| Stalk |
 Stalk Brolly Dolly
| stinkwheel |
 Posted: 18:19 - 28 Dec 2016 Post subject: |
I have seen many worse electrical connections.
It's in a BS60670 approved junction box.
If it was me, I'd have it screwed down to the wall.
What would you have done instead? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| bugeye_bob |
 bugeye_bob World Chat Champion
| 331X2 |
 331X2 Crazy Courier
| bugeye_bob |
 Posted: 19:19 - 28 Dec 2016 Post subject: |
| Stalk |
 Stalk Brolly Dolly
 Posted: 19:23 - 28 Dec 2016 Post subject: |
The problems as I see it are, no strain reliif on the cable, so potental for wire to be pulled out and exposed live, and possibility of water ingress again giving potental for electric shock.
As Bob said, wire direct to boiler would have been the best soulution, however, the cable was not long enough, so at the very least a waterproof connector with strain releif on the cable such as
https://www.toolstation.com/shop/Electrical/d190/Exterior+Wiring+Accessories/sd2659/IP68+Inline+3+Pole+Connector/p27346
The reason for the ask is that in 2004, with the then upcoming part P and being a kitchen fitter who was doing electrics as well, I did a one week wonder course so I could self cert. It was at that point that I had the dreadfull realization of how much I did not know. I have not done electrical work as part of my kitchen fitting since. I have however assisted the qualified sparks and have learned a bit since then. I've not been a kitchen fitter or assisted with sparks work for a couple of years now, and as the 17th edition has happened, and maybe been revised, I am probably well out of date. Hence the ask
The pictured jb was an upgrade on the previous tape wrapped choc blok which where both fitted by a council approved contractor in a council oap bungalow |
| Stalk |
 Stalk Brolly Dolly
| bugeye_bob |
| stinkwheel |
 Posted: 19:54 - 28 Dec 2016 Post subject: |
The irony is, if he'd shoved it up inside the boiler casing, nobody would have noticed.
making it waterproof is a bit of a waste of time, none of the mains electricals inside the boiler itself are waterproof.
There will be a basic screw in terminal block inside the boiler. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Nobby the Bastard |
The last post was made 9 years, 192 days ago. Instead of replying here, would creating a new thread be more useful? |
