Tiny paint chip to tank
Kingbroady
PostPosted: 22:22 - 05 Jan 2017    Post subject: Tiny paint chip to tank Reply with quote
Hi.
My new YBR has a tiny paint chip to the tank. I mean tiny, about the size of a pin head. However, I'm OCD and stuff like this really nags at me.
Anyway, I wiped, waxed, wiped with an alcohol wipe and finally fitted a tank pad which covers it. However, I've since thought whether I've done the right thing and whether this will rust.
Do I need to remove the tank pad and add touch up paint to it? The chip is not down to the metal and is effectively sealed with the tank grip.
A very anal question, I know, but something so tiny feels like a huge wound.
I've also told myself repeatedly to get a grip yet here I am asking for advice on a forum.
mudcow007
PostPosted: 22:37 - 05 Jan 2017    Post subject: Reply with quote
it will be reet, no doubt the bike is going to pick up knocks an dings.
If the chip is under the adhesive of the pad, no air/ water can get to it so it should be cool
PostPosted: 22:41 - 05 Jan 2017    Post subject: Reply with quote
To be sure, I'd very carefully peel back the pad, wipe down again with alcohol, rinse thoroughly with clean water, then, very, very gently, throw the YBR in a ditch and buy a real bike.
6 years and still tiddling, love a duck.
jaffa90
PostPosted: 00:16 - 06 Jan 2017    Post subject: Reply with quote
If you want nagging get married and have kids. Rolling Eyes Smile
RhynoCZ
PostPosted: 00:24 - 06 Jan 2017    Post subject: Reply with quote
OP, go to the paint shop, ask for a paint (small amount) in the colour of your tank (they'll mix it up for you), then use a small brush to touch the place with paint. Let it dry up, then smooth it out and wax it.
If you ever had/buy a car, that's pretty much what you do with the paint chips and scratches, to prevent it from rusting.
bugeye_bob
PostPosted: 00:41 - 06 Jan 2017    Post subject: Reply with quote
Cocktail stick is very good for tiny chips.
tom_e
PostPosted: 10:40 - 06 Jan 2017    Post subject: Reply with quote
Peel the tank pad off, clean the chip up again, dab a little clear lacquer on it to seal it properly then reapply tank pad.
This is coming from the man who is still just using a dab of thick grease to seal a chip on my tank because I'm too lazy to do fuck all else about it.
Teflon-Mike
tl;dr
PostPosted: 07:21 - 07 Jan 2017    Post subject: Re: Tiny paint chip to tank Reply with quote
No.. no you aren't.....
IF you WERE.... then you would have to nib back around the chip; prime & touch with colour match...
THEN you'd spot it.. and it doesn't 'quite' match.... so you would nib back a wider area, and path spray, cut back and laquer, to blend...
AND you'd STILL 'see' it... so you'd sand down the whole tank; prime, spray, get genuine Yamaha Decals to re-finish, and laquer over....
THEN you'd sit back, relax and admire your handiwork...... and ride into the back of a bus!!!!!!!
Alternatively.... you'd get off and note that the side panels don't 'quite'match the shininess/colour of the tank..... And THIS will NOT do.... so out will come the wet and dry, the primer, paint, OE Decals and laquer again.. ad that wll show up the tail unit and front mudguard... and of course the seat, and OH! Those handlbars look a bit 'tatty'...
And the buses need never worry... you will NEVER ride again, you'll be too busy chasing infinitesimal 'faults cleaning contacts, spraying connector blocks with WD40 and sealing with Vaseline; dangling brake levers in ice cream tubs on battery charger clips re-doing the anodize, and sending exhaust headers away to be show-chromed.... and WHEN there's nothing left to 'improve'..... wearing it all out with T-Cut and Solvol.
Tank pad over a chip? You're not OCD your a heathen Botchilist!!!
Wear your patina with pride man! shows you use the damn thing!
Mawsley
PostPosted: 10:32 - 07 Jan 2017    Post subject: Reply with quote
So many people have OCD these days, it's almost like it's contagious.
PostPosted: 11:25 - 07 Jan 2017    Post subject: Reply with quote
That's if they're not ADHD, Arseburger, or dyslexic.
PostPosted: 12:08 - 07 Jan 2017    Post subject: Reply with quote
Dyspraxic is the diagnosis that all the cool bikers are buying this year.
Kingbroady
PostPosted: 13:32 - 07 Jan 2017    Post subject: Reply with quote
Thanks for the advice and the attempted wit. I look forward to your appearance on Channel 4's 100 Greatest Comedians.
Teflon-Mike
tl;dr
PostPosted: 14:16 - 07 Jan 2017    Post subject: Reply with quote
Rogerborg wrote:
Dyspraxic
Is that a bit like Iopreptol?
What does it taste like mixed with Red-Bull?
And do you still have a moster nrg hang-over off it in the morning?
PostPosted: 18:19 - 07 Jan 2017    Post subject: Reply with quote
Am I on it yet?
Best check again.
Am I on it yet?
Best check again.
Am I on it yet?
PostPosted: 13:56 - 08 Jan 2017    Post subject: Reply with quote
How about now?
smegballs
PostPosted: 22:57 - 08 Jan 2017    Post subject: Reply with quote
You'll probably bin the bike and scratch the tank to fuck sooner than the miniscule chip compromises that tanks integrity.
The last post was made 9 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 92.34 Kb
