bike only runs on choke
snowrascal
PostPosted: 18:42 - 07 Jan 2017    Post subject: bike only runs on choke Reply with quote
hello
i have a 70cc peugeot xp6, it was a non runner until i put a brand new carb on plus a new plug and change of oil and 2 stroke.
it starts up on choke and runs well then dies out, next i turn off the choke and it runs for 30 seconds and then dies
any ideas?
thanks in advance Smile
Nobby the Bastard
Harley Gaydar
PostPosted: 20:07 - 07 Jan 2017    Post subject: Reply with quote
Does it have a vacuum fuel tap?
Triumph Sprint ST 1050
snowrascal
PostPosted: 20:12 - 07 Jan 2017    Post subject: Reply with quote
nope there isn't a vacuum fuel tap only a hole in the fuel cap which has a screw in (no air is getting in)
Nobby the Bastard
Harley Gaydar
PostPosted: 20:46 - 07 Jan 2017    Post subject: Reply with quote
I mean on the tank....
snowrascal
PostPosted: 20:49 - 07 Jan 2017    Post subject: Reply with quote
no, its just a a standard fuel shut off value
Nobby the Bastard
Harley Gaydar
PostPosted: 20:59 - 07 Jan 2017    Post subject: Reply with quote
There should be a drain screw in the bottom of the carb. Undo it and see if fuel comes out.
snowrascal
PostPosted: 13:07 - 08 Jan 2017    Post subject: Reply with quote
theres no drain screw on the carb
Nobby the Bastard
Harley Gaydar
PostPosted: 13:54 - 08 Jan 2017    Post subject: Reply with quote
Have you tried riding it? Does it die?
Hong Kong Phooey
PostPosted: 13:55 - 08 Jan 2017    Post subject: Reply with quote
Could be running lean, hence running ok when you enrich the mixture on choke.
Brand new carb, meaning pristine clean? Did you tinker with the screws?
PostPosted: 14:15 - 08 Jan 2017    Post subject: Reply with quote
Is the fuel filter blocked or fuel line kinked/trapped?
WD Forte
PostPosted: 15:01 - 08 Jan 2017    Post subject: Reply with quote
uh?
why the screw?
fuel caps need small holes in them to allow air in to displace fuel
used by the engine
bikers smell of wee
snowrascal
PostPosted: 15:52 - 08 Jan 2017    Post subject: Reply with quote
it rides for on choke for 2 minutes and without for 30 seconds then dies. and yes it was brand new increased the idle screw a little. fuel line are clean and so is the filter. the screw was in the tank before i brought it
thanks
Hong Kong Phooey
PostPosted: 17:15 - 08 Jan 2017    Post subject: Reply with quote
As everyone above is intonating, it seems like fuel starvation. You sure there are no vac lines are connected to the fuel tap?
Is fuel flowing from the tap?
Are all gaskets and rubbers air tight?
bypass2
PostPosted: 19:21 - 08 Jan 2017    Post subject: Reply with quote
Take the petrol cap off start it up see if it starts and runs ok without the cap if it does must be the screw.
The last post was made 9 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 75.48 Kb
