Big bore :S
jamie192
PostPosted: 22:28 - 28 Feb 2005    Post subject: Big bore :S Reply with quote
Right, try two. On my suzuki ts 50 x
I want to put my big bore on my bike again, i had it fitted before. It would idle but not at a set point it like varied between 1.5k and 3 k changing from 3 for about 20 seconds then dropping down to 2 and so on.
It also had no power under 5 k revs, over that it was fine. now under 5 k revs and above 2 k ish is the needle jet on a carb right?
Also would i need to change the main jet if it runs alright over that. If any one can help or add me to msn on [email protected]
that would be a good help. thanks for your time.
Ride Fast, Brake hard, don't fall off!
Dom_
Points Mean Prizes
PostPosted: 22:41 - 28 Feb 2005    Post subject: Reply with quote
What main jet you running?
What carb you got?
What's the make of the big bore?
jamie192
PostPosted: 22:43 - 28 Feb 2005    Post subject: Reply with quote
jet is 67.5
carb .... pass the standard ts 50 x one.....
bore make, hi-level parts
binge
Emo Kiddy
PostPosted: 22:46 - 28 Feb 2005    Post subject: Reply with quote
Bore kits range from bottom end power and top end power. It depends how it has been bored.
My guess is that its a top end power kit. SO you will basically need to set it all up. and then Down gear the bike So it has more torque.
Thats just a guess anyway...
<|Ben|>
The last post was made 21 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.11 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 39.06 Kb
