Accelerator cable not long enough??
airz1988
PostPosted: 15:43 - 01 Dec 2016    Post subject: Accelerator cable not long enough?? Reply with quote
The bike i am riding at the moment is a Suzuki gsx600f, the guy I bought it off turned it into a naked bike and put rental bars on it instead of the clip on bars that are usually fitted to the bike, meaning the handle bars are further away from the carbs meaning my accelerator cable is stretched!!! It revs on its own when I turn the handlebars to the right!!! Just wondering what cable do I fit to stop the problem?? It's routed as well as it can be but I'm thinking something 4 inches longer will completely solve this problem?? Any help is much appreciated Smile thanks in advance.
Airz
Bloggsy
PostPosted: 15:52 - 01 Dec 2016    Post subject: Reply with quote
I would imagine you would have to buy a new cable of the correct length
PostPosted: 16:04 - 01 Dec 2016    Post subject: Reply with quote
https://www.venhill.co.uk/Hoses_&_Cables_-_Custom/Custom_Cables
https://www.carrotcycles.co.uk/custom-made-cables.html
et al.
PostPosted: 16:34 - 01 Dec 2016    Post subject: Reply with quote
Venhill are good Thumbs Up Made me a longer clutch cable for my Speed Four.
Before you get something longer have a look see if you can reroute the current cable. I got away without changing my Throttle cable because I ran it a more direct route.
airz1988
PostPosted: 17:38 - 01 Dec 2016    Post subject: Reply with quote
Thanks rogerborg I'll look now Smile and the cable is routed the best way possible already and it's no good Sad
Airz
airz1988
PostPosted: 17:58 - 02 Dec 2016    Post subject: Reply with quote
I want to buy one from a breaker, second hand good condition, ready to lube and fit, any suggestions? Gagged
Airz
wr6133
PostPosted: 19:36 - 02 Dec 2016    Post subject: Re: Accelerator cable not long enough?? Reply with quote
Seems a bit silly renting your handlebars.
dydey90
PostPosted: 20:01 - 02 Dec 2016    Post subject: Re: Accelerator cable not long enough?? Reply with quote
We're going to be seeing a lot of you in the workshop section then.
talkToTheHat
PostPosted: 01:06 - 03 Dec 2016    Post subject: Reply with quote
Try off the shelf bandit throttle pull cable, pattern ones are a tenner. I suspect it will fit.
Bandit. does. everything.
Suntan Sid
PostPosted: 10:33 - 03 Dec 2016    Post subject: Reply with quote
So you'll be looking for a bike, in a breakers that just happens to have the same mods as yours, in the hope that it has the correct length throttle cable. Good luck with that! Never heard the phrase "needle in a haystack"?
Seeing as your bike will fail an MOT, in it's current state, follow the Borg's links and get your wallet out!
Azoth
PostPosted: 12:31 - 03 Dec 2016    Post subject: Reply with quote
The other way is to snip it near the end, and solder a length of (preferably braided) steel wire to it with a mini blowtorch and high-temp solder, with as much overlap as you can. If it fails, of course, it will be dangerous. But if you're good with soldering, why not?
Safety in numbers
airz1988 This post is not being displayed because it has a low rating (Flame). Unhide this post / all posts.
airz1988
PostPosted: 16:48 - 03 Dec 2016    Post subject: Reply with quote
that sounds a bit dangerous lol
Airz
Suntan Sid
PostPosted: 17:20 - 03 Dec 2016    Post subject: Reply with quote
stop trying to be clever its not working, you sound stupid, if i found the same bike as mine with the same mods as mine i would find an accelerator cable which is the same length and still would not be long enough?? IDIOT!! and why would i want to spend hundreds of pounds on a brand new custom cable if i could find a good condition bandit 600 cable for about £20 as talktothehat just suggested?? you need to think before you type mate
You want to buy a second hand, non standard, throttle cable and I'm an idiot, Rolling Eyes , you're a total fukwit or a troll, so how about you just FRO, bellend! Middle Finger
PostPosted: 17:34 - 03 Dec 2016    Post subject: Reply with quote
Last custom cable I had made by Venhill came to about £45 once postage and VAT was included. These days I have a kit to make them up myself when I need them.
