Arrrgh! Kawasaki ZZR 600, wont start after being dropped!
bikecruiser.co.uk
PostPosted: 20:17 - 28 Feb 2005    Post subject: Arrrgh! Kawasaki ZZR 600, wont start after being dropped! Reply with quote
Hi guys,
All help will be very VERY much appreciated on this one Thumbs Up
I came off my bike 2 days ago. Absoloutely gutted!
The problem is, after i got up and tried to start the bike again, it was just clicking! Hmmmm, so i got the bike recovered, and took a look at it the next morning.
I've had the left hand side of the engine off and checked the starter motor.. It's not turning!! when i take the gear joining the starter motor to the engine it spins fine.
So just out of curiosity, i put it all back together and tried to bump start it to no avail.. The back wheel just locks up!
When i came off i thought that the front wheel hit one of them stupid white lines, but now im thinking that it's possible something has happened inside the engine making my back wheel lock up and throwing me off.
Does anyone have any idea what could be stopping the starter motor turning the engine over? and if you have an idea, how would i go about rectifying the problem?
I'm really in a bind like, coz i've got a charity ride on the 18th of march and it's still screwed!
Any information would help me try and figure it out Smile
Thanks in advance.
Dave Stewart
www.BikeCruiser.co.uk
Scotsman37
PostPosted: 20:42 - 28 Feb 2005    Post subject: Reply with quote
Have you checked the connections with a multimeter to make sure power is getting to starter motor ? Also have you checked your fuses too as you may have blown one or two of them or to make sure the kill switch is off ?
bikecruiser.co.uk
PostPosted: 20:45 - 28 Feb 2005    Post subject: Reply with quote
Yep, that was the first port of call.we thought we'd check that we were getting voltage and current over to the motor.
Another point which may help in diagnosing the problem is that i cant bump start it, the back wheel locks up completely and no matter how much we've tried to move the back wheel it just has no effect..
Cheers mate
Dave
PostPosted: 20:47 - 28 Feb 2005    Post subject: Re: Arrrgh! Kawasaki ZZR 600, wont start after being dropped Reply with quote
Just to check... I presume the bike does go into neutral ok?
I would be bump starting a 600 in second... and try and wait for a relaticely non wet day. If possible get someone to sit on the bike while being pushed (or jump on while running if you're feeling energetic Smile ). Try and stand up then drop down on the bike.
However if there is something bad seized, then this could cause further damage.
As for the seized bits, are there any damaged engine covers etc?
Does it still lock if you try and bum it in 6th gear?)
If you can push the bike in neutral, but it won't move at all when in gear, then you can presume it's something the other side of the gear box that's causing the problems.
Other stuff you can check:
Sparks plugs out and look at the bore with a torch.
Get the engine covers off and check the generator/clutch.
bikecruiser.co.uk
PostPosted: 20:50 - 28 Feb 2005    Post subject: Reply with quote
Hi G,
It locks up in all gears when trying to bump it m8..
It's fine to move in neutral but the second it goes into gear there's jus no chance!
There's not too much damage to the engine covers, just the left hand side is a bit scuffed but not cracked or anythin.
PostPosted: 20:52 - 28 Feb 2005    Post subject: Reply with quote
Can you push it with the clutch in while in gear?
Scotsman37
You may have a a possible bent/broken gear selector or maybe even a damaged gear cog(s).
bikecruiser.co.uk
PostPosted: 20:55 - 28 Feb 2005    Post subject: Reply with quote
Yep, but the second i let the clutch out it locks up. Crying or Very sad
If it's showing nuetral light and the back wheel still refuses to move then you're looking at a possible bent/broken gear selector or maybe even a damaged gear cog(s).
It's showing a neutral light only when in neutral which is a good sign! hehe and the bike moves fine in neutral matey..
Cheers for all this help guys Thumbs Up
Scotsman37
PostPosted: 20:57 - 28 Feb 2005    Post subject: Reply with quote
Cheers mate
Dave
So there is a voltage reaching the start motor?
You have double checked the fuses too ?
Your 2nd gear cog/selector could be still be damaged, as it should be able to move freely the bike with the clutch pulled in while in the 2nd gear or any other gear?
PostPosted: 21:05 - 28 Feb 2005    Post subject: Reply with quote
As Scotsman said, you can damage the gear selectors if the selector rod touches down. However this is unlikley on the ZZR which has rear-set levers, so the actual lever isn't directly conneceted to the rod as it is on some bikes.
Possible that something has jammed and mashed some gears, however I would be worrying about the main engine seizing.
