Hell of a drop from the battery voltage!
RickTaff
PostPosted: 14:48 - 27 Dec 2016    Post subject: Hell of a drop from the battery voltage! Reply with quote
Battery on my bike died about 2 weeks ago, was reading 10.5V. It died suddenly after being parked outside a mates house for an hour or so in the rain. Got it home and managed to bump it in 2nd gear, rode it round but it still cut out various points although bumped again first attempt. [24 hrs later, it wouldnt even bump]
Have kept it indoors since as i had no access to a charger. I now have a trickle charger, 12V 1.5amp - which has put some charge back into my battery and it now reads 12.4V when tested with a voltage tester.
Have had it on charge for about 30hrs(!!) and I thought I would put it onto the bike just to see if there was any life.... there wasnt. It still reads 12.4V but the minute I turn ignition on, it plummets to something outrageous like 0.83V.
Have been given 3 causes.
1. Battery is shorting out
2. Battery is scrap and is now worthy of the rubbish tip
3. Battery has been discharged for 2 weeks, and due to it being charged on trickle charger, it will need a few days constant charge to get back to life, so to speak
I think 2 is most likely.
Nobby the Bastard
Harley Gaydar
PostPosted: 14:57 - 27 Dec 2016    Post subject: Re: Hell of a drop from the battery voltage! Reply with quote
Have you checked the level of the fluid in it or is it a sealed one?
Triumph Sprint ST 1050
RickTaff
PostPosted: 15:08 - 27 Dec 2016    Post subject: Re: Hell of a drop from the battery voltage! Reply with quote
On a flat surface the acid level is halfway between lower and upper level line. When put into the battery holder on the bike... the battery sits at a slight angle so acid level reads more along the lower line then, or just below.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:20 - 27 Dec 2016    Post subject: Reply with quote
What happens when you turn the lights on?
RickTaff
PostPosted: 15:28 - 27 Dec 2016    Post subject: Reply with quote
When i turn the ignition on, I dont even get a neutral light come on anymore. It is literally as if I havent even turned it on.
the needle to indicate my remaining fuel does not even move.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:45 - 27 Dec 2016    Post subject: Reply with quote
Do you have a spare battery, jump leads etc to start the bike so you can check the charging system?
Fizzer Thou
PostPosted: 16:02 - 27 Dec 2016    Post subject: Reply with quote
The battery is Fubar.
Halfords sell them if you need one urgently Thumbs Up
Always have a 'Plan B'
jaffa90
PostPosted: 18:20 - 27 Dec 2016    Post subject: Reply with quote
10.5v sounds like a cell down probably shorted out.
andy_uk
PostPosted: 18:25 - 27 Dec 2016    Post subject: Reply with quote
Faulty reg/rec ?
PostPosted: 19:09 - 27 Dec 2016    Post subject: Reply with quote
This. The recent cold weather has killed your waning battery. It happened to me last week.
New battery time.
PostPosted: 19:15 - 27 Dec 2016    Post subject: Reply with quote
New battery time.
+1 to the lads above. The battery is dead. it can happen and they can sometimes just fail that way with no prior warning. Fit a new one.
smegballs
PostPosted: 19:41 - 27 Dec 2016    Post subject: Re: Hell of a drop from the battery voltage! Reply with quote
RickTaff wrote:
Battery on my bike died about 2 weeks ago, was reading 10.5V......
Keeping a lead-acid battery in a discharged state for 2 weeks will easily kill it due to sulphation of the plates. If it wasn't scrap before it will be now.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:59 - 27 Dec 2016    Post subject: Reply with quote
First off, it's not been that cold.
Following on from that, your battery is probably fucked, but I'd want to know why.
arry
PostPosted: 22:09 - 27 Dec 2016    Post subject: Reply with quote
andy_uk wrote:
Faulty reg/rec ?
Potentially, but more likely battery just went dead in cold weather and dropped off a cliff thereafter.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:16 - 27 Dec 2016    Post subject: Reply with quote
arry wrote:
andy_uk wrote:
Faulty reg/rec ?
Its not been that cold. you need proper minus temperatures to get that and they can generally recover from that.
arry
PostPosted: 22:19 - 27 Dec 2016    Post subject: Reply with quote
It has been a mild winter, granted. But if it's an old battery that wasn't up to much in itself before winter, then a few cold snaps and a couple of gone dead moments without a proper recovery capable charger, then I'd not be surprised if it's nothing more sinister than just the battery
That said, you're still quite right - to err on side of caution and just check voltage at posts when running on the new battery wouldn't be a bad idea in the slightest.
Mawsley
PostPosted: 22:24 - 27 Dec 2016    Post subject: Re: Hell of a drop from the battery voltage! Reply with quote
Old, cheap or charged on a car battery charger?
Nobby the Bastard
Harley Gaydar
PostPosted: 22:30 - 27 Dec 2016    Post subject: Re: Hell of a drop from the battery voltage! Reply with quote
Next you'll be saying that modern cars have 'special' 12v DC that will break your battery/electrical system....
Mawsley
PostPosted: 22:40 - 27 Dec 2016    Post subject: Re: Hell of a drop from the battery voltage! Reply with quote
Current.
ThatDippyTwat
PostPosted: 22:59 - 27 Dec 2016    Post subject: Re: Hell of a drop from the battery voltage! Reply with quote
No, most car chargers force far too much current into the cells of the battery.
Car chargers tend to be 4-5A on the lowest setting. Bike batteries (generally) want 0.5A low, 1A MAx.
That is why you don't use a car charger, or at least one of the "old" ones where you can't set the current to a suitable level. Irrespective of the chemistry of the cell, over-current charging is the quickest way to fuck a cell.
PostPosted: 23:40 - 27 Dec 2016    Post subject: Reply with quote
It's been quite mild but plenty cold enough to see off a weak battery, Mine died on the 21st - a very mild day but the week before had a couple of bitter days.
arry
PostPosted: 23:56 - 27 Dec 2016    Post subject: Reply with quote
Exactly that. Similar conditions last year saw off last car battery. Since lost another to a faulty voltage regulator which is a bit...of a kick....in teh nads.
RickTaff
PostPosted: 15:55 - 28 Dec 2016    Post subject: Re: Hell of a drop from the battery voltage! Reply with quote
This more or less what a dealer told me this morning. He said when it died on December 10th, I should really have stuck it on charge soon as the recovery truck dropped me off. But because I didnt have access to a charger until xmas... it sulphated during that 2 week period. 'Crystals on the plates' i think were his words.
Also said that between the cold-ish weather, and the fact I didnt use the bike every single day, they also play a part in draining it because the bike was stored outdoors with just a cover over it. And from now on just whack it on a trickle charger overnight as often as possible. Even every single night if i want.
RickTaff
PostPosted: 15:56 - 28 Dec 2016    Post subject: Re: Hell of a drop from the battery voltage! Reply with quote
My trickle charger is 12volt 1.5amp, says for use with cars and motorcycles on the charger itself... I was told that it's fine and no issue with the amp current
ThatDippyTwat
PostPosted: 16:21 - 28 Dec 2016    Post subject: Re: Hell of a drop from the battery voltage! Reply with quote
Have a closer look. It may be 1.5A max. Can you adjust it?. Your battery will tell you what it wants, it will be printed on the side of it. As long as the 2 can be made to match, then it's fine, there is no "magic" bike charger, just lower current chargers.
If your cell wants 0.5A trickle (low) and your charger is set at 1.5A then you will noticeably shorten it's life. Feel free to google around to see what over-current charging does to a lead (or any other kind for that matter) cell.
The last post was made 9 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 133.69 Kb
