Installing handwarmers - how to "cut in"
mudcow007
PostPosted: 13:22 - 24 Nov 2016    Post subject: Installing handwarmers - how to "cut in" Reply with quote
This morning was baltic like cold here, my balls only started coming down from inside of my chest by about 10am
Anyways, i have got me a cheap set of handwarmers from fleabay, which came with absolutley no instructions whats so ever, but would presume the "live" wire needs to be cut into a switched live on the bike (and fused too)
Should this be done with a scotchlok? personally i hate them as ive cut through wires with them in the past
Suggestions an answers on a postcode card
ADSrox0r
PostPosted: 13:27 - 24 Nov 2016    Post subject: Reply with quote
Do a proper job, strip right back and lineman splice it in with a nice bit of solder and heatshrink.
Or don't. Up to you really.
PostPosted: 13:29 - 24 Nov 2016    Post subject: Re: Installing handwarmers - how to "cut in" Reply with quote
Go with a fused relay, e.g. https://www.ebay.co.uk/itm/111581062672 (but fit a 5A fuse).
Procedure is as per stinkwheel's excellent guide:
https://www.bikechatforums.com/viewtopic.php?p=2444272
I use them now because bish-bosh, you're done, except when you're not, in which case you're no worse off than you would have been anyway.
UnknownStuntm...
PostPosted: 13:36 - 24 Nov 2016    Post subject: Reply with quote
I'd use something like these: https://www.screwfix.com/p/c-k-automatic-wire-stripper/97204?kpid=97204&cm_mmc=Google-_-Product%20Listing%20Ads-_-Sales%20Tracking-_-sales%20tracking%20url&gclid=Cj0KEQiAvNrBBRDe3IOwzLn6_O4BEiQAmbK-DlG7xzRSXUJtW-RY1mV6Cb9Gj0kPOdqTOnl3V6igBOQaAlWO8P8HAQ
strip a small opening in the wires, solder, heatshrink and insulation tape. Anything that makes heat has the ability to draw a fair bit of current. And scotchlocks aren't really designed for current.
And I don't care what their marketing department say.
If you must "splice in".
Replace a single terminal with a double one.
Or cut the wire and re-join it with a double terminal.
My heated grips can draw up to 3A so make sure whatever wire you are attaching to can cope with that AND the current it's already carrying. A relay is better.
mudcow007
PostPosted: 14:28 - 24 Nov 2016    Post subject: Reply with quote
Awesome Thumbs Up I had forgotten about that awesome wiring guide.
Next question - which is probably stupid but hey ho, do the heating elements go :- on top of the grips or underneath.
Im guessing the cheap nasty ones i have bought go on top as they have come with a pair of novelty size heat shrink, which im guessing is designed to go over the grips?
Suppose if they go over the grip they arnt then heating the bars?
PostPosted: 14:34 - 24 Nov 2016    Post subject: Reply with quote
Over the grips. If they're the same as the ones I just fitted, then you want the wires elements on the inside, facing the grips. The pads curve easily in that direction, but not the other way. A hairdryer should be sufficient for the shrink wrap, although I used a scorchy hot air gun.
I'd only ever use one to trigger a relay.
mudcow007
PostPosted: 15:50 - 24 Nov 2016    Post subject: Reply with quote
Yeah pretty much them. Do they work?
Ive had mine connected to a UPS battery in my office to see how warm they get - which is pretty warm.
God knows what they would be like being used in anger though
PostPosted: 16:22 - 24 Nov 2016    Post subject: Reply with quote
Yup. Single heat setting, they get quite toasty after about 20 minutes, but you can slum it and just flick them off and on to keep the temperature comfortable. I'm using them under muffs, for which they're perfectly adequate.
I had a similar set on my Burgman which stopped functioning after one winter, although I didn't check if the elements had burned through if it my hooky wiring had given up - at that price they're essentially disposable anyway.
PostPosted: 16:26 - 24 Nov 2016    Post subject: Reply with quote
How the fuck can they supply that for £2.16p with free postage from China and still make money Shocked
Triumph Trophy Launch Edition
PostPosted: 16:53 - 24 Nov 2016    Post subject: Reply with quote
Huzzah for child labour. It even comes with what small roll of what seems to be self-amalgamating tape. Hang fire, I've not had them on for long, but no problems so far. It's just some pieces of wire in the final analysis, there's nothing complicated in there, and nor does there need to be. All electrical heaters are near enough 100% efficient.
tom_e
PostPosted: 16:55 - 24 Nov 2016    Post subject: Reply with quote
Postage is heavily subsidised by the Chinese government so they can pump shit out cheap as chips once you factor in slave labour as well.
mudcow007
PostPosted: 15:52 - 28 Nov 2016    Post subject: Reply with quote
Mission is a success Thumbs Up
As per "Stinkies" guide, I installed the hardwarmers with use of a relay.
Weirdly the relay i bought had a built in 30A fuse Shocked . I swapped that out for a 5A, an just because i had one, also fitted an inline jobbie too
The heaters work a treat, but I dont like them. It feels weirdly having warm sweaty palms an freezing cold finger tips
PostPosted: 16:26 - 28 Nov 2016    Post subject: Reply with quote
Bring it, Winter.
The last post was made 9 years, 256 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 88.02 Kb
