| james1988 |
 james1988 World Chat Champion
| Pjay |
 Pjay World Chat Champion
| james1988 |
 Posted: 21:00 - 21 Nov 2016 Post subject: |
I never realised that. I've not had any experience with risers in the past so this is new to me.
Thanks for the advice!
James ____________________ Honda XL1000VA '07 |
| Polarbear |
 Polarbear Super Spammer
| james1988 |
| Raffles |
 Raffles World Chat Champion
| james1988 |
| Dave_80 |
 Dave_80 Renault 5 Driver
| Pjay |
 Posted: 09:59 - 22 Nov 2016 Post subject: |
| Raffles wrote: | Do bear in mind, James, that raising and or moving the bars back may create problems with throttle and clutch cables as well as L/H and R/H switch wiring etc. |
Yeah good point, but it is only 30mm he wants to travel, so chances are good that it will have that amount of play.
James, try it and see, with full turns to make sure nothing catches on each lock. Brake lines are a lot easier to change over than clutch cables and the electrical wiring is harder still, but don't let that bother you too much. If the current position is bothering you, then slowly buy the bits you need until you have everything and then get it done in a single hit. Don't try and bodge it piece by piece, as this could give you handling problems.
Chances are though it should be fine just moving them 30mm, but I'd make sure the cables don't then rub on the tank, as that soon starts leaving a mark. |
| Polarbear |
| james1988 |
| Baffler186 |
 Baffler186 World Chat Champion
| james1988 |
| Polarbear |
| james1988 |
| recman |
 recman World Chat Champion
| Polarbear |
| sickpup |
 sickpup Old Timer
 Posted: 14:38 - 23 Nov 2016 Post subject: |
Other than them hitting the tank, thats why it has cut outs in the tank afterall but they are only for the original position. |
The last post was made 9 years, 327 days ago. Instead of replying here, would creating a new thread be more useful? |
