| bikecruiser.co.uk |
 bikecruiser.co.uk Renault 5 Driver
 Posted: 20:17 - 28 Feb 2005 Post subject: Arrrgh! Kawasaki ZZR 600, wont start after being dropped! |
Hi guys,
All help will be very VERY much appreciated on this one
I came off my bike 2 days ago. Absoloutely gutted!
The problem is, after i got up and tried to start the bike again, it was just clicking! Hmmmm, so i got the bike recovered, and took a look at it the next morning.
I've had the left hand side of the engine off and checked the starter motor.. It's not turning!! when i take the gear joining the starter motor to the engine it spins fine.
So just out of curiosity, i put it all back together and tried to bump start it to no avail.. The back wheel just locks up!
When i came off i thought that the front wheel hit one of them stupid white lines, but now im thinking that it's possible something has happened inside the engine making my back wheel lock up and throwing me off.
Does anyone have any idea what could be stopping the starter motor turning the engine over? and if you have an idea, how would i go about rectifying the problem?
I'm really in a bind like, coz i've got a charity ride on the 18th of march and it's still screwed!
Any information would help me try and figure it out
Thanks in advance.
Dave Stewart ____________________ www.BikeCruiser.co.uk |
| Scotsman37 |
 Scotsman37 World Chat Champion
| bikecruiser.co.uk |
 Posted: 20:45 - 28 Feb 2005 Post subject: |
Yep, that was the first port of call.we thought we'd check that we were getting voltage and current over to the motor.
Another point which may help in diagnosing the problem is that i cant bump start it, the back wheel locks up completely and no matter how much we've tried to move the back wheel it just has no effect..
Cheers mate
Dave ____________________ www.BikeCruiser.co.uk |
| G |
 G The Voice of Reason
 Posted: 20:47 - 28 Feb 2005 Post subject: Re: Arrrgh! Kawasaki ZZR 600, wont start after being dropped |
Just to check... I presume the bike does go into neutral ok?
I would be bump starting a 600 in second... and try and wait for a relaticely non wet day. If possible get someone to sit on the bike while being pushed (or jump on while running if you're feeling energetic ). Try and stand up then drop down on the bike.
However if there is something bad seized, then this could cause further damage.
As for the seized bits, are there any damaged engine covers etc?
Does it still lock if you try and bum it in 6th gear?)
If you can push the bike in neutral, but it won't move at all when in gear, then you can presume it's something the other side of the gear box that's causing the problems.
Other stuff you can check:
Sparks plugs out and look at the bore with a torch.
Get the engine covers off and check the generator/clutch. |
| bikecruiser.co.uk |
 Posted: 20:50 - 28 Feb 2005 Post subject: |
Hi G,
It locks up in all gears when trying to bump it m8..
It's fine to move in neutral but the second it goes into gear there's jus no chance!
There's not too much damage to the engine covers, just the left hand side is a bit scuffed but not cracked or anythin. ____________________ www.BikeCruiser.co.uk |
| G |
| Scotsman37 |
| bikecruiser.co.uk |
| Scotsman37 |
| G |
| bikecruiser.co.uk |
| G |
 Posted: 21:14 - 28 Feb 2005 Post subject: |
Have a look in the drained oil for bits of engine .
Might be worth putting a small filter of some kind between the oil and the catching device... as it's usually quite hard to find bits of anything in used engine oil.
If you can get to the spark plugs easily, checking the bore might be a good start... though may not be that easy on the ZZR. |
| Tarmacsurfer |
 Posted: 22:23 - 28 Feb 2005 Post subject: |
Take the little plastic cover off the middle of the left hand crankcase cover, get a 1/2" drive socket (17mm usually) with extension bar on the end of the crank and see if you can turn it by hand.
If it turns, you are looking at a starter system/electrical problem (such as a flat battery), if it doesn't the engine is seized for one reason or another.
Next step would be to try it with the sparkplugs out, if it turns over with the plugs out but not in, it has fluid locked (oil or fuel would come out of the plug holes). If it still doesn't turn over, something more fundamental has gone wrong with either the engine itself or the primary drive area. I would probably lift the rocker cover first and look for a dropped valve then drain down the oil and take the primary drive cover off to see if anything there has gotten tangled.
See how you do anyway. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Robby |
 Robby Dirty Old Man
| Guest |
 Guest Brolly Dolly
| Hex |
 Hex Party Boy
| Guest |
 Guest Brolly Dolly
 Posted: 09:36 - 01 Mar 2005 Post subject: |
Just a thought - you've had one of the engine covers off? Have you put the screws back in correctly? Often they are of a different length, I don't know the ZZR specifically.
I once had a Honda 90 lock-up solid after a routine service - I'd put a screw in the points cover that was about 6mm too long and it had gone into the slot in the flywheel, stopping the engine turning over completely .
Could be summat daft (with luck)  |
| Guest |
 Guest Brolly Dolly
| bikecruiser.co.uk |
 Posted: 22:18 - 10 Mar 2005 Post subject: |
WELL! What a bitch!!
FINALLY got the engine out, which was a lot harder than i expected! because there's a spacer on the bottom right hand side at the back of the engine, WHICH i didnt have an allen key to fit.. Hammer and chisel done it tho!
So, anyways, gets the engine to bits today, and i take a look at my pistons and barrel... Fine, everythin was gr8..
So, went further down and checked the crank.. Looked good.. Gear box... Sound!
Hmmmmmm, so, i turned the engine the right way up (after it being upside down.. I'm looking at it, and what do i see?? The plastic runner that the cam chain runs down.. Only 1 bolt holding it in..
Quickly turned the engine back over, and there it was jamming up the crank.. NO DAMAGE anywhere.. which is a good thing!
Took that bolt out, and everythin is fine agen now! all that's needed is a bit of a clean and a new gasket set!! Made Up!! hehe
Cheers for everyone's help
So, anyone up for UK in a day then??? It's in the outings n excursions forum if ya avent seen it!
Cheers agen
Deejwah! ____________________ www.BikeCruiser.co.uk |
The last post was made 21 years, 213 days ago. Instead of replying here, would creating a new thread be more useful? |