Have you checked the oil level?
bikecruiser.co.uk
PostPosted: 21:11 - 28 Feb 2005    Post subject: Reply with quote
The bike moves in all gears with the clutch pulled in matey. Thumbs Up
That's what im dreading Crying or Very sad -- The oil level was fine mate, it's a weird problem.. im jus drainin me oil at the moment to start going thru the engine an havin a good look.
cheers for the help peeps! Smile
PostPosted: 21:14 - 28 Feb 2005    Post subject: Reply with quote
Have a look in the drained oil for bits of engine Confused.
Might be worth putting a small filter of some kind between the oil and the catching device... as it's usually quite hard to find bits of anything in used engine oil.
If you can get to the spark plugs easily, checking the bore might be a good start... though may not be that easy on the ZZR.
Tarmacsurfer
PostPosted: 22:22 - 28 Feb 2005    Post subject: Reply with quote
Given no motion of the wheel in 6th, that's sounding like a seize to me . Was the engine running at all while on it's side? Unsure about the ZZR600 but the 1100 is notorious for the oilways in pot 3 giving out and locking the piston up.
I'm immortal. Well, so far.
PostPosted: 22:23 - 28 Feb 2005    Post subject: Reply with quote
Take the little plastic cover off the middle of the left hand crankcase cover, get a 1/2" drive socket (17mm usually) with extension bar on the end of the crank and see if you can turn it by hand.
If it turns, you are looking at a starter system/electrical problem (such as a flat battery), if it doesn't the engine is seized for one reason or another.
Next step would be to try it with the sparkplugs out, if it turns over with the plugs out but not in, it has fluid locked (oil or fuel would come out of the plug holes). If it still doesn't turn over, something more fundamental has gone wrong with either the engine itself or the primary drive area. I would probably lift the rocker cover first and look for a dropped valve then drain down the oil and take the primary drive cover off to see if anything there has gotten tangled.
See how you do anyway.
Robby
Dirty Old Man
PostPosted: 22:32 - 28 Feb 2005    Post subject: Reply with quote
If its clicking and the starter motor turns when you disengage it from the engine, my moneys on flat/dead battery.
Guest
PostPosted: 23:35 - 28 Feb 2005    Post subject: Reply with quote
But if it's locked up, the starter will show ok on the bench (which he has) but won't have a chance of turning the engine over.
I'm with Stinkwheel - take the plugs out and turn the crank from the end with a socket. If it won't turn then it's a strip - either the engine's locked through revving on it's side (no oil) or the gearbox has locked which may have caused the prang in the first place.
Hex
Party Boy
PostPosted: 08:55 - 01 Mar 2005    Post subject: Reply with quote
Agree, though you could just take the spark plugs out and try pushing it in gear (if you didn't want to turn it with a socket).
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
Guest
PostPosted: 09:36 - 01 Mar 2005    Post subject: Reply with quote
Just a thought - you've had one of the engine covers off? Have you put the screws back in correctly? Often they are of a different length, I don't know the ZZR specifically.
I once had a Honda 90 lock-up solid after a routine service - I'd put a screw in the points cover that was about 6mm too long and it had gone into the slot in the flywheel, stopping the engine turning over completely Embarassed .
Could be summat daft (with luck) Thinking Doh!
PostPosted: 14:34 - 01 Mar 2005    Post subject: Reply with quote
Well, yes and no, if there was a gearbox problem it would still appear to be seized. Turning the crank by hand should work even if the gearbox has bombed.
Guest
PostPosted: 18:48 - 01 Mar 2005    Post subject: Reply with quote
I suppose the only real way to isolate what is actually locked is to take the clutch drum off - then you'd know if it was the box or the crank siezed up. Either way it's engine out and full strip to repair.
But I'd make damn sure it wasn't something daft before going to that trouble - chain off, side covers off, cam cover off and a good look while trying to turn the crank.
bikecruiser.co.uk
PostPosted: 22:18 - 10 Mar 2005    Post subject: Reply with quote
WELL! What a bitch!!
FINALLY got the engine out, which was a lot harder than i expected! because there's a spacer on the bottom right hand side at the back of the engine, WHICH i didnt have an allen key to fit.. Hammer and chisel done it tho! Very Happy
So, anyways, gets the engine to bits today, and i take a look at my pistons and barrel... Fine, everythin was gr8..
So, went further down and checked the crank.. Looked good.. Gear box... Sound!
Hmmmmmm, so, i turned the engine the right way up (after it being upside down.. I'm looking at it, and what do i see?? The plastic runner that the cam chain runs down.. Only 1 bolt holding it in..
Quickly turned the engine back over, and there it was jamming up the crank.. NO DAMAGE anywhere.. which is a good thing! Very Happy
Took that bolt out, and everythin is fine agen now! Very Happy all that's needed is a bit of a clean and a new gasket set!! Made Up!! hehe
Cheers for everyone's help
So, anyone up for UK in a day then??? It's in the outings n excursions forum if ya avent seen it!
Cheers agen
Deejwah!
The last post was made 21 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 115.22 Kb
