| colink98 |
 colink98 Could Be A Chat Bot
 Posted: 17:19 - 29 Nov 2016 Post subject: Exhaust blowing |
My CBF600 is a little on the old side so i don't get too fussed about it being a bit noisy, However i think its developed a bit of a blow from the exhaust.
https://youtu.be/9Mlg-x07fr8
that flange the holds the exhaust in place doesn't look too secure either.
second opinions please. ____________________ PCX125 (stolen) - CBF600 (current)
Ride it like you stole it.
ride sensible and not like an idiot and you wont get 6 points in one week. |
| ADSrox0r |
 ADSrox0r World Chat Champion
 Posted: 19:36 - 29 Nov 2016 Post subject: |
Yup, looks like it's the joys of removing corroded exhaust studs for you sunshine  ____________________ Current bikes: '08 VFR 800 VTEC(yo) , '07 ZZR1400 Winter hack: '95 Aprilia 650 Pegaso Currently lusting after: RC30 |
| Baffler186 |
 Baffler186 World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 21:31 - 29 Nov 2016 Post subject: |
Sounds like the header tops have rotted out. Find some new downpipes before you touch it is my advice. ____________________ a.k.a 'Geri'
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 22:37 - 29 Nov 2016 Post subject: |
To take the exhaust off, safely. Spray all the nuts with WD40 / or penetrating oil and let it sit before you attempt to take them off (it helps if you tap the nuts with a hammer before you try to move them). After that, get the right size socket, or use a spanner, and now, you want a instant torque there to break the tension. So put the socket/spanner onto the nut, make sure the socket/spanner sits on the nut firmly at 90° and give it a impact/vigorous twist. This will break the tension and won't harm the studs and/or nuts.
DO NOT just slowly turn the wrench/spanner.
DO NOT use a long bar.
Broken studs and stripped nuts are nothing fun to deal with, especially when the studs break near the head. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| colink98 |
| Polarbear |
 Polarbear Super Spammer
| colink98 |
| RhynoCZ |
 Posted: 10:57 - 30 Nov 2016 Post subject: |
I see, well I would be taking the exhaust off to make a visual check of the exhaust seals then. Who knows how sloppy the mechanic was.
I know you do not want to do any of that, so just clean the studs (take the desired nuts off before you do) and give it proper Nm of torque.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| colink98 |
| skatefreak |
 skatefreak World Chat Champion
 Posted: 11:47 - 30 Nov 2016 Post subject: |
Had to get the headers off my F3 this summer.
5 out of 6 studs backed out of the head and one snapped.
Ended up welding half a stud onto the broken one .
Is it particularly common for the studs to back out of the head before the nuts break free? |
| RhynoCZ |
 Posted: 12:08 - 30 Nov 2016 Post subject: |
| skatefreak wrote: | Had to get the headers off my F3 this summer.
1) Lube the nuts (WD40 or penetrating oil) and let them sit,
2) Tap them with a hammer,
3) Take them off.
Now tell us, did you bother with the first 2 steps or you just went straight to no. 3?  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:26 - 30 Nov 2016 Post subject: |
Is barely better than nothing. You might as well recommend using coca-cola, or vinegar, or whatever else is in the kitchen.
Buy some PlusGas. It'll be far cheaper and more convenient than dealing with a snapped stud.
Consider cutting any accessible nuts off. You can use a dremel to do it neatly and fairly quickly (compared to drilling out a snapped stud in situ, anyway). ____________________ Biking is 1/20th as dangerous as horse riding.
| skatefreak |
 Posted: 13:28 - 30 Nov 2016 Post subject: |
GT85, plus-gas and diesel (not all at the same time), blow torch and tapping a socket + extension.
Could not get the nuts off with the studs out the head for fear of breaking the studs either. The bike has spent a few years outside though  |
| colink98 |
| neptune8 |
 neptune8 Nova Slayer
| Itchy |
 Itchy Super Spammer
 Posted: 15:55 - 03 Dec 2016 Post subject: |
Why is everybody talking about removing the studs?
Unless they are badly corroded then you simply use a nut splitter or a dremel to cut the old nuts off carefully and slowly (don't apply too much force). ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| colink98 |
| Itchy |
 Itchy Super Spammer
| arry |
 arry Super Spammer
| Rogerborg |
 Rogerborg nimbA
 Posted: 08:45 - 05 Dec 2016 Post subject: |
Cheer up, you can easily snap studs even if your (randomly calibrated) torque wrench is correctly set.
I'm glad it all came together in the end though. ____________________ Biking is 1/20th as dangerous as horse riding.
The last post was made 9 years, 114 days ago. Instead of replying here, would creating a new thread be more useful? |