Whether the cable will fit will also depend on the end fittings and the amount of free play, not just the length.
Katy
airz1988
PostPosted: 20:06 - 03 Dec 2016    Post subject: Reply with quote
You either have no idea what you're talking about or no idea what I'm talking about. A second hand standard cable off a different bike. That will fit straight on. Go back to sleep.
Airz
Suntan Sid
PostPosted: 22:17 - 03 Dec 2016    Post subject: Reply with quote
You were given a link earlier in the thread, where you can have a cable made up any size or length you want for under £30!
But you want to save a few fcukin' pennies and buy a secondhand cable from a breakers, that may or may not be the right length and may or may not work for more than a day before it snaps or jams up on a frayed bit, FFS! And apparently I'm the idiot here! Rolling Eyes
Pray tell why having a cable made up to the correct size and length is so much worse than buying some manky old tat from a breakers, a part which neither you or the vendor can verify is in good nick? I'm all fcukin' ears!
You're not my "mate", you're a knob! Middle Finger
janner_10
PostPosted: 08:46 - 04 Dec 2016    Post subject: Reply with quote
Why? Follow Rogers link for a pain free experience.
PostPosted: 09:31 - 04 Dec 2016    Post subject: Reply with quote
Why would a throttle cable from a different bike "fit straight on"?
Motorbikes are not like Lego, you can't just take bits from different bikes and expect them to work together. You may get lucky, or it may get very painful very quickly.
I'd just talk to Venhill or similar and get them to knock you up a cable of the length you need.
Or take the Renthal's off and put it back to standard. If you wanted a naked high bared bike you should have bought one that was designed to be that way from the get go.
I assume you've checked your brake line length as well? Given the previous owner was clearly prepared to run it with a throttle cable of the wrong length, I'd check they're not about to go ping under full extension of the forks.
iooi
PostPosted: 10:20 - 04 Dec 2016    Post subject: Reply with quote
So what you want is someone else to TELL YOU exactly what cable will fit your bike so YOU can save a few P's... Rolling Eyes
You are aware that different bile's use different fittings etc. So it's not just a simple oh look a Yamaha "Divvy" is 4 inch longer so that will do you kinda job. Embarassed
Can't see you getting any help here with that type of attitude when people are only trying to help Twisted Evil
Suntan Sid
PostPosted: 21:10 - 04 Dec 2016    Post subject: Reply with quote
airz1988 wrote:
..............got my hands on a bandit 1200 throttle cable from a breakers yesterday, really good second hand condition......
Really, how do you know?
airz1988 wrote:
..............as for everyone else's ridiculous unwanted criticism and input, go fuck yourselves you're all full of shit Smile thanks for wasting my time annoying me so much that I felt the need to reply, much appreciated talktothehat Smile
Quoted for posterity!
Glad we all know where we stand!
Feelings are mutual, dickhead!
You're a troll, no one could be as fcukin' stupid as you proclaim to be!
airz1988
PostPosted: 05:36 - 05 Dec 2016    Post subject: Reply with quote
read what a troll actually means.
https://www.urbandictionary.com/define.php?term=troll
i simply wanted to know what cable i could get quickly and easily fit. i got my answer. youre the one that started talking shit on my post....
Airz
iooi
PostPosted: 09:11 - 05 Dec 2016    Post subject: Reply with quote
You AA and I claim my £5 Laughing
PostPosted: 12:06 - 05 Dec 2016    Post subject: Reply with quote
Lol £12 for a second hand cable. Laughing
https://www.ebay.co.uk/itm/Suzuki-GSF-1200-W-Bandit-Naked-SACS-GV75A-1998-1200-CC-Throttle-Cable-/360565213856?hash=item53f35c8aa0:g:MK8AAOxyJX1TAaNQ
The last post was made 9 years, 70 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.76 - MySQL Queries: 13 - Page Size: 136.9 Kb
