Peugeot speedfight
Xtrailcraig53
PostPosted: 22:49 - 30 Nov 2016    Post subject: Peugeot speedfight Reply with quote
I've just replaced the cylinder head gasket on my son's speedfight 50cc with a 70cc kit on it. I started it up and ran it for a few minutes then took it out for a run. Got back turned it off and my son went to go out on it half an hour later started no problem got to the end of the drive way and it cut out and won't start. It's got plenty of fuel a good spark. Fuel is getting to the piston as the plug was wet after trying to start it up. Could this be a compression problem.?
Stoker
PostPosted: 01:07 - 01 Dec 2016    Post subject: Reply with quote
Could be anything. Did it run as a 50cc? How well did it run as a 70? what changes did you make to the carburation and exhaust?
I have seen 49cc engines struggle with blocked exhausts before, and unwititng owners trying to address their woes with exhaust mods.
edit. I am an idiot!
Xtrailcraig53
PostPosted: 07:21 - 01 Dec 2016    Post subject: Peugeot speedfight Reply with quote
Bought it as a 50cc with the 70cc kit already on it. Was running fine until the exhaust came loose so I had to take the head off to get the bolt holes helicoiled, put it back together with new gasket set and the rest is what you seen above.
andyscooter
PostPosted: 08:51 - 01 Dec 2016    Post subject: Reply with quote
its a peugeot engine
they hate being tuned
put it back to oe spec and it will probebly run fine
(and yes i know its how you bought it ) is it a two stroke if so is it getting oil
Xtrailcraig53
PostPosted: 10:41 - 01 Dec 2016    Post subject: Peugeot speedfight Reply with quote
It was running great for years until I had to take the head of. Yes it's definitely getting oil
Xtrailcraig53
PostPosted: 22:17 - 01 Dec 2016    Post subject: Peugeot speedfight Reply with quote
Well I stripped it down tonight and the problem was very obvious, cracked piston ring.
The last post was made 9 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 45.94 Kb
