| Tierbirdy |
 Tierbirdy Crazy Courier
 Posted: 19:08 - 28 Nov 2016 Post subject: FZS600 rear calliper seized to fek |
2001 FZS600 Fazer
I decided it was time to change the pads, and upgrade to braided hoses whilst I was at it... treat her right and shell treat you right etc.
Boy was I wrong.
I'm now experiencing the joy I assume most Fazer owners experience at some point.
Seems the pistons are siezed to absolute fuck in the rear calliper. The rear brakes have always been a bit shitty and weak, I just assumed thats the way they were. Though looking at this I think its safe to say they just never really moved much due to corrosion.
Looking at this pic it also seems like theres random bits of o-ring/seal poking out from the piston, now Im no expert but that dont look right to me?
https://i.imgur.com/CCEJVpb.jpg
What the fuck has happened to cause those seals to be jammed out like that, and how do I fix this?
Conversely the front brakes and their sensible slot design and nice big drainage hole so they dont sit in a bath of salty road water for months, changed over in seconds
Do I even bother trying to fix the rear? Or do I just buy an FZ1 blue dot calliper for the rear? |
| Fizzer Thou |
 Posted: 19:50 - 28 Nov 2016 Post subject: |
It looks like so much corrosion has built up behind the seals that they have been forced out into that very small gap between the piston and the caliper body.
I had a similar problem with a caliper on a friends bike.I removed the caliper and worked on it on the bench,forcing the piston past the distorted seals.
A replacement caliper from eblag might be the best bet as it would be more expensive to buy new pistons and seals
Are you in London or the West country? ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| Tdibs |
 Tdibs Traffic Copper
 Posted: 20:29 - 28 Nov 2016 Post subject: |
You need to rebuild the whole caliper. Sounds hard, its not really though.
Spray a ton of brake cleaner in there first and keep pumping your rear brake (put a block of wood where the pads would normally be to stop one/both coming out straight away). until you get movement.
The seals are toast though, its because there is loads of dryed out crap in the seal ring that has expanded and forced your dust seal out.
The pistons actually look pretty good condition to me, you would have to see if there is any really bad pitting once you have cleaned them up though.
Time to youtube rebuilding motorcycle caliper
Good luck!
Edit: good to see the bleed nipple came out and did not snap, tis a bastard when that happens. ____________________ Previous : 09 Vanvan 125| 02' Sv650s || Current: 1999 Xj600n | 1992 DR650 RSE | 2005 Fazer 1000 |
| Shinigami |
 Shinigami World Chat Champion
| Tierbirdy |
| davebike |
 davebike World Chat Champion
 Posted: 08:45 - 29 Nov 2016 Post subject: |
Used calliper is a good bet
Strangely enough there is a FZS600 on the bench this morning my business partner having just changed the swing arm and It has a broken bleed screw so that is one fro me this morning )
If you cannot DIY it feel free to PM me I ran a repair business fro thirty years Currently @ SE20 8JY ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| Tdibs |
| CaNsA |
 CaNsA Super Spammer
| wots |
 wots World Chat Champion
| pompousporcup... |
 pompousporcup... World Chat Champion
 Posted: 15:38 - 29 Nov 2016 Post subject: |
Have a search on youtube for Delboys garage (moonfleet41). He has done various vids on how to rebuild calipers properly, and i know theres defo one for the a rear caliper
Just watching someone else do it first helped ease a bit of the stress of going in blind... brakes are important so im told  |
The last post was made 9 years, 259 days ago. Instead of replying here, would creating a new thread be more useful? |
