostPosted: 21:34 - 22 Nov 2016    Post subject: Reply with quote
james1988 wrote:
...quite a bit of cash saved!
James
Excellent, I have the perfect investment opportunity...
PostPosted: 12:07 - 23 Nov 2016    Post subject: Reply with quote
recman wrote:
James
Rainfriend?
sickpup
Old Timer
PostPosted: 14:38 - 23 Nov 2016    Post subject: Reply with quote
Other than them hitting the tank, thats why it has cut outs in the tank afterall but they are only for the original position.
The last post was made 9 years, 326 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 96.17 Kb
