Water cooler - is it worth fitting it?
mudcow007
PostPosted: 16:23 - 12 Dec 2016    Post subject: Water cooler - is it worth fitting it? Reply with quote
Currently running an i7 at home, on standard clock etc.
Thought about possibly OC just to see what increases I can get.
Proc currently has the Intel standard cooler & fan.
I have got an old (unused) watercooler in my spares cupboard, is it worth fitting it. The cooler is a couple of years old - would the coolent need to be changed etc!?
Just wondering if its worth all the ball ache though?
lihp
PostPosted: 16:54 - 12 Dec 2016    Post subject: Reply with quote
Depends what cooler it is. If it's Corsair, then it wasn't worth fitting when you bought it
mudcow007
PostPosted: 17:06 - 12 Dec 2016    Post subject: Reply with quote
Just googled it, an it seems its worserer than a Corsair cooler
PostPosted: 17:08 - 12 Dec 2016    Post subject: Reply with quote
What cooler is it?
mudcow007
PostPosted: 17:09 - 12 Dec 2016    Post subject: Reply with quote
CoolIT domino A.L.C
Loui5D
PostPosted: 17:15 - 12 Dec 2016    Post subject: Reply with quote
Sounds like chinese crap.
From amazon:
22 of 22 people found the following review helpful
1.0 out of 5 stars WARNING: Leaked all over!! 28 April 2009
By DEN863 - Published on Amazon.com
Verified Purchase
I purchased this product based upon the favorable reviews and for the promise of a low-maintenance water-cooling solution.
After a little over a month, the domino suffered a complete failure; I opened up my computer to find coolant fluid all over my $500 Evga graphics card. One of the cooling hoses had almost completely separated from the radiator unit. Fortunately, the coolant does not appear to have permanently damaged either the card or system.
I can only infer that either the design for the Domino is flawed or that coolIT are using extremely cheap materials to manufacture the product.
Either way I would highly recommend that people avoid this product.
***UPDATE 08/10/09: IT HAPPENED AGAIN!!
Against my better judgment I gave the domino a second chance after amazon offered to send me out a replacement overnight for free. Well, I've used the domino for less than 2 months and the exact same thing happened again! Fortunately, this time I caught the leak early and nothing in my system appears damages. This is conclusive proof in my book that the design of the domino is fundamentally flawed.
AVOID THIS PRODUCT AT ALL COSTS!!
notbike
PostPosted: 17:23 - 12 Dec 2016    Post subject: Reply with quote
But I have a corsair h110i gt AIO and my cpu under max load has never exceeded 64 degrees (then again it has a tdp of 91)
Have only owned it a couple years though, so it still has the test of time to see if it'll coagulate/break.
PostPosted: 17:26 - 12 Dec 2016    Post subject: Reply with quote
SPOILER ALERT!!!
It will break.
PostPosted: 18:14 - 12 Dec 2016    Post subject: Reply with quote
I've had a 100i for 4 years, it's been fine.
CaNsA
PostPosted: 18:26 - 12 Dec 2016    Post subject: Reply with quote
Antec Kuhler 920 H2O for over 4years.
Not dead.
I have seen many a "my corsair AIO has popped/ pump stopped working" threads over the years.
notbike
PostPosted: 21:42 - 12 Dec 2016    Post subject: Reply with quote
Fuk Very Happy
I'll pour water on it if it breaks. That'll fix everything until I buy something else.
M.C
PostPosted: 23:41 - 12 Dec 2016    Post subject: Reply with quote
From amazon:
Verified Purchase
Yeah see that's my fears confirmed regarding water cooling Smile
Why don't you buy a better cooler? I've got a cooler master 212 evo, was actually thinking of going back to the stock cooler seeing as that system isn't OC'd anymore.
mudcow007
PostPosted: 11:30 - 13 Dec 2016    Post subject: Reply with quote
Stock cooler sounds like a angry wasp - everything else is silent, kinda like a submarine just with less seamen
I dont really do anything heavy to warrant OC so will just replace the cooler etc..
Loui5D
PostPosted: 11:37 - 13 Dec 2016    Post subject: Reply with quote
I've not personally had problems with my H60 but then again i'm just one bod out of a few thousand.
Like Cansa said Antec had a good rep.
If you're afraid of using water cooling get a Noctua.
RhynoCZ
PostPosted: 12:37 - 13 Dec 2016    Post subject: Re: Water cooler - is it worth fitting it? Reply with quote
Even a cheap tower type of cooler with one 120x120 (or even two) will be a huge jump ahead, speaking of cooling performance. All that without the risk of leaking liquid cooling solution. Wink
Intel's box coolers really got crap, in the past few years. The box cooler I got with my q6600 (105w TDP) was a huge chunk of copper and aluminium fins, with a very silent fan on it. All that keeping that CPU cool even at 3.0GHz OC, and the fan was still not audible.
The modern Intel coolers are quite laughable, maybe Intel realises that people who use their CPUs for gaming will swap the coolers anyway. They are loud and barely keep the CPUs from melting. Especially the i7 family. Buying an rather expensive CPU, you'd expect the manufacturer to supply it with a more adequate cooling solution. It's quite like buying a V12 sports car on 15'' steel rims.
ThatDippyTwat
PostPosted: 20:45 - 13 Dec 2016    Post subject: Reply with quote
Bought my H50 years ago, at release. I downgraded from a custom loop as I wasn't needing silly cooling any more. Zero issues, ever.
The last post was made 8 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.97 - MySQL Queries: 13 - Page Size: 90.38 Kb
