motorbike wiring system
daniel15cruz
PostPosted: 04:36 - 07 Dec 2016    Post subject: motorbike wiring system Reply with quote
my wiring is well connected and check properly and tested, but every time i turn the key on, all my electrical system malfunction, my battery is new, please help.
janner_10
PostPosted: 05:11 - 07 Dec 2016    Post subject: Reply with quote
Can you not be more specific?
daniel15cruz
PostPosted: 05:18 - 07 Dec 2016    Post subject: wiring system Reply with quote
i checked all the wiring from every connections and battery and its all okay, tester shows good connectivity and conductibility, but once I turned the key on in the ignition there is no light signal, not even the buzzer is working... Sad
janner_10
PostPosted: 05:19 - 07 Dec 2016    Post subject: Reply with quote
Check your main fuse.
PostPosted: 10:31 - 07 Dec 2016    Post subject: Reply with quote
Your assertion that everything is properly connected and tested is clearly incorrect because otherwise the electrics would be working.
Also the time, effort and degree of dismantling it would take to physically check every electrical connection to every componant on a modern motorcycle would mean you would be a competant enough motorcycle electrician to have found and fixed the problem yourself.
So. Basics.
What bike? Make, and model.
What HAVE you checked?
As Janner 10 says, check the main fuse first off.
In general terms, if the bike is completely dead but the fuse is intact andf the battery is charged, first check for continuity between the battery and the ignition switch. Then check the ignition switch, then check for continuity between the ignition switch and the motorcycle componants (on a larger bike, this would usually be a fusebox, on smaller ones, a more direct connection).
You can use a voltmeter or even a simple bulb and holder with two flying leads to perform these checks. Earth one side to the chassis and probe along the circuit from the battery onwards with the other side until you find the point where there is no potential difference where there ought to be one. Your problem is between there and the last place you checked.
PostPosted: 13:30 - 07 Dec 2016    Post subject: Reply with quote
And the main earth connection between the battery and the frame or engine.
The usual question: why did you change the battery? What was wrong with the old one, and what have you done to fix the underlying problem that caused it to go bad?
WD Forte
PostPosted: 17:49 - 07 Dec 2016    Post subject: Re: motorbike wiring system Reply with quote
If you tell us where you live, we'll send you a bus timetable
bikers smell of wee
Raffles
PostPosted: 18:11 - 07 Dec 2016    Post subject: Reply with quote
^^^Make this the first test that you perform^^^
ADSrox0r
PostPosted: 19:53 - 07 Dec 2016    Post subject: Reply with quote
My money is on main fuse is toast.
Not that I think you'll be back to give a fuck.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:01 - 07 Dec 2016    Post subject: Reply with quote
My money is on the battery being in a cardboard box next to bike...
Triumph Sprint ST 1050
PostPosted: 20:27 - 07 Dec 2016    Post subject: Reply with quote
With no acid in it.
PostPosted: 07:45 - 08 Dec 2016    Post subject: Reply with quote
Upside down.
Fish fingers thread.
The last post was made 9 years, 61 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 73.37 Kb
