Instant gasket
sutty86
PostPosted: 17:10 - 09 Dec 2016    Post subject: Instant gasket Reply with quote
Looking for advice to use this on an oil pan, managed to loosen one of the bolts accidentally whilst taking CVT cover off and now have a very minor leak.
Believe gasket has gone, could fork out but delivery is a few days but have instant gasket from previous bike.
Any advice gents
PostPosted: 17:24 - 09 Dec 2016    Post subject: Reply with quote
You are very thin on details. At a minimum make and model eh?
General advice:
Slapping instant gasket on over the top of a leaking gasket face won't work. Or not for long at any rate
So you're looking at taking it apart.
If you're doing that, you may as well do it properly and fit a replacement gasket.
Replacement gaskets can be bought or cut out of appropriate thickness paper/card. Cornflakes packet is traditional.
sutty86
PostPosted: 17:39 - 09 Dec 2016    Post subject: Reply with quote
Sorry for being so sparse on details.
Do not like admitting I have a moped Piaggio x8 125cc.
Totally different ball game to a bike.
Learnt lots just changing belt,rollers etc.
Yes was going to remove the whole part and change oil ,filter etc in process.
Before I get more shit the scooter cost me nothing
PostPosted: 17:45 - 09 Dec 2016    Post subject: Reply with quote
So which bolt did you loosen and where is it leaking from?
Because from what I can see, a piaggio X8 doesn't have a seperate sump pan.
sutty86
PostPosted: 18:09 - 09 Dec 2016    Post subject: Reply with quote
Underneath between dipstick opening to the right slightly , looking around online it's a very common mistake.
Has the bolts from the transmission cover are the same size and on the same sort of level as you are going around.
Only unscrewed it slightly and now I have oil on the floor and you can see drips forming.
Rolling Eyes Rolling Eyes Brick Wall Folded arms Tut Tut
PostPosted: 19:41 - 09 Dec 2016    Post subject: Reply with quote
I think you'd be unlucky to have damaged the gasket by simply loosening then tightening one of those bolts slightly. Sepecially if it's one of the "top" row of bolts.
I'd give it a wipe along the joint with a rag so you've got rid of any residual oil and see if it's still leaking (pop a bit of tinfoil or card under it). Looks like you've only lost a couple of drops there.
Evil Hans
PostPosted: 01:04 - 10 Dec 2016    Post subject: Reply with quote
Which is it? A moped or a 125?
The last post was made 9 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.45 - MySQL Queries: 13 - Page Size: 52.05 Kb
